Ana içeriğe geç
Punkt MP02 Battery Replacement
Neye ihtiyacın var
  1. Punkt MP02 Battery Replacement, Battery: adım 1, 2 resimden 1. Punkt MP02 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Use a SIM card eject tool to to eject and remove the SIM card tray on the side of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Punkt MP02 Battery Replacement: adım 2, 2 resimden 1. Punkt MP02 Battery Replacement: adım 2, 2 resimden 2.
    • The back panel is held on by glue and multiple tabs.
    • Slide a Jimmy into the seam between the back panel and the chassis.
    • Slide the Jimmy around the perimeter to release the back panel, with care not to damage the retaining clips.
    • Clean any old adhesive with a spudger and isopropyl alcohol, then apply new adhesive to the back panel before reinstalling it.
    FixBot'a Sor
    Yorum Ekle
  3. Punkt MP02 Battery Replacement: adım 3, 3 resimden 1. Punkt MP02 Battery Replacement: adım 3, 3 resimden 2. Punkt MP02 Battery Replacement: adım 3, 3 resimden 3.
    • Use a Phillips screwdriver to remove the two adjacent 3 mm Phillips screws.
    FixBot'a Sor
    Yorum Ekle
  4. Punkt MP02 Battery Replacement: adım 4, 3 resimden 1. Punkt MP02 Battery Replacement: adım 4, 3 resimden 2. Punkt MP02 Battery Replacement: adım 4, 3 resimden 3.
    • Insert a Jimmy into the seam between the front and back case.
    • Slide the Jimmy around the perimeter while prying to separate the front and back case.
    FixBot'a Sor
    Yorum Ekle
  5. Punkt MP02 Battery Replacement: adım 5, 2 resimden 1. Punkt MP02 Battery Replacement: adım 5, 2 resimden 2.
    • Use a spudger to pry up and disconnect the battery press connector.
    • Make sure to pry under the connector itself and not on the board.
    FixBot'a Sor
    Yorum Ekle
  6. Punkt MP02 Battery Replacement: adım 6, 2 resimden 1. Punkt MP02 Battery Replacement: adım 6, 2 resimden 2.
    • Gently pry the battery off with the spudger tool.
    • Take care not to bend, warp, or puncture the battery during removal.
    FixBot'a Sor
    Yorum Ekle
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Elias Fischer
425 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 32
Son 30 gün: 116
Her zaman: 291
