Ana içeriğe geç
Razer Barracuda X Battery Replacement
Neye ihtiyacın var
  1. Razer Barracuda X Battery Replacement, Battery: adım 1, 3 resimden 1. Razer Barracuda X Battery Replacement, Battery: adım 1, 3 resimden 2. Razer Barracuda X Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the cushion by pulling it off from the edge and out from the grooves.
    • Continue to pull the cushion away from the speaker until the cushion is fully separated.
    FixBot'a Sor
  2. Razer Barracuda X Battery Replacement: adım 2, 1 resimden 1.
    • Remove the four 6 mm Phillips #1 screws from the left side of the speaker casing.
    FixBot'a Sor
  3. Razer Barracuda X Battery Replacement: adım 3, 2 resimden 1. Razer Barracuda X Battery Replacement: adım 3, 2 resimden 2.
    • Gently pull the speaker casing away from the shell.
    • Place it face down to access the battery.
    FixBot'a Sor
  4. Razer Barracuda X Battery Replacement: adım 4, 2 resimden 1. Razer Barracuda X Battery Replacement: adım 4, 2 resimden 2.
    • Unplug the battery from the socket.
    • Use a spudger to gently lift the battery up.
    • Remove the battery.
    FixBot'a Sor
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
5 farklı kişi bu kılavuzu tamamladı.
Micah Ortiz
307 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-3, Petersen Fall 2022 UMass Dartmouth, Team 2-3, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S2G3
4 Üyeler
10 adet Kılavuz yazıldı
8Kılavuz Yorumları
What is the voltage of the battery?
Bavo Van Rillaer - Yanıt Paylaş
It’s a 3.7V battery.
Dániel Baranyi - Yanıt Paylaş
Battery info Barracuda X Wireless (2022) version but I believe the non 2022 version also:
55345PN2 / 1ICP6/35/51 1200mAh/4.44Wh
Dominick - Yanıt Paylaş
Si, 3,7 v se ve muy mal en la foto del Paso 4
Carlos López (España - Spain) - Yanıt Paylaş
How small is that battery?? i took mine apart and i saw i got the wrong size battery in general.
JPStruggle - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 57
Son 30 gün: 326
Her zaman: 9,587
