Ana içeriğe geç
Razer Blade 15 Advanced Model (Early 2020) Battery Replacement
Neye ihtiyacın var
  1. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 2.
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Unfasten the back cover: adım 2, 2 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Unfasten the back cover: adım 2, 2 resimden 2.
    • Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
  3. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Insert an opening pick: adım 3, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Insert an opening pick: adım 3, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Insert an opening pick: adım 3, 3 resimden 3.
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If it feels loose, remove it at any time.
    • Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Angle the opening pick: adım 4, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Angle the opening pick: adım 4, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Angle the opening pick: adım 4, 3 resimden 3.
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
  5. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Free the bottom right corner: adım 5, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Free the bottom right corner: adım 5, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Free the bottom right corner: adım 5, 3 resimden 3.
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Free the front edge: adım 6, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Free the front edge: adım 6, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Free the front edge: adım 6, 3 resimden 3.
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
  7. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Remove the back cover: adım 7, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Remove the back cover: adım 7, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Remove the back cover: adım 7, 3 resimden 3.
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
  8. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Disconnect the battery: adım 8, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Disconnect the battery: adım 8, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Disconnect the battery: adım 8, 3 resimden 3.
    • Insert the point of a spudger under the middle of the battery connector's long edge.
    • Lift and disconnect the battery press connector from its socket on the motherboard.
    • This will require some force. Don't pry against any resistors or chips.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  9. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Unfasten the battery: adım 9, 2 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Unfasten the battery: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a Phillips screwdriver to remove the six 4.6 mm‑long screws securing the battery.
    • Some battery screws may have stickers on them. Pierce through them with your screwdriver or use tweezers to remove them.
  10. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Separate the adhesive: adım 10, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Separate the adhesive: adım 10, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Separate the adhesive: adım 10, 3 resimden 3.
    • An adhesive pad under the battery's top left corner secures it to the frame.
    • Take care not to puncture or bend the battery—it can leak dangerous chemicals and/or catch fire.
    • Insert an opening pick between the frame and the bottom left edge of the battery.
    • Slowly pry the battery up until the adhesive separates.
    • Don't apply significant force. All that's needed is constant pressure.
    • Leave the pick inserted between the battery and frame to prevent the battery from readhering.
  11. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Remove the battery: adım 11, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Remove the battery: adım 11, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Battery Replacement, Remove the battery: adım 11, 3 resimden 3.
    • Grab the middle of the battery and lift the left edge.
    • Slide the battery's right edge out from its recess in the frame and remove the battery.
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
4 farklı kişi bu kılavuzu tamamladı.
Spencer Day
55.149 İtibar
408 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.410 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 101
Son 30 gün: 441
Her zaman: 4,070
