Ana içeriğe geç
Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement
Neye ihtiyacın var
  1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 2.
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Unfasten the back cover: adım 2, 2 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Unfasten the back cover: adım 2, 2 resimden 2.
    • Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
  3. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Insert an opening pick: adım 3, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Insert an opening pick: adım 3, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Insert an opening pick: adım 3, 3 resimden 3.
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If it feels loose, remove it at any time.
    • Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Angle the opening pick: adım 4, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Angle the opening pick: adım 4, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Angle the opening pick: adım 4, 3 resimden 3.
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
  5. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Free the bottom right corner: adım 5, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Free the bottom right corner: adım 5, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Free the bottom right corner: adım 5, 3 resimden 3.
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Free the front edge: adım 6, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Free the front edge: adım 6, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Free the front edge: adım 6, 3 resimden 3.
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
  7. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Remove the back cover: adım 7, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Remove the back cover: adım 7, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Remove the back cover: adım 7, 3 resimden 3.
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
  8. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Disconnect the battery: adım 8, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Disconnect the battery: adım 8, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Disconnect the battery: adım 8, 3 resimden 3.
    • Insert the point of a spudger under the middle of the battery connector's long edge.
    • Lift and disconnect the battery press connector from its socket on the motherboard.
    • This will require some force. Don't pry against any resistors or chips.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  9. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Disconnect the display cables: adım 9, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Disconnect the display cables: adım 9, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Disconnect the display cables: adım 9, 3 resimden 3.
    • Insert the point of a spudger under the metal locking clip that snaps around the perimeter of the primary display cable’s socket.
    • Swing the clip up and over the socket.
    • Gently pull the display cable straight out of its socket.
  10. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement: adım 10, 1 resimden 1.
    • Use a piece of tape to hold the primary display cable out of the way for better access to the other display cable.
    • Don't crease the cable or position it at an extreme angle, as this can damage it.
  11. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement: adım 11, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement: adım 11, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement: adım 11, 3 resimden 3.
    • Use the tip of a spudger or a clean fingernail to flip up the small, hinged locking flap on the secondary display cable's ZIF connector.
    • Gently pull the cable straight out of its socket.
  12. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Heat the display cable: adım 12, 2 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Heat the display cable: adım 12, 2 resimden 2.
    • Note: Adhesive secures the secondary display cable to the top of the RAM sockets.
    • Heat an iOpener and apply it to the secondary display cable for two minutes.
    • You can also use a hair dryer. Follow this guide for more instructions.
  13. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Peel up the display cable: adım 13, 2 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Peel up the display cable: adım 13, 2 resimden 2.
    • Peel the secondary display cable from the top of the RAM sockets.
  14. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement: adım 14, 2 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement: adım 14, 2 resimden 2.
    • Peel up the primary display cable that you taped down earlier.
  15. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Heat the fabric tape: adım 15, 2 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Heat the fabric tape: adım 15, 2 resimden 2.
    • Note: Fabric tape secures the display cables to the heatsink.
    • Apply a heated iOpener to the fabric tape for two minutes.
  16. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Detach the display cables: adım 16, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Detach the display cables: adım 16, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Detach the display cables: adım 16, 3 resimden 3.
    • Slide the flat end of a spudger under one side of the display cables and gently lift to detach them from the heatsink.
  17. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement: adım 17, 1 resimden 1.
    • Lift the other side of the display cables to fully detach them from the heatsink.
  18. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Reposition the display cables: adım 18, 2 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Reposition the display cables: adım 18, 2 resimden 2.
    • Gently lay the display cables over the top edge of the laptop.
  19. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Remove the screw covers: adım 19, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Remove the screw covers: adım 19, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Remove the screw covers: adım 19, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Note: Some heatsink screws may have foam covers on them.
    • Use a pair of tweezers or your fingers to remove the covers.
  20. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Unfasten the heatsink: adım 20, 2 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Unfasten the heatsink: adım 20, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 11 screws securing the heatsink:
    • Eight 6.7 mm‑long screws
    • One 4.6 mm‑long screw
    • One 5.7 mm‑long screw
    • One 4 mm‑long screw
    • This screw may be covered by a sticker. Pierce through it with your screwdriver or use tweezers to remove it.
  21. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Thermal paste information: adım 21, 2 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Thermal paste information: adım 21, 2 resimden 2.
    • Note: Large globs of thermal paste and multiple thermal pads bond the heatsink very strongly to the motherboard.
  22. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Separate the heatsink: adım 22, 3 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Separate the heatsink: adım 22, 3 resimden 2. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Separate the heatsink: adım 22, 3 resimden 3.
    • Use strong, steady pressure to release the heatsink from the motherboard in the next two steps.
    • Insert the flat end of a spudger between the top edge of the heatsink and frame.
    • Pry the heatsink up at different points along the top edge to release it from the motherboard.
    • If the heatsink won't budge at all, use a hair dryer to warm the heatsink and soften the thermal pads.
  23. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement: adım 23, 2 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement: adım 23, 2 resimden 2.
    • Use the flat end of a spudger to lift (not pry) the heatsink at different points along its edges until the heatsink completely detaches from the motherboard.
    • Be careful not to scrape off any surface-mounted components when putting the spudger under the heatsink.
  24. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Remove the heatsink: adım 24, 2 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Remove the heatsink: adım 24, 2 resimden 2.
    • Remove the heatsink.
  25. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Reassembly information: adım 25, 2 resimden 1. Razer Blade 15 Advanced Model (Early 2020) Heatsink Replacement, Reassembly information: adım 25, 2 resimden 2.
    • Before installing a new heatsink, follow this guide to clean the CPU, GPU, and heatsink and reapply thermal paste.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Spencer Day
96.153 İtibar
662 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
120 Üyeler
19.664 adet Kılavuz yazıldı
1Rehber Yorum
Hi, thank you for detailed tutorial. Do you know how thick ware thermal pads? Thanks
Matej Hudák - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 22
Son 30 gün: 137
Her zaman: 2,795
