Giriş
Use this guide to replace the battery in your Razer Blade 15" (2020) laptop.
If your laptop dies quickly or doesn't hold a charge, it might be time to replace the battery.
If your battery is swollen, take appropriate precautions.
Neye ihtiyacın var
Unplug all cables and fully shut down your laptop.
Close the lid and flip your laptop over so the back cover faces up.
Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
Apply a heated iOpener to the battery cable tape for one minute.
Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
Use a Phillips screwdriver to remove the five 5.3 mm screws securing the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
