Ana içeriğe geç
Razer Blade 15" (2020) Battery Replacement
Neye ihtiyacın var
  1. Razer Blade 15" (2020) Battery Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 1. Razer Blade 15" (2020) Battery Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 2.
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    • Close the lid and flip your laptop over so the back cover faces up.
  2. Razer Blade 15" (2020) Battery Replacement, Unfasten the back cover: adım 2, 1 resimden 1.
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  3. Razer Blade 15" (2020) Battery Replacement, Loosen the back cover: adım 3, 3 resimden 1. Razer Blade 15" (2020) Battery Replacement, Loosen the back cover: adım 3, 3 resimden 2. Razer Blade 15" (2020) Battery Replacement, Loosen the back cover: adım 3, 3 resimden 3.
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  4. Razer Blade 15" (2020) Battery Replacement, Remove the back cover: adım 4, 3 resimden 1. Razer Blade 15" (2020) Battery Replacement, Remove the back cover: adım 4, 3 resimden 2. Razer Blade 15" (2020) Battery Replacement, Remove the back cover: adım 4, 3 resimden 3.
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
  5. Razer Blade 15" (2020) Battery Replacement, Soften the battery cable tape adhesive: adım 5, 2 resimden 1. Razer Blade 15" (2020) Battery Replacement, Soften the battery cable tape adhesive: adım 5, 2 resimden 2.
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
  6. Razer Blade 15" (2020) Battery Replacement, Remove the battery cable tape: adım 6, 3 resimden 1. Razer Blade 15" (2020) Battery Replacement, Remove the battery cable tape: adım 6, 3 resimden 2. Razer Blade 15" (2020) Battery Replacement, Remove the battery cable tape: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
  7. Razer Blade 15" (2020) Battery Replacement, Disconnect the battery: adım 7, 2 resimden 1. Razer Blade 15" (2020) Battery Replacement, Disconnect the battery: adım 7, 2 resimden 2.
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  8. Razer Blade 15" (2020) Battery Replacement, Unfasten the battery: adım 8, 3 resimden 1. Razer Blade 15" (2020) Battery Replacement, Unfasten the battery: adım 8, 3 resimden 2. Razer Blade 15" (2020) Battery Replacement, Unfasten the battery: adım 8, 3 resimden 3.
    • Use a Phillips screwdriver to remove the five 5.3 mm screws securing the battery.
    • If stickers cover any of the screw heads, peel and remove them.
  9. Razer Blade 15" (2020) Battery Replacement, Remove the battery: adım 9, 3 resimden 1. Razer Blade 15" (2020) Battery Replacement, Remove the battery: adım 9, 3 resimden 2. Razer Blade 15" (2020) Battery Replacement, Remove the battery: adım 9, 3 resimden 3.
    • Remove the battery.
    • There's a delicate cable that might be adhered to the underside of the battery. If so, gently unstick it as you lift the battery.
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
Clay Eickemeyer
67.203 İtibar
453 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.410 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 43
Son 30 gün: 223
Her zaman: 1,558
