Giriş
Follow this guide to remove and replace the icemaker assembly in your older Samsung refrigerator.
This guide will work for older (2013) French-door Samsung refrigerators where the icemaker is in the refrigerator compartment. If your icemaker is in the freezer drawer, follow this guide instead.
If your ice maker is frozen, follow this guide to defrost it.
Note: Even if you've followed instructions to defrost your refrigerator, you may need a steamer to aid in removing any leftover ice build up. You should use the steamer whenever necessary throughout the repair to melt any iced over areas.
This guide is based on a model RFG298HDRS refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Neye ihtiyacın var
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
Use your fingers to pull the front edge of cable cover out from the side of the ice room.
Locate the ice maker and ice auger motor connectors.
Remove both cables from the cable guide channel.
Depress the locking tab at the top of the ice maker.
Be sure to dry any moisture that remains in the ice room before reassembly to prevent repair failure.
Repair didn’t go as planned? Ask our Answers Community for help.
