Removing the HP Elitebook 6930p RTC (CMOS) Battery
Giriş
1. adıma gitThis guide will show you how to locate and remove the RTC (CMOS) battery from the laptop. Please note: Removal of this battery will not clear a BIOS password on the HP Elitebook 6930P and some HP Business Class notebooks.
Neye ihtiyacın var
Flip laptop over and locate the battery release button
Push release button to the left to release battery and gently pull battery from the laptop
Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
Slide the retention clips toward the keyboard to release the keyboard
Use a plastic pry tool to lift the rear edge of the keyboard.
Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
Lift the keyboard up to reveal the ribbon connectors
Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
Release the smaller ribbon cable by lifting up the white retainer
Locate the the battery
Disconnect the battery from the connector
Gently un-clip the battery from the plastic housing to completely remove it from the laptop
10 farklı kişi bu kılavuzu tamamladı.
8Kılavuz Yorumları
This did not work for me. I left the CMOS battery disconnected for a day.
You need to contact HP to get this resolved.
This didn't work for me
I can't even boot
cool i like the explanation
Τελικά μπορούμε με κάποιο τρόπο να αφαιρέσουμε κωδικό πρόσβασης BIOS για την HP EliteBook 6930p????
Αν όχι μήπως θα λειτουργούσε ένας δίσκος λειτουργικού γραμμένος από ένα άλλο HP EliteBook 6930p ώστε να μην χρειαστούμε πρόσβασης BIOS?????
It would have been helpful to let everyone know that this requires a new battery which contains the clips and the black plastic cover. The leads are spot welded to the battery so you just can’t change out the 2032 battery like you can with a desktop system. Batteries are available from Amazon or a computer store for about $14.
thankyou thankyou
charging port
