Ana içeriğe geç
Removing the HP Elitebook 6930p RTC (CMOS) Battery
Richdave
Richdave ve 2 diğer katkıda bulunanlar
En son June 23, 2022 tarihinde güncellendi
25 dakika
Orta
Topluluk-Katkılı Kılavuz
This guide will show you how to locate and remove the RTC (CMOS) battery from the laptop. Please note: Removal of this battery will not clear a BIOS password on the HP Elitebook 6930P and some HP Business Class notebooks.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Removing the HP Elitebook 6930p RTC (CMOS) Battery, Battery Removal: adım 1, 3 resimden 1. Removing the HP Elitebook 6930p RTC (CMOS) Battery, Battery Removal: adım 1, 3 resimden 2. Removing the HP Elitebook 6930p RTC (CMOS) Battery, Battery Removal: adım 1, 3 resimden 3.
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p RTC (CMOS) Battery, Keyboard: adım 2, 3 resimden 1. Removing the HP Elitebook 6930p RTC (CMOS) Battery, Keyboard: adım 2, 3 resimden 2. Removing the HP Elitebook 6930p RTC (CMOS) Battery, Keyboard: adım 2, 3 resimden 3.
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p RTC (CMOS) Battery: adım 3, 3 resimden 1. Removing the HP Elitebook 6930p RTC (CMOS) Battery: adım 3, 3 resimden 2. Removing the HP Elitebook 6930p RTC (CMOS) Battery: adım 3, 3 resimden 3.
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
    After loosening the four moveable tabs at the screen end you simply pull slightly to the right to loosen the left side and then up to loose the five tabs in the lower end, then flip keyboard over so keys face the screen.
    e5frog - Yanıt
  4. Removing the HP Elitebook 6930p RTC (CMOS) Battery: adım 4, 3 resimden 1. Removing the HP Elitebook 6930p RTC (CMOS) Battery: adım 4, 3 resimden 2. Removing the HP Elitebook 6930p RTC (CMOS) Battery: adım 4, 3 resimden 3.
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
    There is no need at all to loosen any ribbon cables, after flipping keyboard so it faces keys against screen you can simply remove the RAM. Don't fiddle with the ribbon cables.
    e5frog - Yanıt
    Unless, of course, that your actually replacing the keyboard! In which case, remember to keep that rubber pointing device for replacing the one that you’ll probably eventually lose.
    Dennis - Yanıt
  5. Removing the HP Elitebook 6930p RTC (CMOS) Battery, RTC (CMOS) Battery: adım 5, 2 resimden 1. Removing the HP Elitebook 6930p RTC (CMOS) Battery, RTC (CMOS) Battery: adım 5, 2 resimden 2.
    • Locate the the battery
    • If the battery wires are running underneath the WLAN module you will have to remove it first. In my case it was necessary to remove the WLAN module.
    • Disconnect the battery from the connector
    • Removal of this battery will not clear a BIOS password on the HP Elitebook 6930P and some other Business Class notebooks.
    • Gently un-clip the battery from the plastic housing to completely remove it from the laptop
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Richdave
32.419 İtibar
30 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.676 adet Kılavuz yazıldı
8Kılavuz Yorumları
This did not work for me. I left the CMOS battery disconnected for a day.
You need to contact HP to get this resolved.
http://h30434.www3.hp.com/t5/Notebook-Op...
Wm Brian Savacool - Yanıt
This didn't work for me
Depinder Bharti - Yanıt
I can't even boot
Hugo Escobar - Yanıt
cool i like the explanation
Nartey Levis - Yanıt
Τελικά μπορούμε με κάποιο τρόπο να αφαιρέσουμε κωδικό πρόσβασης BIOS για την HP EliteBook 6930p????
Αν όχι μήπως θα λειτουργούσε ένας δίσκος λειτουργικού γραμμένος από ένα άλλο HP EliteBook 6930p ώστε να μην χρειαστούμε πρόσβασης BIOS?????
ΠΑΝΑΓΙΩΤΗΣ ΓΙΑΝΝΑΚΑΚΗΣ - Yanıt
It would have been helpful to let everyone know that this requires a new battery which contains the clips and the black plastic cover. The leads are spot welded to the battery so you just can’t change out the 2032 battery like you can with a desktop system. Batteries are available from Amazon or a computer store for about $14.
Steve Greathouse - Yanıt
thankyou thankyou
armshooter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 28
Son 30 gün: 99
Her zaman: 41,969
