Ana içeriğe geç
Ridgid R860054 Trigger Replacement
Ryan Friedman
Ryan Friedman ve 3 diğer katkıda bulunanlar
En son May 15, 2023 tarihinde güncellendi
Tahmin yok
Orta
Use this guide to replace a damaged or faulty trigger in your Ridgid 860054 Drill.
The drill trigger causes the drill to rotate when pressed. If the trigger is blocked or damaged, it won’t press or it is otherwise faulty, you will be unable to power on and control the drill.
Be sure to cross out all other possibilities on the troubleshooting guide before doing this replacement. It is possible that the drill trigger is still functional. There could be other issues preventing the drill from working instead of the trigger.
Make sure to remove the battery from the drill before beginning the repair.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Ridgid R860054 Trigger Replacement, Ridgid R860054 Disassembly: adım 1, 2 resimden 1. Ridgid R860054 Trigger Replacement, Ridgid R860054 Disassembly: adım 1, 2 resimden 2.
    • Using a T10 Torx security bit, remove the ten screws from the housing assembly.
    • All of the casing screws are the same length and require the same bit.
  2. Ridgid R860054 Trigger Replacement: adım 2, 2 resimden 1. Ridgid R860054 Trigger Replacement: adım 2, 2 resimden 2.
    • Separate one half of the drill casing from the other by gently pulling both halves apart.
    • Once one half of the casing is removed, be careful! If the components are directed towards the ground, they could fall out.
  3. Ridgid R860054 Trigger Replacement: adım 3, 3 resimden 1. Ridgid R860054 Trigger Replacement: adım 3, 3 resimden 2. Ridgid R860054 Trigger Replacement: adım 3, 3 resimden 3.
    • Remove the plastic speed switch and forward/reverse switch by softly lifting them from the casing.
    • Remove the internal components of the drill by lightly pulling on the drill chuck.
    • All of the other electronic components are attached to the chuck, and will come out with it.
  4. Ridgid R860054 Trigger Replacement: adım 4, 1 resimden 1.
    • The main section of the drill should have the trigger, light indicator, and battery prongs all connected via wire. There should be two plastic switches separated from the rest of the body.
  5. Ridgid R860054 Trigger Replacement, Trigger: adım 5, 3 resimden 1. Ridgid R860054 Trigger Replacement, Trigger: adım 5, 3 resimden 2. Ridgid R860054 Trigger Replacement, Trigger: adım 5, 3 resimden 3.
    • Use a thin tool to disconnect the three prongs.
    • Remove the black plastic piece from the trigger body.
    • On the new trigger, follow the same steps as above and remove the cap.
  6. Ridgid R860054 Trigger Replacement: adım 6, 2 resimden 1. Ridgid R860054 Trigger Replacement: adım 6, 2 resimden 2.
    • Remove the trigger circuit from the plastic trigger body.
  7. Ridgid R860054 Trigger Replacement: adım 7, 3 resimden 1. Ridgid R860054 Trigger Replacement: adım 7, 3 resimden 2. Ridgid R860054 Trigger Replacement: adım 7, 3 resimden 3.
    • Place the circuit into the new trigger and closure.
    • Place the plastic cap back on the trigger to secure the wire.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Friedman
130 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Shaddix Spring 2023 UMass Dartmouth, Team 1-1, Shaddix Spring 2023 üyesi
UMASSD-SHADDIX-S23S1G1
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 329
