Ana içeriğe geç
Rival Mini Chopper MC-67BL Power Button Replacement
  1. Rival Mini Chopper MC-67BL Power Button Replacement, Turning Gears: adım 1, 2 resimden 1. Rival Mini Chopper MC-67BL Power Button Replacement, Turning Gears: adım 1, 2 resimden 2.
    • Twist the plastic lid counterclockwise to unlock it.
    • Lift the lid to remove it from the container.
  2. Rival Mini Chopper MC-67BL Power Button Replacement: adım 2, 1 resimden 1.
    • Carefully remove the blade from the container.
    • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
  3. Rival Mini Chopper MC-67BL Power Button Replacement: adım 3, 1 resimden 1.
    • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
  4. Rival Mini Chopper MC-67BL Power Button Replacement: adım 4, 1 resimden 1.
    • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
    • The two feet furthest from the button tower contain screws. The other two feet do not.
  5. Rival Mini Chopper MC-67BL Power Button Replacement: adım 5, 2 resimden 1. Rival Mini Chopper MC-67BL Power Button Replacement: adım 5, 2 resimden 2.
    • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
    • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
  6. Rival Mini Chopper MC-67BL Power Button Replacement: adım 6, 1 resimden 1.
    • Firmly lift the bottom cover off of the base.
  7. Rival Mini Chopper MC-67BL Power Button Replacement: adım 7, 1 resimden 1.
    • Remove the smaller white gear by lifting it up with your hand.
  8. Rival Mini Chopper MC-67BL Power Button Replacement: adım 8, 3 resimden 1. Rival Mini Chopper MC-67BL Power Button Replacement: adım 8, 3 resimden 2. Rival Mini Chopper MC-67BL Power Button Replacement: adım 8, 3 resimden 3.
    • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
    • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
    • Continue turning the gear until completely removed from the blade-shaft.
  9. Rival Mini Chopper MC-67BL Power Button Replacement, Power Button: adım 9, 1 resimden 1.
    • Use your hand to firmly pull the blade-shaft from the base.
  10. Rival Mini Chopper MC-67BL Power Button Replacement: adım 10, 1 resimden 1.
    • Using Phillips #2 screwdriver, unscrew two 12.7-mm screws in the middle of the base.
  11. Rival Mini Chopper MC-67BL Power Button Replacement: adım 11, 1 resimden 1.
    • Unwind power cord from the base pegs.
  12. Rival Mini Chopper MC-67BL Power Button Replacement: adım 12, 2 resimden 1. Rival Mini Chopper MC-67BL Power Button Replacement: adım 12, 2 resimden 2.
    • Use the plastic opening tool to pry open the base from the main body.
    • These two plastic prongs are pressed fit into the base. It may take some effort to pry the base completely off.
    • Once freed, lift the base panel from the main body and set it aside.
  13. Rival Mini Chopper MC-67BL Power Button Replacement: adım 13, 2 resimden 1. Rival Mini Chopper MC-67BL Power Button Replacement: adım 13, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the three 9.53-mm screws from inside the main body.
    • Next, turn the device upright and lift the upper casing from around the button gently.
  14. Rival Mini Chopper MC-67BL Power Button Replacement: adım 14, 1 resimden 1.
    • Remove the button by simply pulling it up.
    • Don't lose the spring under the button! Without it, the blender will not function.
Sonuç
David Otsu
109 İtibar
1 Kılavuz yazıldı
Cal Poly, Team 4-29, Amido Fall 2013 Cal Poly, Team 4-29, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S4G29
4 Üyeler
5 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 619
