Ana içeriğe geç
Roku 2 Remote Control Buttons Replacement
Alex Saltos
Alex Saltos ve 7 diğer katkıda bulunanlar
En son June 27, 2024 tarihinde güncellendi
5 dakika
Kolay
If you replace the batteries on your Roku 2 remote and it is still not operational the Dpad or the other buttons could be faulty. The Dpad on the remote is how you navigate the television. If this button falls off or is nonfunctional (i.e. not turning channels or letting you click on shows) the Roku remote may need a replacement Dpad. Follow the steps in this guide to replace these buttons.
Neye ihtiyacın var
Aletler
  1. Roku 2 Remote Control Buttons Replacement, Remote Battery: adım 1, 1 resimden 1.
    • Turn over remote and press down on tab to remove.
  2. Roku 2 Remote Control Buttons Replacement: adım 2, 1 resimden 1.
    • Remove batteries
  3. Roku 2 Remote Control Buttons Replacement: adım 3, 1 resimden 1.
    • Place the new batteries into the remote. Make sure the positive terminal is facing the positive terminal of the slot. Similarly the negative terminal should be touching the negative terminal. If done right the batteries should be facing opposite directions of each other.
    • Insert Roku tab back on to its slot.
    No. They should be facing in the same direction, not the opposite direction. Roku does it differently than most other manufacturers.
    Alex Zavatone - Yanıt
  4. Roku 2 Remote Control Buttons Replacement, Remote Control Buttons: adım 4, 1 resimden 1.
    • After removing the batteries, use a #000 Phillips to remove the screw.
    There is no screw.
    Ernst B - Yanıt
    No screw on mine either.
    stevemcdowell - Yanıt
    No screw here.
  5. Roku 2 Remote Control Buttons Replacement, Pry the remote open: adım 5, 1 resimden 1.
    • Use a plastic opening tool to pry open the remote.
    What is the plastic opening tool?
    obimokwenye - Yanıt
  6. Roku 2 Remote Control Buttons Replacement: adım 6, 1 resimden 1.
    • Continue along the top of the remote to lift it off the remote.
    • Lift the top of the remote off very carefully so that board doesn't fall.
  7. Roku 2 Remote Control Buttons Replacement, Replace the buttons: adım 7, 1 resimden 1.
    • Identify the buttons to be replaced and take them out.
    Provide link to part numbers and places to order replacements
    Qris Jonz - Yanıt
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Alex Saltos
526 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-5, Sullivan Fall 2015 USF Tampa, Team 1-5, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S1G5
3 Üyeler
7 adet Kılavuz yazıldı
8 Yorum
Well, hmmm; why is it there is actually no screws in mine nor the ones for others. None in mine and 4 in the ones for volume control over tlc tv's etc??
Junebug - Yanıt
I use my mobile to control and I download it at: https://apps.apple.com/us/app/roku-remot...
It's better for me
donor - Yanıt
And where exactly do you buy the new buttons ??
bonzo dog - Yanıt
And just where exactly do you buy the new buttons??
bonzo dog - Yanıt
So I tried every trick to get my remote to work (all the Youtube tricks). Found this, took the remote apart and got it to work with the cover off. New remote coming in two days but I just wanted to say thanks cause now I can watch TV while I wait for my new remote to arrive!!!!!!!!!!! I would not advise using the remote with the cover off, just sayin, but I am lol….
Joe MacRitchie - Yanıt
I would like to have a view of the pc board
Alden Holmes - Yanıt
The OK button on my remote stopped working. I used these instructions to open it, cleaned the button contacts on the board with isopropyl alcohol, then very carefully reassembled it, taking care to observe the orientation of some plastic films carrying contacts for some of the buttons. It now works, though I lost a few bits of plastic opening it. This was a pain. Except for the savings in electronic waste, it was not worth the price of a new remote.
Ismael Colón - Yanıt
A previously asked question restated :
Where can you get a replacement keypad?
Brian Thompson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 41
Son 30 gün: 122
Her zaman: 54,927
