Giriş
Use this guide to remove or replace the front-facing camera on your Samsung Galaxy Note20 Ultra.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Neye ihtiyacın var
Heat an iOpener and apply it to the left side of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive. Reheat any stubborn adhesive.
Use the pointed end of a spudger to pry up and disconnect the wireless charging coil press connector.
Use the pointed end of a spudger to pry up and disconnect the white press connector located in the bottom right of the motherboard shield.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
Use a pair of tweezers to lift up the motherboard shield.
Use your fingers to grip the motherboard shield.
Use the pointed end of a spudger to pry up the battery press connector to safely disconnect the battery before continuing repairs.
Use the pointed end of a spudger to pry up the laser AF sensor press connector.
Use a Phillips screwdriver to remove the four 4.0 mm screws securing the earpiece speaker.
Insert the pointed end of a spudger into the hole marked by a small triangle on the right side of the earpiece speaker.
Use the spudger to pry up and loosen the earpiece speaker from the frame.
Use the pointed end of a spudger to disconnect the front-facing camera cable from the motherboard.
Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the open space in the bottom left corner of the front-facing camera.
Wait two minutes for the isopropyl alcohol to weaken the adhesive around the front-facing camera.
Insert the pointed end of a spudger into the open space in the bottom left of the front-facing camera.
Push the pointed end of the spudger under the front-facing camera.
Pry up the front-facing camera to loosen it from the frame.
Use a pair of tweezers to remove the front-facing camera.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Ultra Answers community for help.
Bir başkası bu kılavuzu tamamladı.
