Giriş
Use this guide to remove or replace the daughterboard in your Samsung Galaxy S21.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
The daughterboard and USB-C charging port are soldered together; replacing one component means replacing both.
It’s not necessary to remove both interconnect cables before removing the daughterboard, but doing so will make the procedure easier.
Some photos show the interconnect cables being replaced individually, but, if you follow the steps in order, they should both be removed.
Neye ihtiyacın var
Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
Remove the SIM card tray.
Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert an opening pick into the gap.
Slide the pick back and forth along the bottom edge to slice through the adhesive.
Leave the pick in to prevent the adhesive from resealing.
Apply a heated iOpener to the back cover's left edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
Apply a heated iOpener to the back cover's right edge for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
Rotate the right-edge opening pick around the top-right corner of the phone.
Slide the top-most opening pick as close to the camera shell as possible.
Repeat for the left-edge pick.
Heat an iOpener and apply it to the camera shell for two minutes.
Rotate the back cover counterclockwise to create a gap between the camera shell and the frame.
Insert an opening pick in the gap.
Gently slide the two picks toward the camera shell so they are under the corners of the back cover adjacent to the camera shell.
Move the picks back and forth along the bridge between the back cover and the camera shell until you create a gap between the camera shell and the frame.
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
If you're using Samsung custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Use a Phillips screwdriver to remove the five 4 mm-long screws securing the motherboard bracket to the frame.
Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the frame.
While using tweezers, or your fingers, to hold the motherboard bracket out of the way, use a spudger to pry up the battery press connector.
While still holding the motherboard bracket out of the way, use a spudger to pry up and disconnect the wireless charging coil's press connector.
Use your fingers to gently peel the wireless charging coil away from the phone.
Use a Phillips screwdriver to remove the six 4 mm screws securing the loudspeaker to the frame.
Insert the point of a spudger into the notch in the top-left corner of the loudspeaker and pry up to release the clips holding it in place.
Remove the loudspeaker.
Use the flat end of a spudger to pry up and disconnect the primary interconnect cable's bottom press connector.
Use tweezers, or your fingers, to remove the primary interconnect cable.
Use the flat end of a spudger to pry up and disconnect the secondary interconnect cable's bottom press connector.
Use tweezers, or your fingers, to remove the secondary interconnect cable.
Use a Phillips screwdriver to remove the three 3.5 mm screws securing the daughterboard to the frame.
Use the point of a spudger to pry up the daughterboard.
Use your fingers to pull the daughterboard up and away from the bottom of the phone and remove it.
After you've completed the repair, follow this guide to test your repair.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I dids this replacement and I am now getting a "SIM not provisioned" message. The board does not seem to know what service provider the sim is with.
