Ana içeriğe geç
Samsung Galaxy S21 Screen Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S21 Screen Replacement, Heat the bottom edge: adım 1, 1 resimden 1.
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display, internal battery, and plastic back cover are both susceptible to heat damage.
  2. Samsung Galaxy S21 Screen Replacement, Separate the bottom adhesive: adım 2, 3 resimden 1. Samsung Galaxy S21 Screen Replacement, Separate the bottom adhesive: adım 2, 3 resimden 2. Samsung Galaxy S21 Screen Replacement, Separate the bottom adhesive: adım 2, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Only insert the pick up to 5 mm, as you may damage internal components if you go further.
  3. Samsung Galaxy S21 Screen Replacement, Slice the bottom adhesive: adım 3, 3 resimden 1. Samsung Galaxy S21 Screen Replacement, Slice the bottom adhesive: adım 3, 3 resimden 2. Samsung Galaxy S21 Screen Replacement, Slice the bottom adhesive: adım 3, 3 resimden 3.
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  4. Samsung Galaxy S21 Screen Replacement, Heat the left edge: adım 4, 1 resimden 1.
    • Apply a heated iOpener to the back cover's left edge for two minutes.
  5. Samsung Galaxy S21 Screen Replacement, Separate the left adhesive: adım 5, 3 resimden 1. Samsung Galaxy S21 Screen Replacement, Separate the left adhesive: adım 5, 3 resimden 2. Samsung Galaxy S21 Screen Replacement, Separate the left adhesive: adım 5, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
  6. Samsung Galaxy S21 Screen Replacement: adım 6, 3 resimden 1. Samsung Galaxy S21 Screen Replacement: adım 6, 3 resimden 2. Samsung Galaxy S21 Screen Replacement: adım 6, 3 resimden 3.
    • Slide an opening pick along the left edge towards the bottom left corner to cut the adhesive.
    • Don't cut past where the camera shell meets the back cover, as you risk cracking the plastic.
  7. Samsung Galaxy S21 Screen Replacement, Heat the right edge: adım 7, 1 resimden 1.
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  8. Samsung Galaxy S21 Screen Replacement, Separate the right adhesive: adım 8, 3 resimden 1. Samsung Galaxy S21 Screen Replacement, Separate the right adhesive: adım 8, 3 resimden 2. Samsung Galaxy S21 Screen Replacement, Separate the right adhesive: adım 8, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Only insert the pick up to 3 mm, as you may damage the secondary interconnect cable, which runs parallel to the right edge.
  9. Samsung Galaxy S21 Screen Replacement: adım 9, 3 resimden 1. Samsung Galaxy S21 Screen Replacement: adım 9, 3 resimden 2. Samsung Galaxy S21 Screen Replacement: adım 9, 3 resimden 3.
    • Slide an opening pick back and forth along the back cover's right edge to cut the adhesive.
  10. Samsung Galaxy S21 Screen Replacement, Separate the corner adhesive: adım 10, 3 resimden 1. Samsung Galaxy S21 Screen Replacement, Separate the corner adhesive: adım 10, 3 resimden 2. Samsung Galaxy S21 Screen Replacement, Separate the corner adhesive: adım 10, 3 resimden 3.
    • Rotate the right-edge opening pick around the top-right corner of the phone.
    • This procedure can be applied to each corner, except the top-left where the rear-facing camera is located.
  11. Samsung Galaxy S21 Screen Replacement, Reposition the opening picks: adım 11, 3 resimden 1. Samsung Galaxy S21 Screen Replacement, Reposition the opening picks: adım 11, 3 resimden 2. Samsung Galaxy S21 Screen Replacement, Reposition the opening picks: adım 11, 3 resimden 3.
    • Slide the top-most opening pick as close to the camera shell as possible.
    • Repeat for the left-edge pick.
  12. Samsung Galaxy S21 Screen Replacement, Heat the camera shell: adım 12, 1 resimden 1.
    • Heat an iOpener and apply it to the camera shell for two minutes.
  13. Samsung Galaxy S21 Screen Replacement, Separate the camera shell adhesive: adım 13, 3 resimden 1. Samsung Galaxy S21 Screen Replacement, Separate the camera shell adhesive: adım 13, 3 resimden 2. Samsung Galaxy S21 Screen Replacement, Separate the camera shell adhesive: adım 13, 3 resimden 3.
    • Rotate the back cover counterclockwise to create a gap between the camera shell and the frame.
    • Only insert the pick up to 5 mm to avoid scratching the camera.
    • Insert an opening pick in the gap.
    • If this method doesn't work, move to the next step for an alternative method; otherwise, skip the next step.
  14. Samsung Galaxy S21 Screen Replacement, Separate the camera shell adhesive (alternate method): adım 14, 3 resimden 1. Samsung Galaxy S21 Screen Replacement, Separate the camera shell adhesive (alternate method): adım 14, 3 resimden 2. Samsung Galaxy S21 Screen Replacement, Separate the camera shell adhesive (alternate method): adım 14, 3 resimden 3.
    • Gently slide the two picks toward the camera shell so they are under the corners of the back cover adjacent to the camera shell.
    • Move the picks back and forth along the bridge between the back cover and the camera shell until you create a gap between the camera shell and the frame.
    • Be careful with this method, as you risk cracking the plastic back cover.
  15. Samsung Galaxy S21 Screen Replacement: adım 15, 3 resimden 1. Samsung Galaxy S21 Screen Replacement: adım 15, 3 resimden 2. Samsung Galaxy S21 Screen Replacement: adım 15, 3 resimden 3.
    • Slide an opening pick between the camera shell and the frame to cut the adhesive.
    • There's a significant amount of adhesive securing the frame to the camera shell, so multiple rounds of heating may be needed.
  16. Samsung Galaxy S21 Screen Replacement: adım 16, 2 resimden 1. Samsung Galaxy S21 Screen Replacement: adım 16, 2 resimden 2.
    • There's additional adhesive to the right of the camera that you need to cut through.
    • There's a plate on the back cover surrounding the phone's flash that the pick can get stuck on:
    • Angle the pick downward to avoid any damage.
  17. Samsung Galaxy S21 Screen Replacement: adım 17, 3 resimden 1. Samsung Galaxy S21 Screen Replacement: adım 17, 3 resimden 2. Samsung Galaxy S21 Screen Replacement: adım 17, 3 resimden 3.
    • Line up the opening pick's tip with your phone's flash
    • Insert the pick slowly, making sure to avoid the flash's plate.
    • The plate's resistance can feel similar to adhesive. Angle the pick downward to keep the pick from sliding into the plate.
    • Slice the adhesive to the right of the camera.
  18. Samsung Galaxy S21 Screen Replacement, Remove the back cover: adım 18, 2 resimden 1. Samsung Galaxy S21 Screen Replacement, Remove the back cover: adım 18, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the back cover.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone until the back cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  19. Samsung Galaxy S21 Screen Replacement, Unfasten the motherboard bracket: adım 19, 1 resimden 1.
    Magnetic Project Mat
    $19.95
    Satın Al
    • Use a Phillips screwdriver to remove the five 4 mm-long screws securing the motherboard bracket to the frame.
    • Throughout this repair, keep track of each screw, and make sure it goes back exactly where it came from.
  20. Samsung Galaxy S21 Screen Replacement, Unclip the motherboard bracket: adım 20, 2 resimden 1. Samsung Galaxy S21 Screen Replacement, Unclip the motherboard bracket: adım 20, 2 resimden 2.
    Satın Al
    • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the frame.
    • Do not completely remove the bracket yet, as it's still attached to the wireless charging coil.
  21. Samsung Galaxy S21 Screen Replacement, Disconnect the battery: adım 21, 2 resimden 1. Samsung Galaxy S21 Screen Replacement, Disconnect the battery: adım 21, 2 resimden 2.
    • While using tweezers, or your fingers, to hold the motherboard bracket out of the way, use a spudger to pry up the battery press connector.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  22. Samsung Galaxy S21 Screen Replacement, Disconnect the wireless charging coil: adım 22, 2 resimden 1. Samsung Galaxy S21 Screen Replacement, Disconnect the wireless charging coil: adım 22, 2 resimden 2.
    • While still holding the motherboard bracket out of the way, use a spudger to pry up and disconnect the wireless charging coil's press connector.
  23. Samsung Galaxy S21 Screen Replacement, Remove the wireless charging coil: adım 23, 3 resimden 1. Samsung Galaxy S21 Screen Replacement, Remove the wireless charging coil: adım 23, 3 resimden 2. Samsung Galaxy S21 Screen Replacement, Remove the wireless charging coil: adım 23, 3 resimden 3.
    • The wireless charging coil is secured to the phone with light adhesive.
    • Use your fingers to gently peel the wireless charging coil away from the phone.
    • During reassembly, refasten the motherboard bracket screws first to properly align the charging coil into place, then firmly press the rest of the coil down to adhere it.
  24. Samsung Galaxy S21 Screen Replacement, Unfasten the loudspeaker: adım 24, 1 resimden 1.
    • Use a Phillips screwdriver to remove the six 4 mm screws securing the loudspeaker to the frame.
  25. Samsung Galaxy S21 Screen Replacement, Remove the loudspeaker: adım 25, 3 resimden 1. Samsung Galaxy S21 Screen Replacement, Remove the loudspeaker: adım 25, 3 resimden 2. Samsung Galaxy S21 Screen Replacement, Remove the loudspeaker: adım 25, 3 resimden 3.
    • Insert the point of a spudger into the notch in the top-left corner of the loudspeaker and pry up to release the clips holding it in place.
    • Remove the loudspeaker.
  26. Samsung Galaxy S21 Screen Replacement, Disconnect the display cable: adım 26, 2 resimden 1. Samsung Galaxy S21 Screen Replacement, Disconnect the display cable: adım 26, 2 resimden 2.
    • Use a spudger to pry up and disconnect the display cable's bottom press connector.
  27. Samsung Galaxy S21 Screen Replacement: adım 27, 2 resimden 1. Samsung Galaxy S21 Screen Replacement: adım 27, 2 resimden 2.
    • Use a spudger to pry up and disconnect the display cable's top press connector.
  28. Samsung Galaxy S21 Screen Replacement, Remove the display cable: adım 28, 1 resimden 1.
    Satın Al
    • Use tweezers, or your fingers, to remove the display cable.
  29. Samsung Galaxy S21 Screen Replacement, Loosen the display adhesive: adım 29, 1 resimden 1.
    • Apply a heated iOpener to the screen for at least five minutes to loosen the adhesive underneath.
    • The display adhesive of the Galaxy S21 is extremely strong, and it's likely you need to reheat and reapply the iOpener several times before starting the display removal and during the removal procedure.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  30. Samsung Galaxy S21 Screen Replacement: adım 30, 2 resimden 1. Samsung Galaxy S21 Screen Replacement: adım 30, 2 resimden 2.
    • While you wait for the adhesive to soften, note the following:
    • There’s adhesive securing the screen around the perimeter of the frame.
    • More adhesive surrounds the front camera and will require inserting an opening pick further to slice through it.
    • There’s more adhesive right above the fingerprint sensor.
    • Some adhesive may stick to the screen after removal depending on how you slice with a plastic card.
  31. Samsung Galaxy S21 Screen Replacement, Insert an opening pick: adım 31, 3 resimden 1. Samsung Galaxy S21 Screen Replacement, Insert an opening pick: adım 31, 3 resimden 2. Samsung Galaxy S21 Screen Replacement, Insert an opening pick: adım 31, 3 resimden 3.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Slide the opening pick to the top left corner of the screen to slice its adhesive.
    • Only use the tip of the opening pick (4–5 mm) during this procedure to avoid tangling with the in-display fingerprint cable or accidentally tearing it.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  32. Samsung Galaxy S21 Screen Replacement, Slice the adhesive: adım 32, 3 resimden 1. Samsung Galaxy S21 Screen Replacement, Slice the adhesive: adım 32, 3 resimden 2. Samsung Galaxy S21 Screen Replacement, Slice the adhesive: adım 32, 3 resimden 3.
    • Insert a second opening pick at the top left corner and slide it to the bottom left corner of the screen to slice the adhesive.
  33. Samsung Galaxy S21 Screen Replacement: adım 33, 3 resimden 1. Samsung Galaxy S21 Screen Replacement: adım 33, 3 resimden 2. Samsung Galaxy S21 Screen Replacement: adım 33, 3 resimden 3.
    • When you slice near the front facing camera, insert only the tip of the opening pick (2–3 mm) to avoid damaging or smearing the camera.
    • Insert a third opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
  34. Samsung Galaxy S21 Screen Replacement: adım 34, 3 resimden 1. Samsung Galaxy S21 Screen Replacement: adım 34, 3 resimden 2. Samsung Galaxy S21 Screen Replacement: adım 34, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1–2 minutes to reheat it.
    • Insert a fourth opening pick underneath the top-right corner of the screen.
    • Slide the opening pick along the right edge of the screen to slice the adhesive.
  35. Samsung Galaxy S21 Screen Replacement: adım 35, 2 resimden 1. Samsung Galaxy S21 Screen Replacement: adım 35, 2 resimden 2.
    • Insert a fifth opening pick at the bottom right corner of the screen.
    • Slide the opening pick along the bottom edge to slice the remaining adhesive.
    • Do not try to remove the display all the way yet. The display is still adhered to the midframe by adhesive underneath the center of the screen.
  36. Samsung Galaxy S21 Screen Replacement, Insert a plastic card: adım 36, 3 resimden 1. Samsung Galaxy S21 Screen Replacement, Insert a plastic card: adım 36, 3 resimden 2. Samsung Galaxy S21 Screen Replacement, Insert a plastic card: adım 36, 3 resimden 3.
    Plastic Cards
    $2.99
    Satın Al
    • The Galaxy S21 has adhesive underneath the center of the screen that needs to be cut before removing the frame.
    • Insert a plastic card into the gap between the frame and the display at a long edge of the phone.
    • Use the plastic card to slice the adhesive underneath the screen.
  37. Samsung Galaxy S21 Screen Replacement, Remove the screen: adım 37, 3 resimden 1. Samsung Galaxy S21 Screen Replacement, Remove the screen: adım 37, 3 resimden 2. Samsung Galaxy S21 Screen Replacement, Remove the screen: adım 37, 3 resimden 3.
    • Remove the screen.
    • Compare your new replacement part to the original part—you may need to transfer remaining components from your old screen to your replacement part.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, follow this guide in case you're using a precut adhesive card.
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
After you've completed the repair, follow this guide to test your repair.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
7 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
129.318 İtibar
600 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.077 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 74
Son 7 gün: 431
Son 30 gün: 1,877
Her zaman: 36,033
