Ana içeriğe geç
Samsung Galaxy S21 Ultra Screen Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S21 Ultra Screen Replacement, Heat the back cover: adım 1, 1 resimden 1.
    • Unplug and power off your phone before you begin.
    • Prepare an iOpener and apply it to the back cover for at least three minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S21 Ultra Screen Replacement, Insert an opening pick: adım 2, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Insert an opening pick: adım 2, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement, Insert an opening pick: adım 2, 3 resimden 3.
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Samsung Galaxy S21 Ultra Screen Replacement, Slice the adhesive: adım 3, 2 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Slice the adhesive: adım 3, 2 resimden 2.
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Samsung Galaxy S21 Ultra Screen Replacement: adım 4, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement: adım 4, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement: adım 4, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the right edge of your phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  5. Samsung Galaxy S21 Ultra Screen Replacement: adım 5, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement: adım 5, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement: adım 5, 3 resimden 3.
    • When you slice near the camera assembly, insert only the tip of the opening pick (~ 4-5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick underneath the top right corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy S21 Ultra Screen Replacement: adım 6, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement: adım 6, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement: adım 6, 3 resimden 3.
    • Insert a fifth opening pick underneath the top left corner.
    • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
    • When you slice near the power button, insert only the tip of the opening pick (~ 3-4 mm) to avoid damaging the power and volume button flex cable.
  7. Samsung Galaxy S21 Ultra Screen Replacement, Remove the back cover: adım 7, 2 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Remove the back cover: adım 7, 2 resimden 2.
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers.
    • Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  8. Samsung Galaxy S21 Ultra Screen Replacement, Slice the adhesive: adım 8, 2 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Slice the adhesive: adım 8, 2 resimden 2.
    • Insert an opening pick underneath the left bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom left edge of the assembly to separate it from the battery.
  9. Samsung Galaxy S21 Ultra Screen Replacement: adım 9, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement: adım 9, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement: adım 9, 3 resimden 3.
    • Insert an opening pick underneath the bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom of the assembly to separate it from the loudspeaker.
  10. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the charging coil: adım 10, 2 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the charging coil: adım 10, 2 resimden 2.
    • Use a spudger to disconnect the charging coil by prying the connector straight up from its socket.
  11. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the NFC antenna: adım 11, 2 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the NFC antenna: adım 11, 2 resimden 2.
    • Use a spudger to disconnect the NFC antenna by prying the connector straight up from its socket.
  12. Samsung Galaxy S21 Ultra Screen Replacement, Unfasten the NFC antenna & charging coil assembly screws: adım 12, 1 resimden 1.
    • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the NFC antenna and charging coil assembly.
  13. Samsung Galaxy S21 Ultra Screen Replacement, Remove the NFC antenna & charging coil assembly: adım 13, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Remove the NFC antenna & charging coil assembly: adım 13, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement, Remove the NFC antenna & charging coil assembly: adım 13, 3 resimden 3.
    • Use a pair of tweezers or your fingers to carefully remove the NFC antenna and charging coil assembly.
  14. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the battery cable: adım 14, 2 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the battery cable: adım 14, 2 resimden 2.
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  15. Samsung Galaxy S21 Ultra Screen Replacement, Unfasten the loudspeaker assembly screws: adım 15, 1 resimden 1.
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the loudspeaker assembly.
  16. Samsung Galaxy S21 Ultra Screen Replacement, Pry up the loudspeaker assembly: adım 16, 2 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Pry up the loudspeaker assembly: adım 16, 2 resimden 2.
    • Insert a spudger into the gap between the top edge of the loudspeaker assembly and the midframe.
    • Use your spudger to pry up the loudspeaker assembly by tilting it downwards.
  17. Samsung Galaxy S21 Ultra Screen Replacement, Remove the loudspeaker assembly: adım 17, 2 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Remove the loudspeaker assembly: adım 17, 2 resimden 2.
    • Remove the loudspeaker assembly.
    • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
  18. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the display flex cable: adım 18, 2 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the display flex cable: adım 18, 2 resimden 2.
    • If you're not planning to remove the motherboard or to replace the battery, you can skip this step and continue with the next one.
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
  19. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the main & interconnect flex cables: adım 19, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the main & interconnect flex cables: adım 19, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the main & interconnect flex cables: adım 19, 3 resimden 3.
    • Use a spudger to disconnect the main and interconnect flex cables from the motherboard by prying their upper connectors straight up from their sockets.
  20. Samsung Galaxy S21 Ultra Screen Replacement, Remove the interconnect flex cable: adım 20, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Remove the interconnect flex cable: adım 20, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement, Remove the interconnect flex cable: adım 20, 3 resimden 3.
    • Use a spudger to disconnect the interconnect flex cable from the daughterboard by prying its bottom connector straight up from its socket.
    • Use your fingers or a pair of tweezers to carefully remove the interconnect flex cable.
  21. Samsung Galaxy S21 Ultra Screen Replacement, Remove the main flex cable: adım 21, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Remove the main flex cable: adım 21, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement, Remove the main flex cable: adım 21, 3 resimden 3.
    • Use a spudger to disconnect the main flex cable from the daughterboard by prying its bottom connector straight up from its socket.
    • Use your fingers or a pair of tweezers to carefully remove the main flex cable.
  22. Samsung Galaxy S21 Ultra Screen Replacement, Unfasten the earpiece and laser AF module assembly screws: adım 22, 1 resimden 1.
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the earpiece speaker and laser AF module assembly.
  23. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the laser AF module and earpiece speaker  flex cable: adım 23, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the laser AF module and earpiece speaker  flex cable: adım 23, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the laser AF module and earpiece speaker  flex cable: adım 23, 3 resimden 3.
    • Use a spudger to disconnect the laser AF module and earpiece speaker flex cables by prying the connectors straight up from their socket.
  24. Samsung Galaxy S21 Ultra Screen Replacement, Remove the earpiece speaker and laser AF module assembly: adım 24, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Remove the earpiece speaker and laser AF module assembly: adım 24, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement, Remove the earpiece speaker and laser AF module assembly: adım 24, 3 resimden 3.
    • Grab the bottom right corner of the earpiece speaker and laser AF module assembly with a pair of blunt nose tweezers and carefully lift it upwards.
    • Remove the earpiece speaker and laser AF module assembly.
  25. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the in-display fingerprint and  antenna flex cables: adım 25, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the in-display fingerprint and  antenna flex cables: adım 25, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the in-display fingerprint and  antenna flex cables: adım 25, 3 resimden 3.
    • Use a spudger to disconnect the in-display fingerprint and antenna flex cables by prying the connectors straight up from their socket.
    • Carefully bend both connectors to the side to free the motherboard.
    • Do not fold the cables sharply and only bend them to avoid cable damage.
  26. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the front facing camera: adım 26, 2 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the front facing camera: adım 26, 2 resimden 2.
    • Use a spudger to disconnect the front facing camera cable by prying the connector straight up from its socket.
  27. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the power button flex cable: adım 27, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the power button flex cable: adım 27, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement, Disconnect the power button flex cable: adım 27, 3 resimden 3.
    • Use a spudger to disconnect the power button flex cable by prying the connector straight up from its socket.
    • Carefully bend the connector to the side to free the motherboard.
  28. Samsung Galaxy S21 Ultra Screen Replacement, Unfasten the camera module screw: adım 28, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 3.9 mm-long screw securing the camera module.
  29. Samsung Galaxy S21 Ultra Screen Replacement, Pry up the motherboard: adım 29, 2 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Pry up the motherboard: adım 29, 2 resimden 2.
    • Avoid damaging the flex cables surrounding the motherboard during the following procedure.
    • Insert an spudger underneath the top edge of the motherboard next to the vibration motor.
    • Use your spudger to pry up the motherboard by tilting it downwards and twisting it to the side at the same time.
  30. Samsung Galaxy S21 Ultra Screen Replacement, Remove the motherboard: adım 30, 2 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Remove the motherboard: adım 30, 2 resimden 2.
    • Carefully remove the motherboard.
    • Avoid any abrupt movements during the removal and make sure none of the flex cables are entangled in the motherboard to avoid tearing them.
  31. Samsung Galaxy S21 Ultra Screen Replacement, Loosen the display adhesive: adım 31, 1 resimden 1.
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 5 minutes.
    • The display adhesive of the Galaxy S21 Ultra is extremely strong, and it's likely you need to reheat and reapply the iOpener several times before starting the display removal and during the removal procedure.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  32. Samsung Galaxy S21 Ultra Screen Replacement, Insert an opening pick: adım 32, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Insert an opening pick: adım 32, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement, Insert an opening pick: adım 32, 3 resimden 3.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the midframe and the screen.
    • Slide the opening pick to the top left corner of the screen to slice its adhesive.
    • Only use the tip of the opening pick (~4-5 mm) during this procedure to avoid tangling with the in-display fingerprint cable or accidentally tearing it.
  33. Samsung Galaxy S21 Ultra Screen Replacement, Slice the adhesive: adım 33, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Slice the adhesive: adım 33, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement, Slice the adhesive: adım 33, 3 resimden 3.
    • Insert a second opening pick at the top left corner and slide it to the bottom left corner of the screen to slice the adhesive.
  34. Samsung Galaxy S21 Ultra Screen Replacement: adım 34, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement: adım 34, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement: adım 34, 3 resimden 3.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2-3 mm) to avoid damaging or smearing the camera.
    • Insert a third opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
  35. Samsung Galaxy S21 Ultra Screen Replacement: adım 35, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement: adım 35, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement: adım 35, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • Insert a fourth opening pick underneath the top right corner of the screen.
    • Slide the opening pick along the right edge of the screen to slice the adhesive.
  36. Samsung Galaxy S21 Ultra Screen Replacement: adım 36, 2 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement: adım 36, 2 resimden 2.
    • Insert a fifth opening pick at the bottom right corner of the screen.
    • Slide the opening pick along the bottom edge to slice the remaining adhesive.
    • Do not try to remove the display all the way yet. The display and fingerprint cable are still threaded through the frame.
  37. Samsung Galaxy S21 Ultra Screen Replacement, Free the fingerprint cable: adım 37, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Free the fingerprint cable: adım 37, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement, Free the fingerprint cable: adım 37, 3 resimden 3.
    • Carefully thread the fingerprint flex cable through the gap in the midframe.
  38. Samsung Galaxy S21 Ultra Screen Replacement, Remove the screen: adım 38, 3 resimden 1. Samsung Galaxy S21 Ultra Screen Replacement, Remove the screen: adım 38, 3 resimden 2. Samsung Galaxy S21 Ultra Screen Replacement, Remove the screen: adım 38, 3 resimden 3.
    • Thread the display flex cable through the gap in the midframe and remove the screen.
    • Compare your new replacement part to the original part—you may need to transfer remaining components from your old screen to your replacement part.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, follow this guide in case you're using a pre-cut adhesive card.
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After you've completed the repair, follow this guide to test your repair.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
17 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
203.353 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 89
Son 7 gün: 662
Son 30 gün: 2,680
Her zaman: 95,538
