Ana içeriğe geç
Samsung Galaxy Tab 2 7.0 Digitizer Replacement
Wesley Burson
Wesley Burson ve 5 diğer katkıda bulunanlar
En son February 23, 2018 tarihinde güncellendi
1 saat
Orta
Devam Ediyor
Topluluk-Katkılı Kılavuz
  1. Samsung Galaxy Tab 2 7.0 Digitizer Replacement, Digitizer: adım 1, 3 resimden 1. Samsung Galaxy Tab 2 7.0 Digitizer Replacement, Digitizer: adım 1, 3 resimden 2. Samsung Galaxy Tab 2 7.0 Digitizer Replacement, Digitizer: adım 1, 3 resimden 3.
    • Carefully start at the bottom of the tab prying the rear casing.
    • Be careful prying, if you apply too much pressure you can crush the back.
  2. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 2, 2 resimden 1. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 2, 2 resimden 2.
    • Lift the back plate away from the tab.
  3. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 3, 3 resimden 1. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 3, 3 resimden 2. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 3, 3 resimden 3.
    • disconnect the battery by prying from underneath where the wires attach.
    • be careful prying. if you pry the connector you may rip it from the board.
    What's after step 3?
    Stephen Knight - Yanıt
    The guide is incomplete
    iPhone Rebel Repair - Yanıt
    its now finished
    Wesley Burson -
  4. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 4, 2 resimden 1. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 4, 2 resimden 2.
    • Remove the 6 screws holding in the battery]
    • Then the battery should lift out
  5. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 5, 1 resimden 1.
    • Next we will be disconnecting the cables shown in red
  6. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 6, 2 resimden 1. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 6, 2 resimden 2.
    • the speaker connectors will be first.
    • Use a plastic opening tool to pop the connector off
    • repeat this for the other connectors show on previous step
  7. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 7, 2 resimden 1. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 7, 2 resimden 2.
    • remove the screws holding the speakers in.
  8. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 8, 2 resimden 1. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 8, 2 resimden 2.
    • lift both speakers out.
  9. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 9, 1 resimden 1.
    • remove the motherboard screws as shown
    A circle is wrong, meaning the one in the high-left showed in photo. If you don't have some experience, you can get confused, otherwise it wont matter.
    Nico Soranno - Yanıt
  10. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 10, 3 resimden 1. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 10, 3 resimden 2. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 10, 3 resimden 3.
    • lift the motherboard out of the device
  11. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 11, 3 resimden 1. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 11, 3 resimden 2. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 11, 3 resimden 3.
    • flip it over and heat the glass using a heat gun, and insert your plastic opening tool.
    • slowly work your way around the device reheating as needed.
    • make sure the tool does not go too far into the device as it can break the lcd.
    • When heating, don't use too much heat as you can burn the lcd.
  12. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 12, 2 resimden 1. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 12, 2 resimden 2.
    • after filling it with a world share of plastic tools, lift the screen off.
  13. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 13, 2 resimden 1. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 13, 2 resimden 2.
    • feed the connector out of the frame.
  14. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 14, 2 resimden 1. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 14, 2 resimden 2.
    • remove the old adhesive.
    • and clean the glass off the lcd
  15. Samsung Galaxy Tab 2 7.0 Digitizer Replacement: adım 15, 1 resimden 1.
    • reapply adhesive and feed the cable in the frame.
    • Then do the whole guide in reverse minus the prying.
Sonuç
27 farklı kişi bu kılavuzu tamamladı.
Wesley Burson
2.278 İtibar
1 Kılavuz yazıldı
Ekip
iRefresh Phones iRefresh Phones üyesi
Business
1 Üye
1 Kılavuz yazıldı
5 Yorum
Hello! :)
Today I have replaced my screen following your guide and a YouTube video. They were both helpful :)
Just a warning, when you are taking off the old screen, trying to separate it from the glue, be careful not to insert the plastic tools too deep into the space between screen and glass, because you may damage the first one.
Good luck everyone! :D
Fil - Yanıt
Can't see why it's necessary to remove the battery or motherboard. Why can't you heat the digitizer off, since there's access to the cable?
If the correct amount of heat is applied, why is this all necessary?
DNATECH LONDON - Yanıt
The reason I recommend removing it is to help prevent the battery and motherboard from being accidentally heated. I know that if you do it just right there will be no heat applied to them but I'd rather be safe than sorry!
Wesley Burson -
I done this but new screen is not bonding well what are your recommendations
Elizabeth Mochrie - Yanıt
I replaced the digitizer and battery on my son's tablet. Now the network card is hardly able to pick up a signal. I have read that some people replace the antenna, but I can't see how that would help as it is such a simple design.
David Johnson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 22
Her zaman: 23,974
