Ana içeriğe geç
Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Heat the bottom edge: adım 1, 1 resimden 1.
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device for three minutes to loosen the adhesive underneath.
    • The display adhesive of the Galaxy Tab S7+ is extremely strong, and it's likely you need to reheat and reapply the iOpener several times before starting the display removal and during the removal procedure.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Screen removal information: adım 2, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Screen removal information: adım 2, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Screen removal information: adım 2, 3 resimden 3.
    • While you're waiting for the adhesive to loosen, note the following:
    • There's a long circuit board attached to the screen that sits parallel to the bottom edge.
    • Don't insert the pick more than 2 mm to avoid damaging the circuit board.
    • This image shows an example of a damaged display separating from the glass panel.
    • Don't insert the pick more than 3 mm to avoid damaging the display.
  3. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Insert an opening pick: adım 3, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Insert an opening pick: adım 3, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Insert an opening pick: adım 3, 3 resimden 3.
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the bottom adhesive: adım 4, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the bottom adhesive: adım 4, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the bottom adhesive: adım 4, 3 resimden 3.
    • Insert a new opening pick into the gap you created.
    • Slide the new pick along the bottom edge of the device towards the bottom-right corner.
  5. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Heat the right edge: adım 5, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the device for two minutes to loosen the adhesive underneath.
  6. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the bottom-right corner adhesive: adım 6, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the bottom-right corner adhesive: adım 6, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the bottom-right corner adhesive: adım 6, 3 resimden 3.
    • Rotate the opening pick around the bottom-right corner of the device.
  7. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the right edge: adım 7, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the right edge: adım 7, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the right edge: adım 7, 3 resimden 3.
    • Insert a new opening pick into the gap you created at the bottom right corner.
    • Don't insert the pick more than 3 mm to avoid damaging the components along the right edge.
    • Slide the new pick along the right edge of the device towards the top-right corner.
  8. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Heat the top edge: adım 8, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the device for two minutes to loosen the adhesive underneath.
  9. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the top-right corner adhesive: adım 9, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the top-right corner adhesive: adım 9, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the top-right corner adhesive: adım 9, 3 resimden 3.
    • Rotate the opening pick around the top-right corner of the device.
  10. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the top adhesive: adım 10, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the top adhesive: adım 10, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the top adhesive: adım 10, 3 resimden 3.
    • Slide the new pick along the top edge of the device towards the top-left corner.
  11. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Heat the left edge: adım 11, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the device to loosen the adhesive underneath.
  12. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the top-left corner adhesive: adım 12, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the top-left corner adhesive: adım 12, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the top-left corner adhesive: adım 12, 3 resimden 3.
    • Rotate the opening pick around the top-left corner of the device.
  13. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the left adhesive: adım 13, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the left adhesive: adım 13, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the left adhesive: adım 13, 3 resimden 3.
    • Slide the new pick along the left edge of the device towards the bottom-left corner.
  14. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the bottom-left corner adhesive: adım 14, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the bottom-left corner adhesive: adım 14, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the bottom-left corner adhesive: adım 14, 3 resimden 3.
    • Rotate the opening pick around the bottom-left corner of the device.
    • At this point, the perimeter of the screen should be separated from the frame. If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
  15. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the screen: adım 15, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the screen: adım 15, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the screen: adım 15, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Don't try to remove the screen all the way yet; it's still connected by a flex cable.
    • With the top of the device facing you, lift the bottom edge of the screen up and away from you like you're opening a book.
    • Rest the screen upside down before continuing.
    • Be careful not to strain the flex cable.
    • During reassembly:
    • This is a good point to power on your tablet and test all functions before sealing it up. Be sure to power your tablet back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide. If you're using double-sided tape, follow this guide.
  16. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the display cable: adım 16, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the display cable: adım 16, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector from the back of the screen.
    • Be careful not to damage the wide display flex ribbons on the bottom edge of the screen.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 17, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 17, 2 resimden 2.
    • Use tweezers, or your fingers, to hold the display cable in place.
    • Use the flat end of a spudger to pry up and disconnect the fingerprint sensor's press connector attached to the display cable.
    • Take note of the display cable's position—you'll need to bend it in the same way when connecting a new screen.
  18. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the screen: adım 18, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the screen: adım 18, 2 resimden 2.
    • Remove the screen from the frame.
  19. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Unfasten the frame bracket: adım 19, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Unfasten the frame bracket: adım 19, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Unfasten the frame bracket: adım 19, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the fifty 3 mm-long screws securing the frame bracket to the frame.
    • The third photo has the same screws marked by quadrant. Use this photo during reassembly to help account for all the screws:
    • Bottom-left = 9 screws
    • Bottom-right = 14 screws
    • Top-right = 12 screws
    • Top-left = 15 screws
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3229.
  20. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the frame bracket: adım 20, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the frame bracket: adım 20, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the frame bracket: adım 20, 3 resimden 3.
    • Lift the frame bracket away from the frame, making sure to thread the display cable through its slot.
  21. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the battery: adım 21, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the battery: adım 21, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the battery's press connector from the motherboard.
  22. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the daughterboard interconnect cable: adım 22, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the daughterboard interconnect cable: adım 22, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the daughterboard interconnect cable's press connector from the motherboard.
  23. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Unfasten the charging daughterboard: adım 23, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Unfasten the charging daughterboard: adım 23, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two 2 mm screws securing the charging daughterboard to the frame.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3298.
  24. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Reposition the charging daughterboard: adım 24, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Reposition the charging daughterboard: adım 24, 2 resimden 2.
    • Insert a spudger between the charging daughterboard and the frame.
    • Pry up with the spudger to release the clips securing the charging daughterboard.
  25. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 25, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 25, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 25, 3 resimden 3.
    • Use your fingers to pull the charging daughterboard from its slot in the frame.
    • Turn the charging board upside down, making sure not to twist the coaxial cables too far.
  26. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the interconnect cable: adım 26, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the interconnect cable: adım 26, 2 resimden 2.
    Satın Al
    • Use the flat end of a spudger to pry up and disconnect the interconnect cable's press connector secured to the charging daughterboard.
    • Use tweezers, or your fingers, to remove the interconnect cable.
    • Set the cable aside. You'll reuse it during reassembly.
  27. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the coaxial cables: adım 27, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the coaxial cables: adım 27, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the coaxial cables: adım 27, 3 resimden 3.
    • Use the point of a spudger to carefully pry up and disconnect the brown and green coaxial cable from the bottom of the daughterboard.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  28. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 28, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 28, 2 resimden 2.
    • Use the point of a spudger to carefully pry up and disconnect the white coaxial cable from the top of the daughterboard.
  29. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the charging daughterboard: adım 29, 1 resimden 1.
    • Remove the daughterboard from the frame.
    • During reassembly, reconnect the interconnect cable to the daughterboard before fastening the screws.
  30. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the display cable: adım 30, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the display cable: adım 30, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the display cable: adım 30, 3 resimden 3.
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector secured to the motherboard.
    • Repeat for the fingerprint sensor cable attached to display cable.
  31. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the display cable: adım 31, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the display cable: adım 31, 2 resimden 2.
    • Use your fingers to remove the display cable.
  32. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the keyboard dock port cable: adım 32, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the keyboard dock port cable: adım 32, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the keyboard dock port cable's press connector secured to the motherboard.
  33. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the front camera: adım 33, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the front camera: adım 33, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the front camera: adım 33, 3 resimden 3.
    Satın Al
    • Use the flat end of a spudger to pry up and disconnect the front camera's press connector secured to the motherboard.
    • Use tweezers, or your fingers, to remove the front camera.
  34. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the microSD card reader: adım 34, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the microSD card reader: adım 34, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the microSD card reader's press connector secured to the motherboard.
  35. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the left coaxial cables: adım 35, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the left coaxial cables: adım 35, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the left coaxial cables: adım 35, 3 resimden 3.
    • Use the point of a spudger to carefully pry up and disconnect the green coaxial cable from the left side of the motherboard.
    • Repeat this process for the brown coaxial cable.
  36. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the 5G mmWave antenna: adım 36, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the 5G mmWave antenna: adım 36, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the 5G mmWave antenna's press connector secured to the motherboard.
  37. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the 5G mmWave antenna: adım 37, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the 5G mmWave antenna: adım 37, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the 5G mmWave antenna: adım 37, 3 resimden 3.
    • Use tweezers to pull the antenna out of the frame by its bracket.
    • Remove the 5G mmWave antenna.
    • Set the antenna aside. You'll reuse it during reassembly.
  38. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the rear camera: adım 38, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the rear camera: adım 38, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the rear camera: adım 38, 3 resimden 3.
    • Use the flat end of a spudger to pry up and disconnect the rear camera's two press connectors secured to the motherboard.
  39. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the power button cable: adım 39, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the power button cable: adım 39, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the power button cable's press connector secured to the motherboard.
  40. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the bottom-right coaxial cable: adım 40, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the bottom-right coaxial cable: adım 40, 2 resimden 2.
    • Use the point of a spudger to carefully pry up and disconnect the bottom-right loudspeaker's yellow coaxial cable from the motherboard.
    • Take care not to puncture the battery with your tool—a punctured battery may leak dangerous chemicals or cause a fire.
  41. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Reposition the bottom-right coaxial cable: adım 41, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Reposition the bottom-right coaxial cable: adım 41, 2 resimden 2.
    • Pull the coaxial cable away from the frame, making sure the cable is completely unthreaded from the motherboard.
  42. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the interconnect cable: adım 42, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the interconnect cable: adım 42, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the interconnect cable's press connector secured to the motherboard.
  43. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the top-right coaxial cables: adım 43, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the top-right coaxial cables: adım 43, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Disconnect the top-right coaxial cables: adım 43, 3 resimden 3.
    • Use the point of a spudger to carefully pry up and disconnect the top-right loudspeaker's blue coaxial cable from the motherboard.
    • Repeat this process for the white coaxial cable.
  44. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Unfasten the motherboard: adım 44, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Unfasten the motherboard: adım 44, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the three 2 mm screws securing the motherboard to the frame.
  45. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the motherboard: adım 45, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the motherboard: adım 45, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the motherboard: adım 45, 3 resimden 3.
    • Insert a spudger into a gap between the motherboard and the frame.
    • Pry up with the spudger to release the motherboard from its clips.
    • Remove the motherboard.
    • During reassembly, refasten the motherboard screws first to properly align it into place, then reconnect the cables.
  46. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Unfasten the antenna board: adım 46, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Unfasten the antenna board: adım 46, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the 2 mm-long screw securing the antenna board to the frame.
  47. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the antenna board: adım 47, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the antenna board: adım 47, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the antenna board: adım 47, 3 resimden 3.
    • Insert a spudger into a gap between the antenna board and the frame.
    • Pry up with the spudger to separate the antenna board from the frame.
    • Remove the antenna board.
  48. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Heat the keyboard dock port cable: adım 48, 1 resimden 1.
    • The keyboard dock port cable is lightly adhered to the frame.
    • Apply a heated iOpener to the top of the device for 90 seconds.
  49. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the keyboard dock cable adhesive: adım 49, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the keyboard dock cable adhesive: adım 49, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the keyboard dock cable adhesive: adım 49, 3 resimden 3.
    • Insert the tip of an opening pick between the frame and the keyboard dock port cable's metal bracket.
    • Rotate the pick while prying up to separate the adhesive.
  50. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the keyboard dock port cable: adım 50, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the keyboard dock port cable: adım 50, 2 resimden 2.
    Satın Al
    • Use tweezers, or your fingers, to pull the keyboard dock port cable directly out of its slot.
    • Remove the keyboard dock port cable.
  51. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Heat the left edge: adım 51, 1 resimden 1.
    • The bottom-left loudspeaker's flex cable is secured to the frame by adhesive. Use heat to avoid tearing the connector.
    • Apply a heated iOpener to the left edge of the device for two minutes.
  52. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the connector's adhesive: adım 52, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the connector's adhesive: adım 52, 2 resimden 2.
    • Insert an opening pick between the bottom-left loudspeaker's copper connector pads and the frame.
    • Pry up while slicing the adhesive to separate the pad from the frame.
  53. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 53, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 53, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 53, 3 resimden 3.
    • Slice with the opening pick along the bottom of the connector's cable to completely separate it from the frame.
  54. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Reposition the coaxial cables: adım 54, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Reposition the coaxial cables: adım 54, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Reposition the coaxial cables: adım 54, 3 resimden 3.
    • Use your fingers to unroute the blue and white coaxial cables from their groove in the frame.
  55. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the loudspeaker: adım 55, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the loudspeaker: adım 55, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the loudspeaker: adım 55, 3 resimden 3.
    • Use a spudger to pry up and separate the loudspeaker from the frame.
    • Remove the loudspeaker.
    • Set the speaker aside. You'll reuse it during reassembly.
    • During reassembly, rethread the blue coaxial cable after slotting the bottom-left speaker into your new frame.
  56. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the top-left loudspeaker cable's adhesive: adım 56, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the top-left loudspeaker cable's adhesive: adım 56, 2 resimden 2.
    • Insert an opening pick between the top-left loudspeaker cable and the frame.
    • Slice the adhesive while prying up with the pick to separate the cable from the frame.
  57. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the top-left loudspeaker: adım 57, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the top-left loudspeaker: adım 57, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the top-left loudspeaker: adım 57, 3 resimden 3.
    • Use a spudger to pry up and separate the top-left loudspeaker from the frame.
    • Remove the top-left loudspeaker.
  58. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Heat the rear camera: adım 58, 1 resimden 1.
    • The rear camera is secured to the frame by adhesive. Use heat to avoid damaging the camera.
    • Apply a heated iOpener to the top-left corner of the device for two minutes.
  59. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the rear camera's adhesive: adım 59, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the rear camera's adhesive: adım 59, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the rear camera's adhesive: adım 59, 3 resimden 3.
    • Insert an opening pick into a gap between the rear camera and the frame.
    • Rotate the pick around edges of the rear camera to slice the adhesive.
  60. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the rear camera: adım 60, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the rear camera: adım 60, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the rear camera: adım 60, 3 resimden 3.
    • Pry up with the pick to separate the rear camera from the frame.
    • Remove the rear camera.
    • Set the camera aside. You'll reuse it during reassembly.
  61. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 61, 1 resimden 1.
    • The top-right loudspeaker's connector is secured to the frame by adhesive. Use heat to avoid tearing the connector.
    • Apply a heated iOpener to the right edge of the device for two minutes.
  62. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate loudspeaker cable's adhesive: adım 62, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate loudspeaker cable's adhesive: adım 62, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate loudspeaker cable's adhesive: adım 62, 3 resimden 3.
    • Insert an opening pick between the loudspeaker's connector pads and the frame.
    • Slice the adhesive while prying up with the pick to separate the pads from the frame.
  63. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the loudspeaker: adım 63, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the loudspeaker: adım 63, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the loudspeaker: adım 63, 3 resimden 3.
    • During reassembly, rethread the green and brown coaxial cables after slotting the top-right speaker into your new frame.
  64. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the bottom-right loudspeaker cable's adhesive: adım 64, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the bottom-right loudspeaker cable's adhesive: adım 64, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the bottom-right loudspeaker cable's adhesive: adım 64, 3 resimden 3.
    • Insert an opening pick between the bottom-right loudspeaker cable and the frame.
  65. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Reposition the coaxial cable: adım 65, 2 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Reposition the coaxial cable: adım 65, 2 resimden 2.
    • Use your fingers to unroute the white coaxial cable from its groove in the frame.
    • You will need to transfer and rethread the white coaxial cable into your new frame.
  66. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the bottom-right loudspeaker: adım 66, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the bottom-right loudspeaker: adım 66, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the bottom-right loudspeaker: adım 66, 3 resimden 3.
    • Use a spudger to pry up and separate the bottom-right loudspeaker from the frame.
    • Remove the bottom-right loudspeaker.
    • During reassembly, rethread the white coaxial cable after slotting the bottom-right speaker into your new frame.
  67. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the microSD card reader's adhesive: adım 67, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the microSD card reader's adhesive: adım 67, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Separate the microSD card reader's adhesive: adım 67, 3 resimden 3.
    • Insert a pick between the microSD reader's connector pads and the frame.
    • Pry up while slicing the adhesive to separate the pads from the frame.
  68. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 68, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 68, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 68, 3 resimden 3.
    • Insert a pick between the bottom-right peg hole and the frame.
    • Rotate the pick along the peg hole's perimeter to separate it from the frame.
  69. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 69, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 69, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement: adım 69, 3 resimden 3.
    • Insert a pick between the top of the microSD reader and the frame.
    • Rotate the pick around the perimeter of the microSD reader to slice the adhesive.
  70. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the microSD card reader: adım 70, 3 resimden 1. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the microSD card reader: adım 70, 3 resimden 2. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Remove the microSD card reader: adım 70, 3 resimden 3.
    • At this point, the perimeter of the microSD card reader should be separated from the frame. If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
    • Insert an opening pick between the bottom-left peg hole and the frame.
    • Pry up with the pick to separate the microSD card reader from the frame.
    • Remove the microSD card reader.
    • Set the microSD card reader aside. You'll reuse it during reassembly.
  71. Samsung Galaxy Tab S7+ 5G Battery and Frame Assembly Replacement, Only the battery and frame assembly remains: adım 71, 1 resimden 1.
    • You're now left with the battery and frame assembly.
Sonuç
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
After you've completed the repair, download the Samsung Members App from the Galaxy Store or the Play Store, and follow the Samsung Self-Repair document (beginning page 10) to make sure your device is fully functional.
Download the Self Repair Assistant on your device and follow the Samsung Self-Repair document (beginning page 11) to perform a battery cycle reset.
Bir başkası bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
124.510 İtibar
581 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
17.288 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 43
Her zaman: 1,798
