Ana içeriğe geç
Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Heat the bottom edge: adım 1, 1 resimden 1.
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device for three minutes to loosen the adhesive underneath.
    • The display adhesive of the Galaxy Tab S7+ is extremely strong, and it's likely you need to reheat and reapply the iOpener several times before starting the display removal and during the removal procedure.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Screen removal information: adım 2, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Screen removal information: adım 2, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Screen removal information: adım 2, 3 resimden 3.
    • While you're waiting for the adhesive to loosen, note the following:
    • There's a long circuit board attached to the screen that sits parallel to the bottom edge.
    • Don't insert the pick more than 2 mm to avoid damaging the circuit board.
    • This image shows an example of a damaged display separating from the glass panel.
    • Don't insert the pick more than 3 mm to avoid damaging the display.
  3. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Insert an opening pick: adım 3, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Insert an opening pick: adım 3, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Insert an opening pick: adım 3, 3 resimden 3.
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the bottom adhesive: adım 4, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the bottom adhesive: adım 4, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the bottom adhesive: adım 4, 3 resimden 3.
    • Insert a new opening pick into the gap you created.
    • Slide the new pick along the bottom edge of the device towards the bottom-right corner.
  5. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Heat the right edge: adım 5, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the device for two minutes to loosen the adhesive underneath.
  6. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the bottom-right corner adhesive: adım 6, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the bottom-right corner adhesive: adım 6, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the bottom-right corner adhesive: adım 6, 3 resimden 3.
    • Rotate the opening pick around the bottom-right corner of the device.
  7. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the right edge: adım 7, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the right edge: adım 7, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the right edge: adım 7, 3 resimden 3.
    • Insert a new opening pick into the gap you created at the bottom right corner.
    • Don't insert the pick more than 3 mm to avoid damaging the components along the right edge.
    • Slide the new pick along the right edge of the device towards the top-right corner.
  8. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Heat the top edge: adım 8, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the device for two minutes to loosen the adhesive underneath.
  9. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the top-right corner adhesive: adım 9, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the top-right corner adhesive: adım 9, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the top-right corner adhesive: adım 9, 3 resimden 3.
    • Rotate the opening pick around the top-right corner of the device.
  10. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the top adhesive: adım 10, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the top adhesive: adım 10, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the top adhesive: adım 10, 3 resimden 3.
    • Slide the new pick along the top edge of the device towards the top-left corner.
  11. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Heat the left edge: adım 11, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the device to loosen the adhesive underneath.
  12. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the top-left corner adhesive: adım 12, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the top-left corner adhesive: adım 12, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the top-left corner adhesive: adım 12, 3 resimden 3.
    • Rotate the opening pick around the top-left corner of the device.
  13. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the left adhesive: adım 13, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the left adhesive: adım 13, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the left adhesive: adım 13, 3 resimden 3.
    • Slide the new pick along the left edge of the device towards the bottom-left corner.
  14. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the bottom-left corner adhesive: adım 14, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the bottom-left corner adhesive: adım 14, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the bottom-left corner adhesive: adım 14, 3 resimden 3.
    • Rotate the opening pick around the bottom-left corner of the device.
    • At this point, the perimeter of the screen should be separated from the frame. If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
  15. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the screen: adım 15, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the screen: adım 15, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the screen: adım 15, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Don't try to remove the screen all the way yet; it's still connected by a flex cable.
    • With the top of the device facing you, lift the bottom edge of the screen up and away from you like you're opening a book.
    • Rest the screen upside down before continuing.
    • Be careful not to strain the flex cable.
    • During reassembly:
    • This is a good point to power on your tablet and test all functions before sealing it up. Be sure to power your tablet back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide. If you're using double-sided tape, follow this guide.
  16. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the display cable: adım 16, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the display cable: adım 16, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector from the back of the screen.
    • Be careful not to damage the wide display flex ribbons on the bottom edge of the screen.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement: adım 17, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement: adım 17, 2 resimden 2.
    • Use tweezers, or your fingers, to hold the display cable in place.
    • Use the flat end of a spudger to pry up and disconnect the fingerprint sensor's press connector attached to the display cable.
    • Take note of the display cable's position—you'll need to bend it in the same way when connecting a new screen.
  18. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the screen: adım 18, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the screen: adım 18, 2 resimden 2.
    • Remove the screen from the frame.
  19. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Unfasten the frame bracket: adım 19, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Unfasten the frame bracket: adım 19, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Unfasten the frame bracket: adım 19, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the fifty 3 mm-long screws securing the frame bracket to the frame.
    • The third photo has the same screws marked by quadrant. Use this photo during reassembly to help account for all the screws:
    • Bottom-left = 9 screws
    • Bottom-right = 14 screws
    • Top-right = 12 screws
    • Top-left = 15 screws
  20. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the frame bracket: adım 20, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the frame bracket: adım 20, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the frame bracket: adım 20, 3 resimden 3.
    • Lift the frame bracket away from the frame, making sure to thread the display cable through its socket.
  21. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the battery: adım 21, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the battery: adım 21, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the battery's press connector secured to the motherboard.
  22. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the display cable: adım 22, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the display cable: adım 22, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the display cable: adım 22, 3 resimden 3.
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector secured to the motherboard.
    • Repeat for the fingerprint sensor cable attached to display cable.
  23. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the display cable: adım 23, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the display cable: adım 23, 2 resimden 2.
    • Use your fingers to remove the display cable.
  24. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the daughterboard interconnect cable: adım 24, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the daughterboard interconnect cable: adım 24, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the daughterboard interconnect cable's press connector secured to the motherboard.
  25. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the keyboard dock port cable: adım 25, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the keyboard dock port cable: adım 25, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the keyboard dock port cable's press connector secured to the motherboard.
  26. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the front camera: adım 26, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the front camera: adım 26, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the front camera: adım 26, 3 resimden 3.
    Satın Al
    • Use the flat end of a spudger to pry up and disconnect the front camera's press connector secured to the motherboard.
    • Use tweezers, or your fingers, to remove the front camera.
  27. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the microSD card reader: adım 27, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the microSD card reader: adım 27, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the microSD card reader's press connector secured to the motherboard.
  28. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the 5G antenna: adım 28, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the 5G antenna: adım 28, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the 5G antenna's press connector secured to the motherboard.
  29. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the 5G antenna: adım 29, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the 5G antenna: adım 29, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the 5G antenna: adım 29, 3 resimden 3.
    • Use tweezers to pull the antenna out of the frame by its bracket.
    • Remove the 5G antenna.
  30. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the left coaxial cables: adım 30, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the left coaxial cables: adım 30, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the left coaxial cables: adım 30, 3 resimden 3.
    • Use the point of a spudger to carefully pry up and disconnect the green coaxial cable from the left side of the motherboard.
    • Repeat this process for the red coaxial cable.
  31. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the rear camera: adım 31, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the rear camera: adım 31, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the rear camera: adım 31, 3 resimden 3.
    • Use the flat end of a spudger to pry up and disconnect the rear camera's two press connectors secured to the motherboard.
  32. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the power button cable: adım 32, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the power button cable: adım 32, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the power button cable's press connector secured to the motherboard.
  33. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the bottom-right coaxial cable: adım 33, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the bottom-right coaxial cable: adım 33, 2 resimden 2.
    • Use the point of a spudger to carefully pry up and disconnect the bottom-right loudspeaker's yellow coaxial cable from the motherboard.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  34. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Reposition the bottom-right coaxial cable: adım 34, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Reposition the bottom-right coaxial cable: adım 34, 2 resimden 2.
    • Pull the coaxial cable away from the frame, making sure the cable is completely unthreaded from the motherboard.
  35. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the interconnect cable: adım 35, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the interconnect cable: adım 35, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the interconnect cable's press connector secured to the motherboard.
  36. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the top-right coaxial cables: adım 36, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the top-right coaxial cables: adım 36, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the top-right coaxial cables: adım 36, 3 resimden 3.
    • Use the point of a spudger to carefully pry up and disconnect the top-right loudspeaker's blue coaxial cable from the motherboard.
    • Repeat this process for the white coaxial cable.
  37. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Unfasten the motherboard: adım 37, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Unfasten the motherboard: adım 37, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the three 2 mm screws securing the motherboard to the frame.
  38. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the motherboard: adım 38, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the motherboard: adım 38, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the motherboard: adım 38, 3 resimden 3.
    • Insert a spudger into a gap between the motherboard and the frame.
    • Pry up with the spudger to release the motherboard from its clips.
    • Remove the motherboard.
    • During reassembly, refasten the motherboard screws first to properly align it into place, then reconnect the cables.
  39. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Speaker assembly information: adım 39, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Speaker assembly information: adım 39, 2 resimden 2.
  40. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Reposition the bottom-left coaxial cable: adım 40, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Reposition the bottom-left coaxial cable: adım 40, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Reposition the bottom-left coaxial cable: adım 40, 3 resimden 3.
    • Pull the bottom-left coaxial cables away from the frame, making sure the cables are completely unthreaded from the frame.
  41. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the antenna board's interconnect cable: adım 41, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the antenna board's interconnect cable: adım 41, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the antenna board's interconnect cable: adım 41, 3 resimden 3.
    Satın Al
    • Use the flat end of a spudger to pry up and disconnect the antenna board's interconnect cable secured to the antenna board.
    • Use tweezers, or your fingers, to remove the cable.
  42. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Unfasten the antenna board: adım 42, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Unfasten the antenna board: adım 42, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the 2 mm screw securing the antenna board to the frame.
  43. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the antenna board: adım 43, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the antenna board: adım 43, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the antenna board: adım 43, 3 resimden 3.
    • Insert a spudger into a gap between the antenna board and the frame.
    • Pry up with the spudger to separate the antenna board from the frame.
    • Remove the antenna board.
  44. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Heat the left edge: adım 44, 1 resimden 1.
    • The bottom-left loudspeaker's connector is secured to the frame by adhesive; use heat to avoid tearing the connector.
    • Apply a heated iOpener to the left edge of the device for two minutes.
  45. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the connector's adhesive: adım 45, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the connector's adhesive: adım 45, 2 resimden 2.
    • Insert an opening pick between the bottom-left loudspeaker's copper connector pads and the frame.
    • Pry up while slicing the adhesive to separate the pad from the frame.
  46. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement: adım 46, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement: adım 46, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement: adım 46, 3 resimden 3.
    • Slice with the opening pick along the bottom of the connector's cable to completely separate it from the frame.
  47. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the loudspeaker: adım 47, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the loudspeaker: adım 47, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the loudspeaker: adım 47, 3 resimden 3.
    • Use a spudger to pry up and separate the loudspeaker from the frame.
    • Remove the loudspeaker.
  48. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Heat the left edge: adım 48, 1 resimden 1.
    • The top-left loudspeaker's connector is secured to the frame by adhesive; use heat to avoid tearing the connector.
  49. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the loudspeaker cable's adhesive: adım 49, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the loudspeaker cable's adhesive: adım 49, 2 resimden 2.
    • Insert an opening pick between the loudspeaker cable and the frame.
    • Slice the adhesive while prying up with the pick to separate the cable from the frame.
  50. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the loudspeaker: adım 50, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the loudspeaker: adım 50, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the loudspeaker: adım 50, 3 resimden 3.
  51. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Unfasten the charging daughterboard: adım 51, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Unfasten the charging daughterboard: adım 51, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two 2 mm screws securing the charging daughterboard to the frame.
  52. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Reposition the charging daughterboard: adım 52, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Reposition the charging daughterboard: adım 52, 2 resimden 2.
    • Insert a spudger between the charging daughterboard and the frame.
    • Pry up with the spudger to release the clips securing the charging daughterboard.
  53. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement: adım 53, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement: adım 53, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement: adım 53, 3 resimden 3.
    • Use your fingers to pull the charging daughterboard from its slot in the frame.
    • Turn the charging board upside down, making sure not to twist the coaxial cables too far.
  54. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the interconnect cable: adım 54, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the interconnect cable: adım 54, 2 resimden 2.
    Satın Al
    • Use the flat end of a spudger to pry up and disconnect the interconnect cable's press connector secured to the charging daughterboard.
    • Use tweezers, or your fingers, to remove the interconnect cable.
  55. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the coaxial cables: adım 55, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the coaxial cables: adım 55, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Disconnect the coaxial cables: adım 55, 3 resimden 3.
    • Use the point of a spudger to carefully pry up and disconnect the red and green coaxial cable from the bottom of the daughterboard.
  56. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement: adım 56, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement: adım 56, 2 resimden 2.
    • Use the point of a spudger to carefully pry up and disconnect the white coaxial cable from the top of the daughterboard.
  57. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the charging daughterboard: adım 57, 2 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the charging daughterboard: adım 57, 2 resimden 2.
    • Remove the daughterboard from the frame.
    • During reassembly, refasten the charging daughterboard screws first to properly align it into place, then reconnect the interconnect cable.
  58. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Heat the right edge: adım 58, 1 resimden 1.
    • The top-right loudspeaker's connector is secured to the frame by adhesive; use heat to avoid tearing the connector.
  59. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate loudspeaker cable's adhesive: adım 59, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate loudspeaker cable's adhesive: adım 59, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate loudspeaker cable's adhesive: adım 59, 3 resimden 3.
    • Insert an opening pick between the loudspeaker's copper connector pads and the frame.
    • Slice the adhesive while prying up with the pick to separate the pads from the frame.
  60. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the loudspeaker: adım 60, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the loudspeaker: adım 60, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the loudspeaker: adım 60, 3 resimden 3.
  61. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Heat the right edge: adım 61, 1 resimden 1.
    • The bottom-right loudspeaker's connector is secured to the frame by adhesive; use heat to avoid tearing the connector.
    • Apply a heated iOpener to the right edge of the device for two minutes.
  62. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the loudspeaker cable's adhesive: adım 62, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the loudspeaker cable's adhesive: adım 62, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Separate the loudspeaker cable's adhesive: adım 62, 3 resimden 3.
  63. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the loudspeaker: adım 63, 3 resimden 1. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the loudspeaker: adım 63, 3 resimden 2. Samsung Galaxy Tab S7 Plus Loudspeaker Assembly Replacement, Remove the loudspeaker: adım 63, 3 resimden 3.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Tab S7+ Answers community for help.
Alex Diaz-Kokaisl
125.280 İtibar
582 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
137 Üyeler
17.457 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 132
