Ana içeriğe geç
Samsung Galaxy Watch3 Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Watch3 Battery Replacement, Unfasten the back cover screws: adım 1, 1 resimden 1.
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
    I heeded your advice - and now need another screw because it fell out!!!
    Paul - Yanıt
    I must have stripped the screws out or either the dirt and sweat is so packed into the screw i can't get a good bite to unscrew the screws. What can I do about this? This watch battery DOES NOT hold a charge for more than 5min, should I trash the watch?
    ShaneWizdum - Yanıt
  2. Samsung Galaxy Watch3 Battery Replacement, Wedge open the back cover: adım 2, 2 resimden 1. Samsung Galaxy Watch3 Battery Replacement, Wedge open the back cover: adım 2, 2 resimden 2.
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
    Could not get the back housing off
    Joseph Ortiz, Jr - Yanıt
  3. Samsung Galaxy Watch3 Battery Replacement, Disconnect the sensor flex cable: adım 3, 3 resimden 1. Samsung Galaxy Watch3 Battery Replacement, Disconnect the sensor flex cable: adım 3, 3 resimden 2. Samsung Galaxy Watch3 Battery Replacement, Disconnect the sensor flex cable: adım 3, 3 resimden 3.
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  4. Samsung Galaxy Watch3 Battery Replacement, Remove the back cover: adım 4, 2 resimden 1. Samsung Galaxy Watch3 Battery Replacement, Remove the back cover: adım 4, 2 resimden 2.
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
    Where would one get a new rubber water gasket if the old one is damaged by this process?
    Jack Popham - Yanıt
    I need also the Rubber Sealing. Anyone got a replacement part?
    Steffen Politzky -
    Me too, I'm tired of searching for one, they don't exist.
    Karl Roberts - Yanıt
    If anyone has the red ringed gasket in the photo please share a link to buy or part code to search for etc. I am constantly drawing a blank no matter what key words I search. It's utterly crushing not to have this part easily available.
  5. Samsung Galaxy Watch3 Battery Replacement, Unplug the three connectors: adım 5, 3 resimden 1. Samsung Galaxy Watch3 Battery Replacement, Unplug the three connectors: adım 5, 3 resimden 2. Samsung Galaxy Watch3 Battery Replacement, Unplug the three connectors: adım 5, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the flex cables of the side buttons, the display and the hall sensor.
  6. Samsung Galaxy Watch3 Battery Replacement, Unfasten the motherboard screw: adım 6, 1 resimden 1.
    • Remove the Phillips #00 screw.
  7. Samsung Galaxy Watch3 Battery Replacement, Remove the motherboard: adım 7, 2 resimden 1. Samsung Galaxy Watch3 Battery Replacement, Remove the motherboard: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • The motherboard is held in place by two small plastic clips.
    • Use a pair of blunt tweezers to lift the motherboard out from underneath the plastic clips towards the buttons.
    • Remove the motherboard.
    Question, I had a demo Watch3. I tried to swap out the software and ended up putting it into Odem Mode. It’s bricked right now, any idea or help to fix it?
    Lucas Economy - Yanıt
  8. Samsung Galaxy Watch3 Battery Replacement, Lever up the battery: adım 8, 3 resimden 1. Samsung Galaxy Watch3 Battery Replacement, Lever up the battery: adım 8, 3 resimden 2. Samsung Galaxy Watch3 Battery Replacement, Lever up the battery: adım 8, 3 resimden 3.
    • Place the flat end of a supdger in the small gap between the plastic frame and the battery, opposite to the display cable.
    • Carefully lever the battery up and out of its recess.
    • The battery is adhered to the core with light adhesive, so take your time.
    • Don't try to remove the battery completely yet, as its connector is still adhered to the core.
  9. Samsung Galaxy Watch3 Battery Replacement, Remove the battery: adım 9, 2 resimden 1. Samsung Galaxy Watch3 Battery Replacement, Remove the battery: adım 9, 2 resimden 2.
    Tesa 61395 Tape
    $5.99
    • Lift the battery up a little in order to access its glued down connector cable.
    • Use a pair of blunt tweezers to lift up the battery connector which is secured with some light adhesive.
    • You will most likely be able to re-use the adhesive to fix the new battery in place. If not replace it with double sided or pre-cut adhesive tape.
    • Remove the battery.
    Herzlichen Dank für die hervorragende Anleitung. Ich habe mich genau daran gehalten und es hat problemlos geklappt.
    Wichtig ist: guten Schraubendreher Y00 verwenden, nicht die billigen kleinen Plastik Schraubendreher die oft beim Akku dabei sind.
    Andreas Herber - Yanıt
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
21 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
124.408 İtibar
189 adet Kılavuz yazıldı
Ekip
18Kılavuz Yorumları
Once I had the correct tools and replacement battery, fixing was easy. Tyvm!
Jeremy Salazar - Yanıt
One question, where can I find an authorized battery for this watch? or one that you highly recommend. Thanks.
**Edit - Your store doesn’t have a 45mm battery for my Galaxy Watch 3. Only 42 and 46.
Gilberto Garcia - Yanıt
The 42 and 46 mm models are the first Galaxy Watch sizes. We ’re working on getting the Watch3 batteries and parts but it may take some time.
Tobias Isakeit -
Hi, is it possible to put the battery from samsung watch 472mAh, on samsung watch 3, instead of 340mAh?
Andrey Irnazarov - Yanıt
Hi Andrey, short answer is no—although basically a good idea. But even if you cut the battery contact plate to fit (cut off the part with the alignment hole) its polarity is inverted. The Watch3 contact plate has -/+ (noted under the cable) whereas the original has +/-. Also the original Galaxy Watch battery is much bigger than the one in the Watch3. So it won’t fit inside the recess. Here is an image with the Watch3 battery on top of the original battery.
Tobias Isakeit -
Hi Tobias, thanks for the reply, I don't think the pins are a problem, the wire can be turned over and the tab with the hole, cut off. the pins will be pressed by the motherboard. I'm more interested in the size of the 472mAl battery and the inside of the battery compartment of the Watch 3?
Also I wonder if it would be a problem if the battery has a 472mAl, 1.27Wh and the 340mAl, 1.8Wh ?
Unfortunately, I don't have the opportunity to measure and test it myself.
Thanks.
Here’s a photo for you with some measurements. I’m afraid you won’t be able to fit the bigger Watch1 battery inside the Watch3 frame
Tobias Isakeit -
Great instructions which were easy to follow. Side note is I was doing the battery replacement on the 41mm instead of the 45mm (did not find one specifically for the 41mm version) and the battery it uses is the same one in Samsung Galaxy Watch Active2 40mm (EB-BR830ABY). Just in case anyone else was wondering.
Bradley Avery - Yanıt
Do you mean that the battery EB-BR840ABY for the 45mm is compatible with the EB-BR830ABY for the 41mm. So I could put the 840 in my 41mm?
R.J.G. Beerten -
Are there batteries for the smr850 yet??
scott park - Yanıt
It is nice that they give instructions on how to remove the battery with the right tools it can be accomplished. However reassembly should be addressed for people who have never done this before. I had difficulty making the last connection on to the motherboard with the connector that is attached to the back cover. I tried using my dominant hand several times to no avail. Apparently you need your dominant hand to hold the cover steady while you use your fingers from your non-dominant hand to press down to connector. My Water Seal adhered to the watch and I had to carefully reuse a spudger to remove it and then reshape it so it would fit back onto the back cover. And then during reassembly I had to carefully make sure that that part of the water seal was carefully in place before screwing the the cover down.
Coy D Davis - Yanıt
Tienen la batería disponible para el modelo de Samsung watch 3 de 41mm modelo de la batería: EB-BR830ABY
rodrichucho rodrichucho - Yanıt
Is the battery EB-BR840ABY for the 45mm is compatible with the EB-BR830ABY for the 41mm. So I could put the 840 in my 41mm?
R.J.G. Beerten - Yanıt
I guess what Bradley was saying is, that the battery from the Active 2 (40mm) is the same battery used in the Watch 3 (41mm).
You very likely can NOT use the battery from the Galaxy Watch 3 (44mm) in the smaller Galaxy Watch 3 (41mm) model.
Tobias Isakeit -
The Galaxy 3 has two variants - a 41mm case, and a 45mm case. The batteries are different. The basic steps for disassembly and battery replacement are the same for both, but make sure you get the correct battery. The size is shown on the case, in small print. Please don't assume you have a 45mm case based on these instructions.
JohnG - Yanıt
Bought the appropriate toolkit, changed the battery in less than 10 minutes, tbh, the hardest part was reconnecting the flex sensor. £40 spent and watch is now good as new, saving £350 over a new one.
Marcus Waldock - Yanıt
That’s how it is supposed to be. Repair over buying a new device. Congrats and enjoy your new old watch.
Tobias Isakeit -
Awesome guide, thank you.
I thought I'd have to take it to a repair shop to get it replaced but the guide with the pictures was easy enough to follow.
Flex sensor was the trickiest part but not toouch hassle in the end
Russell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 160
Son 30 gün: 849
Her zaman: 42,077
