Ana içeriğe geç
Samsung NX Mini LCD Replacement
Kelsea Weber
Kelsea Weber ve başka bir katkıda bulunan
En son March 18, 2016 tarihinde güncellendi
Tahmin yok
Orta
Is your LCD stuck in place, cracked or unresponsive? Use this guide to remove the LCD assembly and make necessary repairs.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Samsung NX Mini LCD Replacement, Battery: adım 1, 3 resimden 1. Samsung NX Mini LCD Replacement, Battery: adım 1, 3 resimden 2. Samsung NX Mini LCD Replacement, Battery: adım 1, 3 resimden 3.
    • Orient the camera so the button panel and LCD are facing you.
    • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
  2. Samsung NX Mini LCD Replacement: adım 2, 2 resimden 1. Samsung NX Mini LCD Replacement: adım 2, 2 resimden 2.
    • Push the blue trapdoor to the left to release the battery, and remove the battery.
    • There is no battery shown in this photo.
  3. Samsung NX Mini LCD Replacement, Front Case: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
  4. Samsung NX Mini LCD Replacement: adım 4, 1 resimden 1.
    • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
  5. Samsung NX Mini LCD Replacement: adım 5, 1 resimden 1.
    • Remove the four 5 mm Phillips #00 screws from the lens assembly.
  6. Samsung NX Mini LCD Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the metal lens mount by hand or with tweezers.
    • Be careful not to touch the sensor in the center of the lens assembly.
  7. Samsung NX Mini LCD Replacement: adım 7, 1 resimden 1.
    • Use tweezers to remove the inner metal ring.
  8. Samsung NX Mini LCD Replacement: adım 8, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
  9. Samsung NX Mini LCD Replacement: adım 9, 2 resimden 1. Samsung NX Mini LCD Replacement: adım 9, 2 resimden 2.
    • Use your hands to slowly pull the front casing away from the camera.
    • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
  10. Samsung NX Mini LCD Replacement, Sensor: adım 10, 3 resimden 1. Samsung NX Mini LCD Replacement, Sensor: adım 10, 3 resimden 2. Samsung NX Mini LCD Replacement, Sensor: adım 10, 3 resimden 3.
    • Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
    • Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
    • Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
    • The gold lens contacts lying beneath the ribbon cable become loose when the screw and contact cover are removed.
  11. Samsung NX Mini LCD Replacement: adım 11, 2 resimden 1. Samsung NX Mini LCD Replacement: adım 11, 2 resimden 2.
    • Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
  12. Samsung NX Mini LCD Replacement: adım 12, 3 resimden 1. Samsung NX Mini LCD Replacement: adım 12, 3 resimden 2. Samsung NX Mini LCD Replacement: adım 12, 3 resimden 3.
    • Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
    • Remove the battery compartment.
  13. Samsung NX Mini LCD Replacement: adım 13, 2 resimden 1. Samsung NX Mini LCD Replacement: adım 13, 2 resimden 2.
    • Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
  14. Samsung NX Mini LCD Replacement: adım 14, 1 resimden 1.
    • Gently remove the sensor mount from the camera case.
  15. Samsung NX Mini LCD Replacement, Flash Assembly: adım 15, 3 resimden 1. Samsung NX Mini LCD Replacement, Flash Assembly: adım 15, 3 resimden 2. Samsung NX Mini LCD Replacement, Flash Assembly: adım 15, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws holding the flash assembly to the camera case.
  16. Samsung NX Mini LCD Replacement: adım 16, 2 resimden 1. Samsung NX Mini LCD Replacement: adım 16, 2 resimden 2.
    • Remove the flash assembly by gently pulling it away from the case.
    • You may need to use a spudger to release some of the clips holding the assembly in place.
    • Avoid touching the ends of the capacitor (the large black cylinder on the right). Capacitors that haven't been discharged may cause electric shock. Learn how to discharge a capacitor here.
  17. Samsung NX Mini LCD Replacement, LCD: adım 17, 1 resimden 1.
    • Remove the 5 mm Phillips #00 screw in the top right corner of the LCD assembly.
  18. Samsung NX Mini LCD Replacement: adım 18, 2 resimden 1. Samsung NX Mini LCD Replacement: adım 18, 2 resimden 2.
    • Tilt and wiggle the LCD to remove it from the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kelsea Weber
20.616 İtibar
32 adet Kılavuz yazıldı
Ekip
iFixit, Team S1-G1, Weber Summer 2018 iFixit, Team S1-G1, Weber Summer 2018 üyesi
FIX-WEBER-SU18S1G1
5 Üyeler
43 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 580
