Samsung YP-P3 Buttons Replacement
Neye ihtiyacın var
Pry up the small black piece of plastic located between the volume [-] button and the HOLD/ON button.
Before removing the circuit board, we must remove the ribbon-like wires attached to two sides of the circuit board.
There are two screws (Phillips #000, 2.0 mm long) holding in the circuit board. Use a Phillips #000 screwdriver to take out those screws.
The battery is also attached to the circuit board by a cable. The cable is difficult to disconnect with both components in place. It's best to lift the circuit board out partially to give yourself more room to disconnect the connector.
The wire that is connected to the circuit board is connected by a plastic piece with two metal prongs.
Use the pointy end of the spudger to place in between the computer board and the plastic piece and gently pry the prongs away from the circuit board.
Use the spudger to carefully pry up the battery. The battery is attached with a few spots of glue, so it may not move at first.
Remove the six screws (Phillips #000, 2.3 mm long) holding the screen frame to the front of the case. As the picture shows, one of them is hidden under the black speaker/rumble assembly.
The buttons, built-in speaker, and rumble device are all contained in a black plastic assembly. This assembly simply snaps into place at the top of the case. Lift up gently to remove it from its place.
1Rehber Yorum
This is terrific, but who makes a 3”, 272x480 pixel lcd screen and/or touchpanel for the samsung? Is this the same screen hardware as on the P2?
