Ana içeriğe geç
Sony Cyber-shot DSC-H20 Screen Replacement
Rachel Payne
Rachel Payne ve 3 diğer katkıda bulunanlar
En son January 10, 2021 tarihinde güncellendi
Tahmin yok
Orta
Yanlış Araçlar
Dilim ve Zar
Daha iyi giriş
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-H20 Screen Replacement, Screen: adım 1, 2 resimden 1. Sony Cyber-shot DSC-H20 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Slide open the battery cover and remove the battery and the Memory Stick Duo.
    • Return the battery cover to its closed position.
  2. Sony Cyber-shot DSC-H20 Screen Replacement: adım 2, 1 resimden 1.
    • Remove all three screws from the bottom of the camera.
  3. Sony Cyber-shot DSC-H20 Screen Replacement: adım 3, 2 resimden 1. Sony Cyber-shot DSC-H20 Screen Replacement: adım 3, 2 resimden 2.
    • Remove the screws on the left and right sides of the camera.
  4. Sony Cyber-shot DSC-H20 Screen Replacement: adım 4, 3 resimden 1. Sony Cyber-shot DSC-H20 Screen Replacement: adım 4, 3 resimden 2. Sony Cyber-shot DSC-H20 Screen Replacement: adım 4, 3 resimden 3.
    • Press down on the flash cover to raise the flash.
    • Remove both screws that hold the flash cover to the body of the camera.
  5. Sony Cyber-shot DSC-H20 Screen Replacement: adım 5, 1 resimden 1.
    • Place the camera upside down with the battery port positioned upward.
    • Slide open the battery port.
  6. Sony Cyber-shot DSC-H20 Screen Replacement: adım 6, 3 resimden 1. Sony Cyber-shot DSC-H20 Screen Replacement: adım 6, 3 resimden 2. Sony Cyber-shot DSC-H20 Screen Replacement: adım 6, 3 resimden 3.
    • Pry the front cover of the camera off with the plastic opening tool.
  7. Sony Cyber-shot DSC-H20 Screen Replacement: adım 7, 1 resimden 1.
    • Remove the power shutter unit.
  8. Sony Cyber-shot DSC-H20 Screen Replacement: adım 8, 2 resimden 1. Sony Cyber-shot DSC-H20 Screen Replacement: adım 8, 2 resimden 2.
    • Unscrew the screw located at the back left corner of the flash component.
    • Set the flash component aside.
  9. Sony Cyber-shot DSC-H20 Screen Replacement: adım 9, 1 resimden 1.
    • Remove the two screws from the bottom of the motherboard.
  10. Sony Cyber-shot DSC-H20 Screen Replacement: adım 10, 1 resimden 1.
    • Use the plastic opening tool to assist you in separating the metal frame from the back cover of the camera.
  11. Sony Cyber-shot DSC-H20 Screen Replacement: adım 11, 2 resimden 1. Sony Cyber-shot DSC-H20 Screen Replacement: adım 11, 2 resimden 2.
    • Flip the metal frame over to the left side of the camera and onto the surface on which you are working.
  12. Sony Cyber-shot DSC-H20 Screen Replacement: adım 12, 2 resimden 1. Sony Cyber-shot DSC-H20 Screen Replacement: adım 12, 2 resimden 2.
    • Now remove the LCD screen by bringing the back cover over to the left so that the LCD screen falls into your hand.
    I had a pin fall out, I don’t know where it goes now.
    Lucas Vaughn - Yanıt
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Rachel Payne
416 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Leahy Winter 2015 USF Tampa, Team 1-1, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S1G1
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Thank you so much. I could successfully open the camera and got the LCD display out. But I couldn't find out how to replace the LCD, I wanted to mean where to open the LCD cable?
ummejamil - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 2,206
