Ana içeriğe geç
Sony WH-1000XM5 Battery Replacement
Neye ihtiyacın var
    1. Sony WH-1000XM5 Battery Replacement, Earpads: adım 1, 3 resimden 1. Sony WH-1000XM5 Battery Replacement, Earpads: adım 1, 3 resimden 2. Sony WH-1000XM5 Battery Replacement, Earpads: adım 1, 3 resimden 3.
      Bu adımda kullanılan alet:
      iFixit Opening Tool
      $1.99
      • Place the edge of an iFixit opening tool under the earpad cushion.
      • Slide it alongside the edge of the cushion until it detaches from the rest of the headphones.
      FixBot'a Sor
      Yorum Ekle
    1. Sony WH-1000XM5 Battery Replacement, Battery: adım 2, 2 resimden 1. Sony WH-1000XM5 Battery Replacement, Battery: adım 2, 2 resimden 2.
      Phillips #000 Screwdriver
      $5.49
      • Use a Phillips #000 screwdriver to remove the eight screws along the outer inside edge.
      • There is a piece of grey foam you can simply remove to uncover the centre 4 screws.
      • Flip the headphones to the other side and slowly lift up the back plastic cover piece.
      • Gently disconnect the touch sensor ribbon cable by pulling it out evenly from the main board.
      FixBot'a Sor
      Yorum Ekle
    2. Sony WH-1000XM5 Battery Replacement: adım 3, 3 resimden 1. Sony WH-1000XM5 Battery Replacement: adım 3, 3 resimden 2. Sony WH-1000XM5 Battery Replacement: adım 3, 3 resimden 3.
      • Peel off the tape covering the battery connector.
      • Pull out the battery and disconnect the battery cable from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
4 farklı kişi bu kılavuzu tamamladı.
Miranda
243 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Santin Spring 2024 UMass Dartmouth, Team 1-4, Santin Spring 2024 üyesi
UMASSD-SANTIN-S24S1G4
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Hey folks, thanks for taking the time to layout this procedure. These headphones are amazing, and this really helps me get my friends onboard.
placebomessiah - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 23
Son 7 gün: 184
Son 30 gün: 803
Her zaman: 19,527
