Ana içeriğe geç
Sony Xperia Z1s Battery Replacement
Neye ihtiyacın var
    1. Sony Xperia Z1s Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Insert the opening pick in the crease between the rear cover and the body of the phone.
      • Pry along the edge to lift and remove the back cover.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Xperia Z1s Battery Replacement: adım 2, 1 resimden 1.
      • Using the T4 Torx screwdriver, remove five 5 mm screws from the panel above the battery.
      • Remove the panel by grabbing its bottom edge and lifting upwards.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Xperia Z1s Battery Replacement: adım 3, 1 resimden 1.
      • Use the opening pick to pry off the battery flex cable.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Xperia Z1s Battery Replacement: adım 4, 1 resimden 1.
      • Using the T4 Torx screwdriver, remove two 5 mm screws from the bottom corners of the battery.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Xperia Z1s Battery Replacement: adım 5, 1 resimden 1.
      • Firmly press the suction cup onto the battery.
      • Pull the battery out using the suction handle.
      FixBot'a Sor
      Yorum Ekle
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
Bir başkası bu kılavuzu tamamladı.
Matthew Klengson
324 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 4-4, Hunter Fall 2021 Clemson, Team 4-4, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S4G4
5 Üyeler
35 adet Kılavuz yazıldı
1Rehber Yorum
Step 1 - The gap is too small to simply use the pick. The suction tool also did not provide a big enough gap to get the pick in. In order to get the pick in I had to heat up the back and use the suction cup in order to get the pick. Then moved the pick around the perimeter to pull of the back. The battery was attached to the back with two glue strips. I unpluged the battery ribbon cable and got the glue off using the two pull tabs that were attached to the glue.
The rest of the steps were non existent in my case. Hope this reply helps
MrKoszmaro - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 18
Son 7 gün: 22
Son 30 gün: 47
Her zaman: 703
