Ana içeriğe geç
TI-Nspire CX Battery Replacement
Jim Kerman
Jim Kerman ve 7 diğer katkıda bulunanlar
En son March 10, 2025 tarihinde güncellendi
10 dakika
Kolay
If your TI-Nspire CX calculator isn't powering on after being charged, or appears to need charged more often or for longer than usual, you may need to replace the battery. Use this guide to replace the calculator's internal rechargeable battery.
The rechargeable battery may become damaged or faulty with repeated use and charging cycles. A faulty battery will store less energy or no energy at all.
Step 3 requires you to disconnect and remove the old battery. Before removing the old battery, inspect it for damage such as leaking or appearing puffy. Damaged batteries are a fire hazard. If the battery appears damaged, you must take appropriate precautions.
Before using this guide, be sure to power off the calculator completely.
If the battery appears to be punctured do not use it.
Use an official Texas Instruments battery for optimal performance.
Neye ihtiyacın var
Parçalar
Aletler
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. TI-Nspire CX Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to loosen the captive screws on the back plate of the calculator.
    • The screws do not come all the way out. Simply twist them until you are able to remove the back plate.
  2. TI-Nspire CX Battery Replacement: adım 2, 2 resimden 1. TI-Nspire CX Battery Replacement: adım 2, 2 resimden 2.
    • Remove the back plate using the spudger or by hand.
  3. TI-Nspire CX Battery Replacement: adım 3, 3 resimden 1. TI-Nspire CX Battery Replacement: adım 3, 3 resimden 2. TI-Nspire CX Battery Replacement: adım 3, 3 resimden 3.
    • Carefully disconnect and remove the old battery.
    • Unhook the wire from the tab.
    • Carefully pull out the connector.
    • Grip the wire close to the top and pull away.
  4. TI-Nspire CX Battery Replacement: adım 4, 1 resimden 1.
    • Plug in the new battery.
    • Make sure to put the wire back in the same way. You should see 4 metal connections on top
  5. TI-Nspire CX Battery Replacement: adım 5, 1 resimden 1.
    • Position the new battery and tuck the wire under the tab.
  6. TI-Nspire CX Battery Replacement: adım 6, 1 resimden 1.
    • Replace the back plate and the 2 screws.
Sonuç
Now charge your calculator and power it up. If replacing the battery does not solve your problem, it may be a problem with your charging cord or the internal sockets.
10 farklı kişi bu kılavuzu tamamladı.
Jim Kerman
335 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 24-2, Green Winter 2015 Cal Poly, Team 24-2, Green Winter 2015 üyesi
CPSU-GREEN-W15S24G2
4 Üyeler
4 adet Kılavuz yazıldı
2Kılavuz Yorumları
Hi. I own a TI Nspire CX CAS. I’ve had it for 5 years now and the battery’s been screwy for the past few years. I just ordered a new battery with good reviews from amazon. I’m worried that if I take out the battery my documents and other saved settings will be deleted. Does removing the battery delete anything? I have the modded operating system for my oldschool gameboy games, so I really don’t want to lose my games and settings, as the laptop I used years ago to put the games on there has been broken. I would really appreciate any help. Thank you.
G Reod - Yanıt
Hola Amigo. Pudiste solucionar?
Armando02 -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 91
Her zaman: 17,634
