Teenage Engineering OP-Z Function Key Plastic Buttons Replacement
Giriş
1. adıma gitUse this guide to replace the function key plastic buttons of your OP-Z.
The actual button flex cable is a separate guide/part. Please disassemble and check your device before purchasing any parts.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
Use your fingernail or a spudger to lift the battery on the right side where the notch is.
Use your finger or a spudger to push up on the small tab on the bottom of the module.
Lift the module up and out of its recess bottom first.
Use a spudger to push the first set of function buttons inwards.
