Ana içeriğe geç
Texas Instruments TI-30 XS Multiview Solar Panel Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: adım 1, 2 resimden 1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: adım 1, 2 resimden 2.
    • If the screw is not turning, do not force it. This can strip the screw. See the How to Remove a Stripped Screw guide if the screw is already stripped.
    • Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
    • Use the spudger (or fingernail) to pry into the space between the blue back cover and the white body to take off the back cover.
    FixBot'a Sor
    Yorum Ekle
  2. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the battery compartiment: adım 2, 1 resimden 1.
    • Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
    • Lift the metal plate from the battery and set it to the side.
    FixBot'a Sor
    Yorum Ekle
  3. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Eject the battery: adım 3, 1 resimden 1.
    • Use the spudger (or fingernail) to lift the battery from the black holder.
    FixBot'a Sor
    Yorum Ekle
    • Put the new CR2032 battery in. Never insert a different type of battery!
    • Make sure the positive side of your CR2032 is facing up.
    • Reverse the steps 2 and 1.
    FixBot'a Sor
    Yorum Ekle
  4. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Free the solar panel: adım 5, 1 resimden 1.
    • Use the #00 Phillips screwdriver to remove the one 3mm Phillips screw holding the solar panel in place.
    FixBot'a Sor
    Yorum Ekle
  5. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Carefully pull the panel out: adım 6, 1 resimden 1.
    • Be careful not to pull the solar panel too far out, as the wires connecting it to the calculator are fragile and could be ripped off.
    • Carefully pull the solar panel away from the calculator, as shown to the left.
    FixBot'a Sor
    Yorum Ekle
  6. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Unsolder the wires: adım 7, 1 resimden 1.
    • The capacitor might not be discharged. Proceed with caution.
    • Unsolder the three wires from the motherboard.
    • Unsoldering help can be found here.
    • To re-solder the wires from the new solar panel to the calculator motherboard take notice of the color and placement of the wires.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Aaron Feinstein
401 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 11-2, Forte Fall 2015 Cal Poly, Team 11-2, Forte Fall 2015 üyesi
CPSU-FORTE-F15S11G2
4 Üyeler
9 adet Kılavuz yazıldı
1Rehber Yorum
Do you know where I could get a replacement solar panel for the calculator?
Josh - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 34
Her zaman: 3,031
