Ana içeriğe geç
Texas Instruments TI-30 XS Multiview Solar Panel Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: adım 1, 2 resimden 1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: adım 1, 2 resimden 2.
    • If the screw is not turning, do not force it. This can strip the screw. See the How to Remove a Stripped Screw guide if the screw is already stripped.
    • Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
    • Use the spudger to pry into the space between the blue back cover and the white body to take off the back cover.
  2. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the battery compartiment: adım 2, 1 resimden 1.
    • Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
    • Lift the metal plate from the battery and set it to the side.
  3. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Eject the battery: adım 3, 1 resimden 1.
    • Use the spudger to lift the battery up from the black holder.
    • Put the new CR2032 battery in. Never insert a different type of battery!
    • Reverse the steps 2 and 1.
  4. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Free the solar panel: adım 5, 1 resimden 1.
    • Use the #00 Phillips screwdriver to remove the one 3mm Phillips screw holding the solar panel in place.
  5. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Carefully pull the panel out: adım 6, 1 resimden 1.
    • Be careful not to pull the solar panel too far out, as the wires connecting it to the calculator are fragile and could be ripped off.
    • Carefully pull the solar panel away from the calculator, as shown to the left.
  6. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Unsolder the wires: adım 7, 1 resimden 1.
    • The capacitor might not be discharged. Proceed with caution.
    • Unsolder the three wires from the motherboard.
    • Unsoldering help can be found here.
    • To re-solder the wires from the new solar panel to the calculator motherboard take notice of the color and placement of the wires.
Sonuç
Aaron Feinstein
349 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 11-2, Forte Fall 2015 Cal Poly, Team 11-2, Forte Fall 2015 üyesi
CPSU-FORTE-F15S11G2
4 Üyeler
9 adet Kılavuz yazıldı
1Rehber Yorum
Do you know where I could get a replacement solar panel for the calculator?
Josh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 27
Her zaman: 2,449
