Ana içeriğe geç
Toshiba Satellite C660 CMOS / BIOS Battery Replacement
ZFix
ZFix ve 4 diğer katkıda bulunanlar
En son April 8, 2024 tarihinde güncellendi
5 - 10 dakika
Çok kolay
Topluluk-Katkılı Kılavuz
CMOS / BIOS Battery replacement for Toshiba Satellite C660 with video tutorial:
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
Videoya Genel Bakış
  1. Toshiba Satellite C660 CMOS / BIOS Battery Replacement, CMOS / BIOS Battery replacement: adım 1, 2 resimden 1. Toshiba Satellite C660 CMOS / BIOS Battery Replacement, CMOS / BIOS Battery replacement: adım 1, 2 resimden 2.
    • Disconnect the charger and the battery.
  2. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: adım 2, 3 resimden 1. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: adım 2, 3 resimden 2. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: adım 2, 3 resimden 3.
    • Remov the narrow plastic lid and unscrew 4x Phillips screw.
  3. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: adım 3, 3 resimden 1. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: adım 3, 3 resimden 2. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: adım 3, 3 resimden 3.
    • Remove the keyboard.
  4. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: adım 4, 3 resimden 1. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: adım 4, 3 resimden 2. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: adım 4, 3 resimden 3.
    • This is the internal CMOS / BIOS battery. Use small screwdriver to remove it.
  5. Toshiba Satellite C660 CMOS / BIOS Battery Replacement: adım 5, 1 resimden 1.
    • And that's it!
    Sur mon satellite L555-135, ce n’est pas une CR32, mais une petite pile soudée. Est-elle compatible avec une CR32 ? Il n’y a aucune inscription sur la pile. Merci.
    Pat Bazar - Yanıt
    Oui c'est compatible car les bios nécessitent 3 volts pour rester à jour. Vous pouvez très bien utiliser une pile de 3v plus petite mais elle se déchargera plus rapidement ou plus grosse (mais toujours en 3v) pour peut qu'elle rentre dans l'emplacement prévu par le constructeur.
    Les CR32 sont devenus des standards.
    Hyperion - Yanıt
    Ni siquiera publicaste el tipo de pila que necesitas para recambio, solo las herramientas.
    Bastante inútil
    Marcus Bingham - Yanıt
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
ZFix
194.093 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.700 adet Kılavuz yazıldı
5 Yorum
what battery do i need
allan mccauley - Yanıt
This is a CR2032 battery
Hyperion - Yanıt
The receptacle that the battery goes into is loose and not making contact on the (+) terminal. This is a shoddy design. You can test it by pressing the receptacle down and powering the laptop. Works fine. You cannot solder the terminal for fear of upsetting the motherboard. Any solutions.
Until I find one, I continue to press F1, go to Control Panel and set the time and date every time I power on the laptop.
Hari Razdan - Yanıt
same battery CR2032 for Toshiba sattelite L775 G10 ?
thx
gagalot Eric - Yanıt
Bonjour,
Je ne savais pas où était cette pile dans un Toshiba 650D, et j'hésitais à me lancer dans le démontage de ce portable. J'ai trouvé ce tutoriel qui explique parfaitement la marche à suivre, et j'ai réussi à changer cette pile en deux temps trois mouvements!!
Un grand merci donc.
PS: je n'ai pas débranché le connecteur clavier et n'ai pas eu de problème.
Jean-Marc GERMAIN - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 55
Son 30 gün: 250
Her zaman: 50,644
