Giriş
Removing this piece makes working inside of the computer easier. To replace this part (if it is broken) follow this guide.
Neye ihtiyacın var
There are ten 5mm screws surrounding the edge of the cover.
A rubber cap covers the eleventh 5mm screw (in the center).
Remove the screws using a Phillips #00 screwdriver.
At this point you should be able to:
2 farklı kişi bu kılavuzu tamamladı.
