Giriş
With this guide you will be able to remove both left and right speakers and replace them.
Neye ihtiyacın var
There are ten 5mm screws surrounding the edge of the cover.
A rubber cap covers the eleventh 5mm screw (in the center).
Remove the screws using a Phillips #00 screwdriver.
At this point you should be able to:
Remove the two 5mm screws using a Phillips #00 screwdriver.
Remove the left speaker.
Neredeyse bitti!
Sonuç
