Giriş
If the processor fan stops working, and the system is overheating, Follow this guide to replace it.
Neye ihtiyacın var
There are ten 5mm screws surrounding the edge of the cover.
A rubber cap covers the eleventh 5mm screw (in the center).
Remove the screws using a Phillips #00 screwdriver.
At this point you should be able to:
Bir başkası bu kılavuzu tamamladı.
