Ana içeriğe geç
Toshiba Satellite U840W Processor Fan Replacement.
Neye ihtiyacın var
  1. Toshiba Satellite U840W Processor Fan Replacement., Toshiba Satellite U840W Disassembly Guide: adım 1, 2 resimden 1. Toshiba Satellite U840W Processor Fan Replacement., Toshiba Satellite U840W Disassembly Guide: adım 1, 2 resimden 2.
    • There are ten 5mm screws surrounding the edge of the cover.
    • A rubber cap covers the eleventh 5mm screw (in the center).
    • Remove the screws using a Phillips #00 screwdriver.
  2. Toshiba Satellite U840W Processor Fan Replacement.: adım 2, 3 resimden 1. Toshiba Satellite U840W Processor Fan Replacement.: adım 2, 3 resimden 2. Toshiba Satellite U840W Processor Fan Replacement.: adım 2, 3 resimden 3.
    • Pry between the casing and cover using a plastic wedge tool.
    • Use the wedge tool to move along the case & slowly pry it open.
    • The wire for the 12v charging port connects the cover to the casing.
  3. Toshiba Satellite U840W Processor Fan Replacement.: adım 3, 3 resimden 1. Toshiba Satellite U840W Processor Fan Replacement.: adım 3, 3 resimden 2. Toshiba Satellite U840W Processor Fan Replacement.: adım 3, 3 resimden 3.
    • Disconnect this connector from the motherboard to avoid damaging the motherboard or charging port cable.
  4. Toshiba Satellite U840W Processor Fan Replacement.: adım 4, 1 resimden 1.
    • Disconnect the battery.
    • Hold down the power button for ~10 seconds to discharge any stored electricity from the motherboard.
  5. Toshiba Satellite U840W Processor Fan Replacement., Processor Fan: adım 6, 2 resimden 1. Toshiba Satellite U840W Processor Fan Replacement., Processor Fan: adım 6, 2 resimden 2.
    • Remove the three 3mm screws using a Phillips #00 screwdriver.
  6. Toshiba Satellite U840W Processor Fan Replacement.: adım 7, 2 resimden 1. Toshiba Satellite U840W Processor Fan Replacement.: adım 7, 2 resimden 2.
    • A plastic prying tool can be used to help you remove the fan.
    • Plastic wire guides hold the wire in place. Manipulate the wire out from these guides.
  7. Toshiba Satellite U840W Processor Fan Replacement.: adım 8, 2 resimden 1. Toshiba Satellite U840W Processor Fan Replacement.: adım 8, 2 resimden 2.
    • Remove the connector from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tony Aprile
118 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team S1-G1, Saknee Spring 2019 Gateway, Team S1-G1, Saknee Spring 2019 üyesi
GCC-SAKNEE-S19S1G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 317
