Ana içeriğe geç
Volkswagen Key Fob Battery Replacement
Neye ihtiyacın var
  1. Volkswagen Key Fob Battery Replacement, Identification: adım 1, 1 resimden 1.
    • There are two main key fob models when it comes to repair.
    • If you see this shiny pin it means it’s the easiest of the two.
    • If this is not the case, the other iFixit guides on Volkswagen key fobs deal with the other replacement method.
  2. Volkswagen Key Fob Battery Replacement, Opening: adım 2, 1 resimden 1.
    • Pull from the small plastic square in the direction of the arrow to release the casing.
  3. Volkswagen Key Fob Battery Replacement, Swap the battery: adım 3, 2 resimden 1. Volkswagen Key Fob Battery Replacement, Swap the battery: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Spudger
    $3.99
    • Insert a spudger or a pointed object inside of the marked ledge to help release the battery.
    • Replace the battery and congrats!! You are done.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
carlotremolada
2.541 İtibar
1 Kılavuz yazıldı
Ekip
Cooperators Cooperators üyesi
Community
21 Üyeler
387 adet Kılavuz yazıldı
2Kılavuz Yorumları
very helpful!
drai - Yanıt
It's easy, but I was afraid of doing damage and was about to go to a Volkswagen centre. Very useful guide
Kodama - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 217
Her zaman: 4,300
