Ana içeriğe geç
Volkswagen Key Fob Battery Replacement
carlotremolada
carlotremolada ve başka bir katkıda bulunan
En son January 22, 2024 tarihinde güncellendi
1 dakika
Çok kolay
Topluluk-Katkılı Kılavuz
Volkswagen key fobs come in many different shapes and sizes but there are only two ways to replace their battery. Mine is the easiest of the two. For this you will need no tools, however a spudger might come in handy in dislodging the battery.
Best of luck!
Neye ihtiyacın var
Parçalar
Aletler
  • Spudger
    Spudger
Daha fazlasını göster…
  1. Volkswagen Key Fob Battery Replacement, Identification: adım 1, 1 resimden 1.
    • There are two main key fob models when it comes to repair.
    • If you see this shiny pin it means it’s the easiest of the two.
    • If this is not the case, the other iFixit guides on Volkswagen key fobs deal with the other replacement method.
  2. Volkswagen Key Fob Battery Replacement, Opening: adım 2, 1 resimden 1.
    • Pull from the small plastic square in the direction of the arrow to release the casing.
  3. Volkswagen Key Fob Battery Replacement, Swap the battery: adım 3, 2 resimden 1. Volkswagen Key Fob Battery Replacement, Swap the battery: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Spudger
    $3.99
    • Insert a spudger or a pointed object inside of the marked ledge to help release the battery.
    • Replace the battery and congrats!! You are done.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
carlotremolada
2.541 İtibar
1 Kılavuz yazıldı
Ekip
Cooperators Cooperators üyesi
Community
21 Üyeler
391 adet Kılavuz yazıldı
2Kılavuz Yorumları
very helpful!
drai - Yanıt
It's easy, but I was afraid of doing damage and was about to go to a Volkswagen centre. Very useful guide
Kodama - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 32
Son 30 gün: 152
Her zaman: 4,354
