Ana içeriğe geç
Xiaomi Mi 9 Battery Replacement
Neye ihtiyacın var
  1. Xiaomi Mi 9 Battery Replacement, Rear Glass: adım 1, 1 resimden 1.
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
  2. Xiaomi Mi 9 Battery Replacement: adım 2, 3 resimden 1. Xiaomi Mi 9 Battery Replacement: adım 2, 3 resimden 2. Xiaomi Mi 9 Battery Replacement: adım 2, 3 resimden 3.
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner of the phone.
  3. Xiaomi Mi 9 Battery Replacement: adım 3, 2 resimden 1. Xiaomi Mi 9 Battery Replacement: adım 3, 2 resimden 2.
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Xiaomi Mi 9 Battery Replacement: adım 4, 3 resimden 1. Xiaomi Mi 9 Battery Replacement: adım 4, 3 resimden 2. Xiaomi Mi 9 Battery Replacement: adım 4, 3 resimden 3.
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 9 to cut the adhesive.
    • Be aware of the rear cameras and only insert the tip of the opening pick. As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Mi 9 Battery Replacement: adım 5, 2 resimden 1. Xiaomi Mi 9 Battery Replacement: adım 5, 2 resimden 2.
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Be very careful at this point not to raise the cover too much, at the slightest bending the glass shatters. It just happened to me :(
    enrica_spiga - Yanıt
  6. Xiaomi Mi 9 Battery Replacement: adım 6, 2 resimden 1. Xiaomi Mi 9 Battery Replacement: adım 6, 2 resimden 2.
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right edge to cut the remaining adhesive.
  7. Xiaomi Mi 9 Battery Replacement: adım 7, 2 resimden 1. Xiaomi Mi 9 Battery Replacement: adım 7, 2 resimden 2.
    • Carefully lift the rear glass and remove it.
    • Before installing new adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    Il y a un peu d'adhésif autour de l'appareil photo, c'est pour cela que ça peu forcer un tout petit peu.
    Charles - Yanıt
  8. Xiaomi Mi 9 Battery Replacement, Motherboard Cover with Charging Coil: adım 8, 1 resimden 1.
    • Remove the ten Phillips #00 screws (3 mm length) that secure the motherboard cover.
    • There might be tamper proof sticker on some of the screws.
    Note, the Explorer/Transparent edition does not use phillips #00 screws.
    Jason Baginski - Yanıt
    It uses 0.8mm star screws(P2 Pentalobe in the iFixIt store)
    Jason Baginski -
    Thanks for mentioning Jason!
    Dominik Schnabelrauch -
  9. Xiaomi Mi 9 Battery Replacement: adım 9, 2 resimden 1. Xiaomi Mi 9 Battery Replacement: adım 9, 2 resimden 2.
    • Insert an opening pick at the top right corner of the motherboard cover.
    • Twist the opening pick sideways to pry up and slightly lift the motherboard cover.
  10. Xiaomi Mi 9 Battery Replacement: adım 10, 2 resimden 1. Xiaomi Mi 9 Battery Replacement: adım 10, 2 resimden 2.
    • Carefully remove the motherboard cover including the charging coil / NFC antenna.
  11. Xiaomi Mi 9 Battery Replacement, Battery Disconnect: adım 11, 2 resimden 1. Xiaomi Mi 9 Battery Replacement, Battery Disconnect: adım 11, 2 resimden 2.
    • Use a spudger to pry up and disconnect the battery flex cable.
  12. Xiaomi Mi 9 Battery Replacement, Loudspeaker Unit: adım 12, 1 resimden 1.
    • Remove the seven Phillips #00 screws securing the loudspeaker unit:
    • Four silver 3.2 mm long screws
    • Two yellowish 3.8 mm long screws
    • One black 2.8 mm long screw
    • Some screws may be hidden beneath tamper proof stickers.
    I found that there was no need to remove the loudspeaker assembly at all. The battery adhesive was easy to pull out (by rolling it up on a screwdriver) without needing to remove the loudspeaker.
    Jez S - Yanıt
    I can confirm this. Worked like a charm without taking the loudspeaker assembly out.
    Alexander Niehoff -
    Ich stellte fest, dass es überhaupt nicht nötig war, die Lautsprecherbaugruppe zu entfernen. Der Batteriekleber ließ sich leicht herausziehen (durch Aufrollen mit einem Schraubenzieher), ohne dass der Lautsprecher entfernt werden musste.
    Gegenteilig sogar! Das Antennenkabel löste sich und hat dann außerordentlich viel Zeit gekostet den Stecker zu reparieren!!
    Harald Sanders - Yanıt
  13. Xiaomi Mi 9 Battery Replacement: adım 13, 2 resimden 1. Xiaomi Mi 9 Battery Replacement: adım 13, 2 resimden 2.
    • Slide an opening pick under the right side of the loudspeaker unit.
    • Twist the opening pick sideways to pry up the loudspeaker unit until you can get a good grip.
    • There is still an antenna cable connected to the back of the unit.
  14. Xiaomi Mi 9 Battery Replacement: adım 14, 2 resimden 1. Xiaomi Mi 9 Battery Replacement: adım 14, 2 resimden 2.
    • Carefully lift the loudspeaker unit and hinge it open towards the left side.
  15. Xiaomi Mi 9 Battery Replacement: adım 15, 2 resimden 1. Xiaomi Mi 9 Battery Replacement: adım 15, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to pry off and disconnect the antenna cable from the loudspeaker unit.
    • Remove the loudspeaker unit.
    • Before reassembly check your old loudspeaker for components that might need to be transferred to the replacement part such as the antenna flex cable with its coax connector.
  16. Xiaomi Mi 9 Battery Replacement, Battery: adım 16, 3 resimden 1. Xiaomi Mi 9 Battery Replacement, Battery: adım 16, 3 resimden 2. Xiaomi Mi 9 Battery Replacement, Battery: adım 16, 3 resimden 3.
    • Use a pair of tweezers to peel the black ends of the adhesive tabs off the battery.
  17. Xiaomi Mi 9 Battery Replacement: adım 17, 2 resimden 1. Xiaomi Mi 9 Battery Replacement: adım 17, 2 resimden 2.
    Plastic Cards
    $2.99
    • Use a pair of tweezers to pull out the left adhesive tab from underneath the battery.
    • The adhesive tab underneath the battery can rip very easily. Make sure you pull out the tab in a slow and steady motion and in a flat angle. To prevent the adhesive tab from ripping, it's helpfull to twist the strip around the tweezers.
    • In case one of the adhesive tabs rips and it‘s not possible to pull it out completely, you can use isopropyl alcohol or an heated iOpener to loosen the adhesive. After the adhesive is soft enough use a prying tool such as an opening pick or a plastic card to pry out the battery.
    Be careful with this one. My fully charged battery catch fire.
    I tried to forcefully remove the battery after ripping the adhesive tab. I was bending it a lot.
    It started to burn and smoke a lot. I didnt get any burn wounds but it left some nasty marks on the floor even though I throw it out on the balcony after 1 second.
    Lars Pekkala - Yanıt
  18. Xiaomi Mi 9 Battery Replacement: adım 18, 2 resimden 1. Xiaomi Mi 9 Battery Replacement: adım 18, 2 resimden 2.
    • Use a pair of tweezers to pull out the right adhesive tab from underneath the battery.
  19. Xiaomi Mi 9 Battery Replacement: adım 19, 2 resimden 1. Xiaomi Mi 9 Battery Replacement: adım 19, 2 resimden 2.
    • Use an opening pick to pry the battery out of its recess until you can get a good grip.
  20. Xiaomi Mi 9 Battery Replacement: adım 20, 2 resimden 1. Xiaomi Mi 9 Battery Replacement: adım 20, 2 resimden 2.
    • Remove the battery.
    • Reusing a deformed or bent battery after it has forcefully been removed, is a potential safety hazard. Replace it with a new battery.
    • Remove any remaining adhesive from the midframe, and clean the glued areas with isopropyl alcohol and a lint-free cloth before applying new adhesive.
Sonuç
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
52 farklı kişi bu kılavuzu tamamladı.
231.382 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.715 adet Kılavuz yazıldı
15Kılavuz Yorumları
Is it possible to swap mi 9 battery with mi 9 pro battery?
edwinyapeter - Yanıt
yes I'm also interested. is it the same size? would like to replace with larger battery
Barbudo - Yanıt
What type is the antenna plug?
Mine got damaged
Marcel - Yanıt
Hi Marcel,
the Antenna connector is a COAX connector. You can find a little more information here.
I’ve changed the battery but device has not started even I tried to charge for 1-2 hours..( charger, USB-C cable checked). Btw, the symptoms was like the device started to turn off on around 50% of battery life. And charged too fast in about 10-15 minutes by the original fast charger. What could happen?
Andrew Blake - Yanıt
Im also experiencing this issue. How can I fix this?
Leolando Tan -
Same. Did ya'll figure it out? Going to buy a new battery to see if that helps.
Odin Omdal Hørthe -
You must calibrate your new battery as above instructions.
wheelspinning -
Vielen Dank für die ausführliche Anleitung. Das hat mir 60€ Montagekosten bei Saturn erspart :) Gruß Iris
Iris Ock - Yanıt
I change my battery but it seams that the quick charge has gone from 65% to 100%. Why?
Giulio - Yanıt
You need to calibrate the new battery, the android software still thinks it has the old battery installed.
wheelspinning -
Superb guide, thank you! Battery replacement went very well and the iFixit Mi9 battery is superb quality.
Jez S - Yanıt
In the section what do you need. Gluestrips for the battery should be included
Karel Tenkink - Yanıt
What width glue strips do I need?
Simon Jackson - Yanıt
I just did it with 1mm strips, put two of them on each sides to be secured but I believe 2mm would have been more appropriate.
Armand -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 28
Son 7 gün: 185
Son 30 gün: 1,167
Her zaman: 100,968
