Xiaomi Redmi Note 7 Screen Replacement
Giriş
1. adıma gitUse this guide to replace a cracked or broken screen on your Xiaomi Redmi Note 7.
If the frame is deformed, it's important to replace it to make sure the new screen will mount correctly and won’t suffer damage from uneven pressure.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
You’ll need replacement adhesive to reattach components when reassembling the device.
Apply a heated iOpener to the rear glass to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner to slice the adhesive.
Insert a second opening pick and slide it to the bottom left corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner.
Slide the opening pick along the left edge of the phone to slice the rear glass adhesive.
Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick under the top left corner of the rear glass.
Slide the opening pick along the top edge of the phone to slice the rear glass adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick at the top right corner of the phone.
Slide the opening pick along the right edge to slice the remaining adhesive.
Carefully fold the rear glass to the left side of the phone assembly like you'd open the front cover of a book.
Use a Phillips screw driver to remove the three 3.3 mm-long screws securing the connector cover to the midframe.
Bu adımda kullanılan alet:Tweezers$4.99
Use a pair of tweezers to remove the connector cover.
Use the flat end of a spudger to pry up and disconnect the battery flex cable from the motherboard.
Use a pair of tweezers to carefully peel the yellow protective foil off the ZIF connector.
Why do you need to remove the fingerprint flex cable, are there any special reason for this?
Hi insomniacno1,
it’s not necessary to disconnect the fingerprint cable but if you don’t, you have the rear glass dangling on your phone during all other repairs. This step is relatively easy and makes other repairs way more comfortable after you put the rear glass to the side.
Use the pointed end of a spudger to open the ZIF connector by bringing its black flap in an upright position.
This step is not necessary, there is enough slack in the flex cable so it can stay connected for the battery replacement.
Disconnect the fingerprint flex cable by pulling it straight out off the ZIF connector using a pair of tweezers.
Use a Phillips screw driver to remove the eight 3.3 mm-long screws securing the loudspeaker assembly.
Slide an opening pick underneath the right edge of the loudspeaker assembly.
Use the opening pick to pry up the loudspeaker assembly.
Remove the loudspeaker assembly.
Use a Phillips screw driver to remove the 3.3 mm-long screw securing the display connector cover to the midframe.
Use a pair of tweezers to remove the display connector cover.
Use the flat end of a spudger to pry up and disconnect the display flex cable.
Apply a heated iOpener or a heat gun to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
Once the screen is warm to touch, apply a suction cup to the bottom edge of the phone.
Lift the screen with the suction handle to create a small gap between the screen and the frame.
Insert the tip of an iFlex in the gap between the midframe and the screen.
Insert the tip of an opening pick in the gap between the midframe and the screen, next to the iFlex.
Remove the iFlex.
Slide the opening pick to the bottom right corner to cut the adhesive. Leave it in its place to prevent the adhesive from resealing.
Insert a second opening pick and slide it to the bottom left corner of the screen to cut the adhesive.
Insert a third opening pick under the bottom left corner of the phone.
Slide the opening pick up to the top left corner to cut the adhesive. Leave it in to prevent the adhesive from resealing.
Insert a fourth opening pick at the top left corner.
Slide the opening pick along the top edge of the phone to cut the adhesive. Leave the opening pick in the top right corner of the screen to prevent the adhesive from resealing.
Insert a fifth opening pick and slide it along the right edge of the phone to cut the remaining adhesive.
Thread the display flex cable through the gap in the midframe and remove the screen.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
10 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
This guide is just WRONG and useless.
He disconnect the battery cable and nothing else: if you try this, at step 18 you will just pull a flex cable that is still screwed. The correct ribbon is not the one near the battery connector shown in step 10, but the one on the left under the camera.
Guide shows he removes 3 screews, and these are just to disconnect the battery. After this, it is necessary to remove more screws and actually disconnect the display flex: 1 to free the small metal cover blocking the ribbon (similar to step 9) and 8 more screws on the bottom of the phone to free and remove the loudspeaker, which otherwise will block the display ribbon even if it was disconnected and the first screw I mentioned removed.
Hi A M,
thank you for your feedback. You're completely right. Some prereq guides for the screen guide were set to private and because of that not visible. I made them public and the full display removal procedure should be correct now. If you notice anything else that is wrong or I missed something, please let me know.
شكراً جزيلا
