Ana içeriğe geç
iPad 8 LTE Button Control Cable Replacement
Neye ihtiyacın var
  1. iPad 8 LTE Button Control Cable Replacement, Heat the left edge: adım 1, 1 resimden 1.
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. iPad 8 LTE Button Control Cable Replacement, Screen removal information: adım 2, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Screen removal information: adım 2, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Screen removal information: adım 2, 3 resimden 3.
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. iPad 8 LTE Button Control Cable Replacement, Anti-Clamp instructions: adım 3, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Anti-Clamp instructions: adım 3, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Anti-Clamp instructions: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad 8 LTE Button Control Cable Replacement: adım 4, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 4, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement: adım 4, 3 resimden 3.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad 8 LTE Button Control Cable Replacement: adım 5, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 5, 2 resimden 2.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad 8 LTE Button Control Cable Replacement, Insert an opening pick: adım 6, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Insert an opening pick: adım 6, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Insert an opening pick: adım 6, 3 resimden 3.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. iPad 8 LTE Button Control Cable Replacement, Separate the left adhesive: adım 7, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Separate the left adhesive: adım 7, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Separate the left adhesive: adım 7, 3 resimden 3.
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. iPad 8 LTE Button Control Cable Replacement: adım 8, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 8, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement: adım 8, 3 resimden 3.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. iPad 8 LTE Button Control Cable Replacement: adım 9, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 9, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement: adım 9, 3 resimden 3.
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. iPad 8 LTE Button Control Cable Replacement, Heat the top edge: adım 10, 1 resimden 1.
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
  11. iPad 8 LTE Button Control Cable Replacement, Separate the top left adhesive: adım 11, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Separate the top left adhesive: adım 11, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Separate the top left adhesive: adım 11, 3 resimden 3.
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  12. iPad 8 LTE Button Control Cable Replacement, Separate the top adhesive: adım 12, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Separate the top adhesive: adım 12, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Separate the top adhesive: adım 12, 3 resimden 3.
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. iPad 8 LTE Button Control Cable Replacement: adım 13, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 13, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement: adım 13, 3 resimden 3.
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. iPad 8 LTE Button Control Cable Replacement: adım 14, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 14, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement: adım 14, 3 resimden 3.
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. iPad 8 LTE Button Control Cable Replacement, Heat the right edge: adım 15, 1 resimden 1.
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. iPad 8 LTE Button Control Cable Replacement, Separate the top right adhesive: adım 16, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Separate the top right adhesive: adım 16, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Separate the top right adhesive: adım 16, 3 resimden 3.
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. iPad 8 LTE Button Control Cable Replacement, Separate the right adhesive: adım 17, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Separate the right adhesive: adım 17, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Separate the right adhesive: adım 17, 3 resimden 3.
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  18. iPad 8 LTE Button Control Cable Replacement, Heat the bottom edge: adım 18, 1 resimden 1.
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. iPad 8 LTE Button Control Cable Replacement, Separate the bottom left adhesive: adım 19, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Separate the bottom left adhesive: adım 19, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Separate the bottom left adhesive: adım 19, 3 resimden 3.
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the corner before moving to the next step.
  20. iPad 8 LTE Button Control Cable Replacement, Separate the bottom adhesive: adım 20, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Separate the bottom adhesive: adım 20, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Separate the bottom adhesive: adım 20, 3 resimden 3.
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. iPad 8 LTE Button Control Cable Replacement: adım 21, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 21, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement: adım 21, 3 resimden 3.
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  22. iPad 8 LTE Button Control Cable Replacement: adım 22, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 22, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement: adım 22, 3 resimden 3.
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. iPad 8 LTE Button Control Cable Replacement, Heat the right edge: adım 23, 1 resimden 1.
  24. iPad 8 LTE Button Control Cable Replacement: adım 24, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 24, 2 resimden 2.
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. iPad 8 LTE Button Control Cable Replacement: adım 25, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 25, 2 resimden 2.
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. iPad 8 LTE Button Control Cable Replacement, Separate the right adhesive: adım 26, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Separate the right adhesive: adım 26, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Separate the right adhesive: adım 26, 3 resimden 3.
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. iPad 8 LTE Button Control Cable Replacement: adım 27, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 27, 2 resimden 2.
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  28. iPad 8 LTE Button Control Cable Replacement, Disconnect the home button: adım 28, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement, Disconnect the home button: adım 28, 2 resimden 2.
    • Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
  29. iPad 8 LTE Button Control Cable Replacement: adım 29, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 29, 2 resimden 2.
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
  30. iPad 8 LTE Button Control Cable Replacement: adım 30, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 30, 2 resimden 2.
    • Use a pair of tweezers to pull the home button ribbon cable straight out of the ZIF connector.
  31. iPad 8 LTE Button Control Cable Replacement, Disconnect the display cables: adım 31, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Disconnect the display cables: adım 31, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Disconnect the display cables: adım 31, 3 resimden 3.
    • Use the flat end of a spudger to pry up and disconnect the two digitizer cable press connectors.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  32. iPad 8 LTE Button Control Cable Replacement, Remove the vibration isolator: adım 32, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Remove the vibration isolator: adım 32, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Remove the vibration isolator: adım 32, 3 resimden 3.
    • Use the flat end of a spudger to pry up the vibration isolator below the SIM card reader.
    • Take care not to puncture or tear the home button ribbon cable.
    • Remove the vibration isolator.
  33. iPad 8 LTE Button Control Cable Replacement: adım 33, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 33, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement: adım 33, 3 resimden 3.
    • Use a pair of tweezers to peel the home button cable away from the rear case.
    • The cable is secured with some light adhesive.
  34. iPad 8 LTE Button Control Cable Replacement, Remove the front panel assembly: adım 34, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Remove the front panel assembly: adım 34, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Remove the front panel assembly: adım 34, 3 resimden 3.
    Polyimide Tape
    $9.99
    • Remove the front panel assembly.
    • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye and is different from the foam dust barrier strips found on many iPads.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
  35. iPad 8 LTE Button Control Cable Replacement, Disconnect the home button: adım 35, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement, Disconnect the home button: adım 35, 2 resimden 2.
  36. iPad 8 LTE Button Control Cable Replacement: adım 36, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 36, 2 resimden 2.
  37. iPad 8 LTE Button Control Cable Replacement: adım 37, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 37, 2 resimden 2.
  38. iPad 8 LTE Button Control Cable Replacement, Disconnect the display cables: adım 38, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Disconnect the display cables: adım 38, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Disconnect the display cables: adım 38, 3 resimden 3.
  39. iPad 8 LTE Button Control Cable Replacement, Remove the vibration isolator: adım 39, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Remove the vibration isolator: adım 39, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Remove the vibration isolator: adım 39, 3 resimden 3.
  40. iPad 8 LTE Button Control Cable Replacement: adım 40, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 40, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement: adım 40, 3 resimden 3.
  41. iPad 8 LTE Button Control Cable Replacement, Remove the front panel assembly: adım 41, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Remove the front panel assembly: adım 41, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Remove the front panel assembly: adım 41, 3 resimden 3.
    Polyimide Tape
    $9.99
  42. iPad 8 LTE Button Control Cable Replacement, Remove the upper component bracket: adım 42, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement, Remove the upper component bracket: adım 42, 2 resimden 2.
    • Carefully peel the LCD buffer tape up off of the upper component bracket.
  43. iPad 8 LTE Button Control Cable Replacement: adım 43, 1 resimden 1.
    • Use a Phillips screwdriver to remove the five screws securing the upper component bracket:
    • Three 1.4 mm-long screws
    • Two 1.9 mm-long screws
  44. iPad 8 LTE Button Control Cable Replacement: adım 44, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 44, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement: adım 44, 3 resimden 3.
    • Use the pointed end of a spudger to lift up the upper component bracket until you can grip it with your fingers.
    • Remove the upper component bracket.
    • You may need to peel the upper component bracket off of some tape securing it to the logic board.
  45. iPad 8 LTE Button Control Cable Replacement, Disconnect the rear camera: adım 45, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement, Disconnect the rear camera: adım 45, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the rear camera press connector.
  46. iPad 8 LTE Button Control Cable Replacement, Heat the rear camera: adım 46, 1 resimden 1.
    • Heat an iOpener and apply it to the top-left edge of the iPad's rear for thirty seconds to loosen the rear camera adhesive.
  47. iPad 8 LTE Button Control Cable Replacement: adım 47, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 47, 2 resimden 2.
    • Use an opening tool to pry the rear camera out of the rear case.
  48. iPad 8 LTE Button Control Cable Replacement, Remove the rear camera: adım 48, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement, Remove the rear camera: adım 48, 2 resimden 2.
    • Use tweezers, or your fingers, to remove the rear camera.
  49. iPad 8 LTE Button Control Cable Replacement, Disconnect the button control cable: adım 49, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement, Disconnect the button control cable: adım 49, 2 resimden 2.
  50. iPad 8 LTE Button Control Cable Replacement: adım 50, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 50, 2 resimden 2.
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the button control cable ZIF connector.
  51. iPad 8 LTE Button Control Cable Replacement: adım 51, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 51, 2 resimden 2.
    • Use a pair of tweezers to carefully pull the button control cable straight out of the ZIF connector.
  52. iPad 8 LTE Button Control Cable Replacement, Remove the volume button bracket: adım 52, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement, Remove the volume button bracket: adım 52, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 2.3 mm-long screws securing the volume button bracket to the rear case.
  53. iPad 8 LTE Button Control Cable Replacement: adım 53, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 53, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 2.3 mm-long screws securing the lock button bracket.
  54. iPad 8 LTE Button Control Cable Replacement: adım 54, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 54, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement: adım 54, 3 resimden 3.
    • Insert the point of a spudger between the rear case and the bottom of the volume button bracket to dislodge it.
    • Remove the volume button bracket.
  55. iPad 8 LTE Button Control Cable Replacement, Remove the button control cable: adım 55, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Remove the button control cable: adım 55, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Remove the button control cable: adım 55, 3 resimden 3.
    • Use the flat end of a spudger to push the volume buttons out of their slots in the rear case.
  56. iPad 8 LTE Button Control Cable Replacement: adım 56, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 56, 2 resimden 2.
    • Insert an opening pick between the button control cable and the rear case.
    • Slide the opening pick up toward the lock button to cut the adhesive securing the button control cable to the rear case.
  57. iPad 8 LTE Button Control Cable Replacement, Remove the button control cable: adım 57, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement, Remove the button control cable: adım 57, 2 resimden 2.
    • Remove the button control cable.
    • The lock button will become loose once the button control cable is removed.
    • Upon reassembly, remember to set the lock button back into the its slot.
  58. iPad 8 LTE Button Control Cable Replacement, Loosen the adhesive: adım 58, 2 resimden 1. iPad 8 LTE Button Control Cable Replacement, Loosen the adhesive: adım 58, 2 resimden 2.
    • Heat an iOpener and apply it to the button control cable for thirty seconds.
  59. iPad 8 LTE Button Control Cable Replacement, Remove the buttons: adım 59, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Remove the buttons: adım 59, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Remove the buttons: adım 59, 3 resimden 3.
    • Use a pair of tweezers to grip the upper volume button.
    • Insert an opening pick between the volume control cable and the upper volume button.
    • Peel the volume control cable off of the upper volume button.
  60. iPad 8 LTE Button Control Cable Replacement: adım 60, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement: adım 60, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement: adım 60, 3 resimden 3.
    • Repeat the same process to peel the volume control cable off of the lower volume button.
  61. iPad 8 LTE Button Control Cable Replacement, Remove the lock button bracket: adım 61, 3 resimden 1. iPad 8 LTE Button Control Cable Replacement, Remove the lock button bracket: adım 61, 3 resimden 2. iPad 8 LTE Button Control Cable Replacement, Remove the lock button bracket: adım 61, 3 resimden 3.
    Tesa 61395 Tape
    $5.99
    • Use a pair of tweezers to grip the lock button bracket.
    • Insert a halberd spudger or opening pick between the lock button bracket and the button control cable.
    • Peel the button control cable up and off of the pegs on the lock button bracket.
    • Upon reassembly, apply Tesa tape to reattach the volume buttons and lock button bracket to the button control cable.
  62. iPad 8 LTE Button Control Cable Replacement: adım 62, 1 resimden 1.
    • Only the button control cable remains.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 8 Answers community for help.
Alex Diaz-Kokaisl
213.775 İtibar
1.041 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.735 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 510
