Ana içeriğe geç
iPad Pro 11" 4th Gen Screen Replacement
Neye ihtiyacın var
  1. iPad Pro 11" 4th Gen Screen Replacement, Prepare your iPad: adım 1, 1 resimden 1.
    • Ensure the battery is entirely drained before attempting this repair. The battery connection in this device is sensitive and you don't want to accidentally provide the board power for a myriad of reasons.
    • All cords/cables should be removed and the iPad should be fully shut down.
  2. iPad Pro 11" 4th Gen Screen Replacement, Important Information: adım 2, 3 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Important Information: adım 2, 3 resimden 2. iPad Pro 11" 4th Gen Screen Replacement, Important Information: adım 2, 3 resimden 3.
    • There are important and sensitive connections that you should make note of before attempting this repair. The colored boxes each represent an important component just below the screen.
    • Exposed LCD Edges
    • Screen Magnets
    • Camera Module, Ambient Light & Proximity Sensors, and Microphone
    • Display Cables
  3. iPad Pro 11" 4th Gen Screen Replacement, Heat the Right Edge: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Clamp
    $24.95
    Satın Al
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    • You may use a hair dryer or heat gun but extreme caution should be used because you don't want to over heat any one part of the display.
    • There is an additional method for opening using iFixit's new Anti-Clamp.
  4. iPad Pro 11" 4th Gen Screen Replacement, Insert Opening Pick: adım 4, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Insert Opening Pick: adım 4, 2 resimden 2.
    • If the display is badly cracked, consider cover it with a layer of clear packing tape. This may allow a suction cup to adhere. iFixit even advises using superglue if you are totally replacing the display.
    • Apply a suction cup to the right edge of the screen about 5 cm from the bottom edge.
    • Pull up on the suction cup with firm, constant pressure to create a gap large enough to insert an opening pick no more that 5mm into the iPad.
    • If you find it helpful, mark the 5mm line on the opening pick with a sharpie before inserting.
    • Try to remember you only need to create a gap large enough for the opening pick to get in.
  5. iPad Pro 11" 4th Gen Screen Replacement, Separate the right edge adhesive: adım 5, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Separate the right edge adhesive: adım 5, 2 resimden 2.
    • Insert another opening pick right next to the original.
    • Slide the new pick along the right edge to separate the adhesive.
    • When you get close to the volume buttons make sure the pick isn't inserted more than 2mm
    • Leave the pick in the top right corner.
  6. iPad Pro 11" 4th Gen Screen Replacement, Heat the Top Edge: adım 6, 1 resimden 1.
    • Apply the heated iOpener to the top edge of the iPad for two minutes.
  7. iPad Pro 11" 4th Gen Screen Replacement, Important Information: Top Edge: adım 7, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Important Information: Top Edge: adım 7, 2 resimden 2.
    • The top edge contains the camera module, two ambient light sensors, the proximity sensor, and the front microphone. All of these components are fragile and easily damaged if an opening pick is inserted too far.
    • This color indicates the location of the ambient light sensors. Avoid inserting the opening pick more than 2mm to avoid damaging the sensors.
    • This color indicates the location of the camera module, proximity sensor and microphone. Avoid inserting the opening pick more that 1mm to avoid damage.
  8. iPad Pro 11" 4th Gen Screen Replacement, Separate the Top Adhesive: adım 8, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Separate the Top Adhesive: adım 8, 2 resimden 2.
    • Insert opening pick #3 around the corner from where you left #2.
    • Take pick #3 and slide the pick along the top edge. Taking precaution of the components listed in the previous step.
    • Leave pick #3 on the right side of the ambient light sensor, near the upper left corner.
  9. iPad Pro 11" 4th Gen Screen Replacement, Heat the Bottom Edge: adım 9, 1 resimden 1.
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
  10. iPad Pro 11" 4th Gen Screen Replacement, Separate the Bottom Edge Adhesive: adım 10, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Separate the Bottom Edge Adhesive: adım 10, 2 resimden 2.
    • Insert pick #4 in the bottom right corner below the original pick.
    • Slide the pick around the bottom right corner taking caution not to insert more than 2mm.
  11. iPad Pro 11" 4th Gen Screen Replacement: adım 11, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement: adım 11, 2 resimden 2.
    • Slide the opening pick along the bottom edge, taking care just above the USB-C port.
    • Once the pick has made it to the opposite corner, leave pick #4 right above the USB-C port.
    • Insert opening pick #5 above opening pick #4 and take #5 the rest of the length of the bottom edge and around the left corner. Leave #5 at just above the corner.
  12. iPad Pro 11" 4th Gen Screen Replacement, Heat the Left Edge: adım 12, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  13. iPad Pro 11" 4th Gen Screen Replacement, Important Information: The Left Edge: adım 13, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Important Information: The Left Edge: adım 13, 2 resimden 2.
    • The left edge contains several display cables. These are extremely fragile and easily damaged by an opening pick if it's inserted too far.
    • This color indicates where the display cables are located within small indents of the frame. Best practice is to insert the pick at a 45 degree angle.
    • This color indications where the flat sections of the frame are. These sections require the pick to be horizontal.
  14. iPad Pro 11" 4th Gen Screen Replacement, Separate the Left Edge Adhesive: adım 14, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Separate the Left Edge Adhesive: adım 14, 2 resimden 2.
    • Insert a pick at a 45 degree angle just above the bottom left corner.
    • Carefully slide the pick along the left edge, stopping when you reach the flats section of the frame.
  15. iPad Pro 11" 4th Gen Screen Replacement, Separate the Remaining Adhesive: adım 15, 1 resimden 1.
    • Separate the remaining adhesive.
    • Slide the pick at a 45 degree downward angle and don't insert the pick more than 5mm.
    • Slide the pick horizontally and don't insert more than 5mm
  16. iPad Pro 11" 4th Gen Screen Replacement, Separate the Screen from the Frame: adım 16, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Separate the Screen from the Frame: adım 16, 2 resimden 2.
    • Use yet another opening pick to see if there is any remaining adhesive.
    • Grave the top right and bottom left corners of the screen and slowly move the screen towards the bottom right side.
    • The screen is still attached to the iPad by several ribbon cables. While you move the display you can lift it straight up slightly to see their position.
    • Keep moving the screen until you see the ambient light sensor ribbon cable near the top edge is uncovered.
  17. iPad Pro 11" 4th Gen Screen Replacement: adım 17, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement: adım 17, 2 resimden 2.
    Satın Al
    • Use a Phillips screwdriver to remove the two screws securing the ambient light sensor bracket to the logic board.
    • One 1.3 mm screw
    • One 2.0 mm screw
    • Use a pair of tweezers or your fingers to remove the bracket.
    • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
  18. iPad Pro 11" 4th Gen Screen Replacement, Disconnect the Ambient Light Sensor Cable: adım 18, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Disconnect the Ambient Light Sensor Cable: adım 18, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the ambient light sensor cable by lifting straight up on the press connectors.
  19. iPad Pro 11" 4th Gen Screen Replacement, Reposition the Screen: adım 19, 3 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Reposition the Screen: adım 19, 3 resimden 2. iPad Pro 11" 4th Gen Screen Replacement, Reposition the Screen: adım 19, 3 resimden 3.
    • The screen is still attached by one more ribbon cable - do not try to remove it yet.
    • Holding the right edge of the screen, open the iPad like a book.
    • In order to not strain the ribbon cable let the screen rest over the left side of the iPad.
  20. iPad Pro 11" 4th Gen Screen Replacement, Remove the Logic Board Cable Shield: adım 20, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Remove the Logic Board Cable Shield: adım 20, 2 resimden 2.
    • Using a Phillips head screwdriver, remove the five screws securing the cable shield to the logic board:
    • Two 2.0 mm screws
    • Three 1.3 mm screws
    • Use tweezers or your fingers to grab and remove the lower cable shield.
  21. iPad Pro 11" 4th Gen Screen Replacement, Unscrew Battery Connector: adım 21, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
  22. iPad Pro 11" 4th Gen Screen Replacement, Important Information: Battery Reference: adım 22, 3 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Important Information: Battery Reference: adım 22, 3 resimden 2. iPad Pro 11" 4th Gen Screen Replacement, Important Information: Battery Reference: adım 22, 3 resimden 3.
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  23. iPad Pro 11" 4th Gen Screen Replacement, Create a battery blocker: adım 23, 3 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Create a battery blocker: adım 23, 3 resimden 2. iPad Pro 11" 4th Gen Screen Replacement, Create a battery blocker: adım 23, 3 resimden 3.
    • You need to place a barrier between the battery connector and logic board to disconnect the battery. Follow this step to create a battery blocker out of a playing card.
    • Cut two 6 mm-wide strips from a playing card to block the connections to the battery.
  24. iPad Pro 11" 4th Gen Screen Replacement, Insert the card strips: adım 24, 3 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Insert the card strips: adım 24, 3 resimden 2. iPad Pro 11" 4th Gen Screen Replacement, Insert the card strips: adım 24, 3 resimden 3.
    • Insert the card strips under each side of the battery connector.
    • If you can't slide the cards under the battery connector, use an opening pick to gently lift the connector to help insert the card strips.
    • Don't pry or lift the connector too much—it's soldered onto the logic board and may break if stressed.
  25. iPad Pro 11" 4th Gen Screen Replacement, Disconnect Display Cables: adım 25, 3 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Disconnect Display Cables: adım 25, 3 resimden 2. iPad Pro 11" 4th Gen Screen Replacement, Disconnect Display Cables: adım 25, 3 resimden 3.
    • Using the pointed end of a spudger, disconnect the bottom two display cables.
    • Using the pointed end of a spudger disconnect the top two display cables.
  26. iPad Pro 11" 4th Gen Screen Replacement, Remove the Screen: adım 26, 1 resimden 1.
    • The screen is now entirely disconnected. You may lift it away from the housing.
    • Use isopropyl alcohol (>90%) and a lint free cloth or q-tip to remove any remaining adhesive on the housing before replacing the display. Remember, without replacing the adhesive strips, your iPad is at serious risk of water damage.
    • Follow this guide to install pre-cut adhesive strips on your iPad before sealing it up.
  27. iPad Pro 11" 4th Gen Screen Replacement, LiDAR Removal: adım 27, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, LiDAR Removal: adım 27, 2 resimden 2.
    • The LiDAR sensor assembly is paired to the Face ID hardware. You'll need to transfer it to your replacement screen to keep Face ID functionality. The following steps show how to remove the sensor assembly and install it on your replacement screen.
    • Ambient Light Sensors (2)
    • Microphone
    • Proximity Sensor
    • The ribbon cable that connects these sensors is very thin and delicate, take your time and be careful with removal.
    • Prepare an iOpener. Leave it in place at the top of the display for two minutes.
  28. iPad Pro 11" 4th Gen Screen Replacement, Ambient Light Sensors: adım 28, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Ambient Light Sensors: adım 28, 2 resimden 2.
    • Using a pair of tweezers, insert one arm between the ambient light sensor and the screen.
    • Gently pry the sensor up from the screen. This may take considerable force.
    • Repeat these steps with the other ambient light sensor.
  29. iPad Pro 11" 4th Gen Screen Replacement, Proximity Sensor: adım 29, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Proximity Sensor: adım 29, 2 resimden 2.
    • Reheat & reapply your iOpener
    • Using the same method that we used with the ambient light sensor, use one arm of the tweezers to slip under the ribbon cable and gently pry up.
  30. iPad Pro 11" 4th Gen Screen Replacement, Microphone: adım 30, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Microphone: adım 30, 2 resimden 2.
    • There may be tape covering the microphone.
    • Slide the opening tool under the microphone to separate the adhesive.
    • Pry up to separate the microphone from the screen.
  31. iPad Pro 11" 4th Gen Screen Replacement, LiDar Cable Removal Procedure: adım 31, 1 resimden 1.
    • Slide an opening pick under the LiDAR sensor assembly cable to separate it from the screen.
    • Exercise caution while separating this cable to avoid tearing it.
  32. iPad Pro 11" 4th Gen Screen Replacement, Remove the LiDAR Cable: adım 32, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Remove the LiDAR Cable: adım 32, 2 resimden 2.
    • Continue to use the opening pick to separate the LiDAR cable from the screen.
  33. iPad Pro 11" 4th Gen Screen Replacement, Lower Display Cable Transfer: adım 33, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Lower Display Cable Transfer: adım 33, 2 resimden 2.
    • Some display replacements come without display cables attached. If this is the case, you will need to remove the display cables from your original display.
    • The bracket in the bottom right corner of the display is covering the display cable connectors.
  34. iPad Pro 11" 4th Gen Screen Replacement, Separate Display Cable: adım 34, 2 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Separate Display Cable: adım 34, 2 resimden 2.
    • Use an opening pick to remove the small section of the upper display cable that is attached to the bracket.
  35. iPad Pro 11" 4th Gen Screen Replacement, Remove the Bracket: adım 35, 3 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Remove the Bracket: adım 35, 3 resimden 2. iPad Pro 11" 4th Gen Screen Replacement, Remove the Bracket: adım 35, 3 resimden 3.
    • Use a Phillips screwdriver to remove the two 1.2mm screws scoring the display cable bracket.
    • Using a pair of tweezers remove the lower display cable bracke.
  36. iPad Pro 11" 4th Gen Screen Replacement, Disconnect & Remove Display Cables: adım 36, 3 resimden 1. iPad Pro 11" 4th Gen Screen Replacement, Disconnect & Remove Display Cables: adım 36, 3 resimden 2. iPad Pro 11" 4th Gen Screen Replacement, Disconnect & Remove Display Cables: adım 36, 3 resimden 3.
    • Using flat end of a spudger, pry up and disconnect the narrow display cable.
    • Set the cable aside to connect to your new display.
    • Repeat this process with the wider display cable.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Luke
992 İtibar
1 Kılavuz yazıldı
Ekip
Apple fan boys Apple fan boys üyesi
Community
51 Üyeler
44 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 47
Son 7 gün: 186
Son 30 gün: 791
Her zaman: 6,555
