Ana içeriğe geç
iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement
  1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Prepare your iPad for disassembly: adım 1, 1 resimden 1.
    • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Unplug any cables and fully shut down your iPad.
  2. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Heat the right edge: adım 2, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the iPad—the screen and internal battery are susceptible to heat damage.
  3. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Anti-Clamp instructions: adım 3, 3 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Anti-Clamp instructions: adım 3, 3 resimden 2. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Anti-Clamp instructions: adım 3, 3 resimden 3.
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Elevate the iPad enough for the Anti-Clamp's arms to rest above and below the screen.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the right edge of the iPad—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  4. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement: adım 4, 3 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement: adım 4, 3 resimden 2. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement: adım 4, 3 resimden 3.
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  5. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Insert an opening pick: adım 5, 3 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Insert an opening pick: adım 5, 3 resimden 2. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Insert an opening pick: adım 5, 3 resimden 3.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Apply a suction handle to the screen as close to the center of the right edge as possible.
    • Pull up on the suction handle with a strong, steady force to create a small gap between the frame and screen.
    • The large screen is very fragile. Only create a gap big enough to insert an opening pick.
    • Insert an opening pick into the gap.
    • Don't insert the pick more than 5 mm to avoid damaging the screen.
  6. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Right edge information: adım 6, 3 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Right edge information: adım 6, 3 resimden 2. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Right edge information: adım 6, 3 resimden 3.
    • Along the frame's right edge, there are two cutouts for the screen magnets where the adhesive is very thin. As you slice along this edge in the next step, don't insert your opening pick deeper than 2 mm in these locations:
    • One magnet begins 2 cm from the top edge and is 2.5 cm long.
    • The second magnet begins 3 cm from the bottom edge and is 2.5 cm long.
  7. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the right edge adhesive: adım 7, 3 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the right edge adhesive: adım 7, 3 resimden 2. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the right edge adhesive: adım 7, 3 resimden 3.
    • Slide your opening pick back and forth along the right edge of the screen to slice the adhesive.
    • Angle your pick downward and insert it no more than 2 mm near the magnet cutouts and 5 mm everywhere else.
  8. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the corner adhesive: adım 8, 2 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the corner adhesive: adım 8, 2 resimden 2.
    • Rotate your opening pick around the bottom right corner of the screen.
    • Leave your pick in the bottom right corner to prevent the adhesive from resealing.
  9. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Heat the bottom edge: adım 9, 1 resimden 1.
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
  10. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the bottom edge adhesive: adım 10, 3 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the bottom edge adhesive: adım 10, 3 resimden 2. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the bottom edge adhesive: adım 10, 3 resimden 3.
    • Insert a second opening pick in the bottom right corner of the screen.
    • Don't insert your opening pick more than 5 mm.
    • Slide your pick to the bottom left corner to slice the bottom edge adhesive.
  11. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the corner adhesive: adım 11, 2 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the corner adhesive: adım 11, 2 resimden 2.
    • Rotate your opening pick around the bottom left corner of the screen.
    • Leave your pick in the bottom left corner to prevent the adhesive from resealing.
  12. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Heat the left edge: adım 12, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  13. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Left edge information: adım 13, 1 resimden 1.
    • Along the left edge of the screen, there are three cutouts for cables where the adhesive is very thin. As you slice along this edge in the next step, don't insert your opening pick deeper than 2 mm in these locations:
    • The upper cutout begins 4 cm from the top edge and is 2.5 cm long.
    • The middle cutout is exactly in the middle of the frame and is 2.5 cm long.
    • The lower cutout begins 4 cm from the bottom edge and is 2.5 cm long.
    • Everywhere else, don't insert your opening pick more than 5 mm.
  14. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the left edge adhesive: adım 14, 3 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the left edge adhesive: adım 14, 3 resimden 2. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the left edge adhesive: adım 14, 3 resimden 3.
    • Insert a third opening pick in the bottom left corner of the screen.
    • Slide your pick to the top left corner to slice the left edge adhesive.
  15. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the corner adhesive: adım 15, 2 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the corner adhesive: adım 15, 2 resimden 2.
    • Rotate your opening pick around the top left corner of the screen.
    • Leave your pick in the top left corner to prevent the adhesive from resealing.
  16. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Heat the top edge: adım 16, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  17. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Top edge information: adım 17, 2 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Top edge information: adım 17, 2 resimden 2.
    • While the top edge adhesive softens, note the following:
    • There are two ambient light sensors near the corners. Only insert the very tip of your pick here to avoid damaging them.
    • There are three strips of heat dispersion tape. Angle your pick upward as you slice here.
    • The front-facing camera assembly is in the center of the top edge. Don't insert your pick here to avoid damaging them.
    • Everywhere else, don't insert your pick deeper than 5 mm to avoid damaging the screen.
  18. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the top edge adhesive: adım 18, 2 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Slice the top edge adhesive: adım 18, 2 resimden 2.
    • Slide your opening pick 9 cm toward the center of the top edge to slice the adhesive, paying attention to the spots mentioned in the previous step.
    • If you slice farther than 9 cm, you will reach the front camera assembly and risk damaging its components.
    • Leave your pick inserted. You will use another pick to slice the remaining adhesive.
  19. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement: adım 19, 2 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement: adım 19, 2 resimden 2.
    • Insert a fourth opening pick to the right of the front camera assembly, 4 cm from the previous opening pick and 9 cm from the right edge of the screen.
    • Slide your pick to the top right corner to slice the remaining adhesive.
  20. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Reposition the screen: adım 20, 3 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Reposition the screen: adım 20, 3 resimden 2. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Reposition the screen: adım 20, 3 resimden 3.
    • Grab two opposing corners of the screen and gently shift it around to separate it from the frame.
    • Don't fully remove the screen yet, as it's still attached by several cables.
    • If the screen feels stuck, slide your opening picks around the perimeter to separate any remaining adhesive. Pay attention to sensitive components mentioned in the previous steps.
    • Shift the screen towards the bottom right corner of the frame until the ribbon cable near the top edge is uncovered.
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use your Phillips screwdriver to remove the two screws securing the upper cable shield:
    • One 1.8 mm-long screw
    • One 2.0 mm-long screw
    • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
  21. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Remove the upper cable shield: adım 22, 2 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Remove the upper cable shield: adım 22, 2 resimden 2.
    • Use tweezers or your fingers to grab and remove the upper cable shield.
    • During reassembly, orient the shield so the notch faces up and to the right.
  22. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Disconnect the upper sensors: adım 23, 2 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Disconnect the upper sensors: adım 23, 2 resimden 2.
    • Use the point of your spudger to pry up and disconnect the upper sensors press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  23. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Reposition the screen: adım 24, 3 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Reposition the screen: adım 24, 3 resimden 2. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Reposition the screen: adım 24, 3 resimden 3.
    • Grip the right edge of the screen and fold it open like a book.
    • Don't pull on the screen—the ribbon cables near the bottom are still attached.
    • Lay the screen down over the left edge of the iPad.
  24. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Unfasten the lower cable shield: adım 25, 1 resimden 1.
    • Use your Phillips screwdriver to remove the five screws securing the lower cable shield:
    • Four 1.1 mm screws
    • One 2.0 mm screw
  25. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Remove the lower cable shield: adım 26, 2 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Remove the lower cable shield: adım 26, 2 resimden 2.
    • Use tweezers or your fingers to grab and remove the lower cable shield.
  26. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Unfasten the battery: adım 27, 1 resimden 1.
    • Use your Phillips screwdriver to remove the 1.7 mm screw securing the battery connector to the logic board.
  27. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Create a battery blocker: adım 28, 3 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Create a battery blocker: adım 28, 3 resimden 2. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Create a battery blocker: adım 28, 3 resimden 3.
    • You need to place a barrier between the battery connector and logic board to disconnect the battery. Follow this step to create a battery blocker out of a playing card.
    • Cut two 6 mm-wide strips from a playing card to block the connections to the battery.
  28. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Insert the card strips: adım 29, 3 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Insert the card strips: adım 29, 3 resimden 2. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Insert the card strips: adım 29, 3 resimden 3.
    • Insert the card strips under each side of the battery connector.
    • If you can't slide the cards under the battery connector, use an opening pick to gently lift the connector to help insert the card strips.
    • Don't pry or lift the connector too much—it's soldered onto the logic board and may break if stressed.
    • During reassembly, this is a good time to apply replacement adhesive, if you have it. Follow this guide to clean your screen and apply new adhesive strips.
  29. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Disconnect the USB-C port: adım 30, 2 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Disconnect the USB-C port: adım 30, 2 resimden 2.
    • Use the point of your spudger to pry up and disconnect the USB-C port press connector from the logic board.
  30. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Soften the adhesive: adım 31, 1 resimden 1.
  31. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Loosen the USB-C port cable: adım 32, 2 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Loosen the USB-C port cable: adım 32, 2 resimden 2.
    • Slide an opening pick under the USB-C port cable to separate it from the logic board.
  32. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Unfasten the USB-C port: adım 33, 1 resimden 1.
    • Use your Phillips screwdriver to remove the two 1.6 mm-long screws securing the USB-C port.
  33. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Remove the USB-C port: adım 34, 3 resimden 1. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Remove the USB-C port: adım 34, 3 resimden 2. iPad Pro 12.9" 4th Gen USB-C Charging Port Replacement, Remove the USB-C port: adım 34, 3 resimden 3.
    • Grab and remove the USB-C port from its recess in the frame.
    • Use caution not to lose the grounding contacts on either side of the USB-C recess.
    • During reassembly, install the USB-C port underneath the grounding contacts.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 12.9" 4th Gen Answers community for help.
Clay Eickemeyer
21.773 İtibar
175 adet Kılavuz yazıldı
iFixit iFixit üyesi
Community
138 Üyeler
17.041 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 45
Son 30 gün: 111
Her zaman: 144
