Ana içeriğe geç
iPad Pro 12.9" 5th Gen Front Camera Replacement
Neye ihtiyacın var
  1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Prepare your iPad for disassembly: adım 1, 1 resimden 1.
    • Allow your iPad's battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged during the repair.
    • If your battery is swollen, take appropriate precautions.
    • Unplug any cables and fully shut down your iPad.
    FixBot'a Sor
    Yorum Ekle
  2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Heat the right edge: adım 2, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the iPad—the screen and internal battery are susceptible to heat damage.
    FixBot'a Sor
    Yorum Ekle
  3. iPad Pro 12.9" 5th Gen Front Camera Replacement, Anti-Clamp instructions: adım 3, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Anti-Clamp instructions: adım 3, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Anti-Clamp instructions: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
    FixBot'a Sor
    Yorum Ekle
  4. iPad Pro 12.9" 5th Gen Front Camera Replacement: adım 4, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement: adım 4, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement: adım 4, 3 resimden 3.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    FixBot'a Sor
    Yorum Ekle
  5. iPad Pro 12.9" 5th Gen Front Camera Replacement: adım 5, 2 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement: adım 5, 2 resimden 2.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
    FixBot'a Sor
    Yorum Ekle
  6. iPad Pro 12.9" 5th Gen Front Camera Replacement, Insert an opening pick: adım 6, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Insert an opening pick: adım 6, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Insert an opening pick: adım 6, 3 resimden 3.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken display.
    • Apply a suction handle to the screen as close to the center of the right edge as possible.
    • Pull up on the suction handle with a strong, steady force to create a small gap between the frame and screen.
    • The large screen is very fragile. Only create a gap big enough to insert an opening pick.
    • If you're having trouble making a gap, reapply a heated iOpener to the right edge for two minutes.
    • Insert an opening pick into the gap.
    • Don't insert the pick more than 5 mm to avoid damaging the screen.
    FixBot'a Sor
    Yorum Ekle
  7. iPad Pro 12.9" 5th Gen Front Camera Replacement, Right edge information: adım 7, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Right edge information: adım 7, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Right edge information: adım 7, 3 resimden 3.
    • There are two 2.3 cm-long magnets along the right edge of the screen. Don't insert your opening pick more than 2 mm to avoid damaging the screen in these locations:
    • The first magnet begins 1.9 cm from the top of the iPad.
    • The second magnet begins 2.9 cm from the bottom of the iPad.
    • Everywhere else, don't insert your opening pick more than 5 mm.
    FixBot'a Sor
    Yorum Ekle
  8. iPad Pro 12.9" 5th Gen Front Camera Replacement, Separate the right adhesive: adım 8, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Separate the right adhesive: adım 8, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Separate the right adhesive: adım 8, 3 resimden 3.
    • Slide your opening pick along the right edge of the screen to separate the adhesive.
    • Angle your pick downward and insert up to a 2 mm depth near the magnet cutouts and 5 mm everywhere else.
    • Leave the pick inserted in the bottom right corner before continuing.
    FixBot'a Sor
    Yorum Ekle
  9. iPad Pro 12.9" 5th Gen Front Camera Replacement, Separate the corner adhesive: adım 9, 2 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Separate the corner adhesive: adım 9, 2 resimden 2.
    • Slide your opening pick around the bottom right corner of the screen to separate the adhesive.
    • Leave your pick in the bottom right corner to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  10. iPad Pro 12.9" 5th Gen Front Camera Replacement, Heat the bottom edge: adım 10, 1 resimden 1.
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
    FixBot'a Sor
    Yorum Ekle
  11. iPad Pro 12.9" 5th Gen Front Camera Replacement, Separate the bottom adhesive: adım 11, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Separate the bottom adhesive: adım 11, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Separate the bottom adhesive: adım 11, 3 resimden 3.
    • Insert a second opening pick under the bottom right corner of the screen.
    • Don't insert your opening pick more than 5 mm.
    • Slide your pick to the bottom left corner to separate the bottom adhesive.
    FixBot'a Sor
    Yorum Ekle
  12. iPad Pro 12.9" 5th Gen Front Camera Replacement, Slice the corner adhesive: adım 12, 2 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Slice the corner adhesive: adım 12, 2 resimden 2.
    • Rotate your opening pick around the bottom left corner of the screen.
    • Leave your pick in the bottom left corner to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  13. iPad Pro 12.9" 5th Gen Front Camera Replacement, Heat the left edge: adım 13, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the screen for two minutes.
    FixBot'a Sor
    Yorum Ekle
  14. iPad Pro 12.9" 5th Gen Front Camera Replacement, Left edge information: adım 14, 2 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Left edge information: adım 14, 2 resimden 2.
    • There are four cutouts for flex cables along the left edge of the screen where the adhesive is very thin. Don’t insert your opening pick more than 2 mm in these locations to avoid damaging the display:
    • The 2.1-cm outer cutouts begin at 6.1 cm from the top and bottom of the frame.
    • The 2.8-cm inner cutouts begin at 10.1 cm from the top and bottom of the frame.
    FixBot'a Sor
    Yorum Ekle
  15. iPad Pro 12.9" 5th Gen Front Camera Replacement, Slice the left adhesive: adım 15, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Slice the left adhesive: adım 15, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Slice the left adhesive: adım 15, 3 resimden 3.
    • Insert a third opening pick under the bottom left corner of the screen.
    • Slide your pick to the top left corner to slice the left adhesive, making sure to avoid the cutouts shown in the previous step.
    • Leave the pick inserted in the top left corner before continuing.
    FixBot'a Sor
    Yorum Ekle
  16. iPad Pro 12.9" 5th Gen Front Camera Replacement, Slice the corner adhesive: adım 16, 2 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Slice the corner adhesive: adım 16, 2 resimden 2.
    • Slide your opening pick around the top left corner of the screen.
    • Leave your pick in the top left corner to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  17. iPad Pro 12.9" 5th Gen Front Camera Replacement, Heat the top edge: adım 17, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the screen for two minutes.
    FixBot'a Sor
    Yorum Ekle
  18. iPad Pro 12.9" 5th Gen Front Camera Replacement, Top edge information: adım 18, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Top edge information: adım 18, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Top edge information: adım 18, 3 resimden 3.
    • While the top edge adhesive softens, note the following:
    • There are 0.7-cm cutouts for the ambient light sensors starting 4.1 cm from each of the side edges. Don't insert your pick more than 1 mm here.
    • The front-facing camera and additional sensors are in the center of the top edge. Don't insert your pick here—there is less than 1 mm of adhesive and you may damage the components.
    • For everywhere else, don't insert your pick more than 5 mm to avoid damaging the screen.
    FixBot'a Sor
    Yorum Ekle
  19. iPad Pro 12.9" 5th Gen Front Camera Replacement, Separate the top adhesive: adım 19, 2 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Separate the top adhesive: adım 19, 2 resimden 2.
    • Slide your opening pick toward the top right edge, stopping just before the camera assembly.
    • If you slide any farther, you risk damaging the camera's sensors.
    • Leave your pick inserted before continuing.
    FixBot'a Sor
    Yorum Ekle
  20. iPad Pro 12.9" 5th Gen Front Camera Replacement: adım 20, 2 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement: adım 20, 2 resimden 2.
    • Insert a new opening pick on the other side of the camera assembly, about 4 cm from the previous pick.
    • Slide your pick to the top right corner to slice the remaining adhesive.
    FixBot'a Sor
    Yorum Ekle
  21. iPad Pro 12.9" 5th Gen Front Camera Replacement, Reposition the screen: adım 21, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Reposition the screen: adım 21, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Reposition the screen: adım 21, 3 resimden 3.
    • Don't fully remove the screen, as it's attached by several cables.
    • Grab two opposing corners of the screen and lift up to separate it from the frame.
    • If the screen feels stuck, slide your opening picks around the perimeter to separate any remaining adhesive. Pay attention to sensitive areas shown in previous steps.
    • Shift the screen towards the bottom right corner of the frame until the ribbon cable near the top edge is uncovered.
    FixBot'a Sor
    Yorum Ekle
  22. iPad Pro 12.9" 5th Gen Front Camera Replacement, Unfasten the upper cable shield: adım 22, 1 resimden 1.
    FixMat
    $36.95
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a Phillips screwdriver to remove the two screws securing the upper cable shield:
    • One 1.8 mm-long screw
    • One 1.4 mm-long screw
    • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
    FixBot'a Sor
    Yorum Ekle
  23. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the upper cable shield: adım 23, 2 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the upper cable shield: adım 23, 2 resimden 2.
    • Use tweezers or your fingers to grab and remove the upper cable shield.
    FixBot'a Sor
    Yorum Ekle
  24. iPad Pro 12.9" 5th Gen Front Camera Replacement, Disconnect the upper sensors: adım 24, 2 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Disconnect the upper sensors: adım 24, 2 resimden 2.
    • Use the tip of a spudger to pry up and disconnect the upper sensors press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    FixBot'a Sor
    Yorum Ekle
  25. iPad Pro 12.9" 5th Gen Front Camera Replacement, Reposition the screen: adım 25, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Reposition the screen: adım 25, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Reposition the screen: adım 25, 3 resimden 3.
    • Grip the right edge of the screen and open it like a book.
    • Don't pull up on the screen—the screen cables are still attached.
    • Lay the screen down over the left edge of the iPad.
    • Be careful not to strain the screen cables.
    FixBot'a Sor
    Yorum Ekle
  26. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the logic board cover: adım 26, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the logic board cover: adım 26, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the logic board cover: adım 26, 3 resimden 3.
    • The logic board cover is lightly adhered to the logic board.
    • Peel the cover off of the logic board to remove it.
    FixBot'a Sor
    Yorum Ekle
  27. iPad Pro 12.9" 5th Gen Front Camera Replacement, Unfasten the display brackets: adım 27, 1 resimden 1.
    • Use a Phillips screwdriver to remove the seven screws securing the top and bottom display brackets:
    • Four 1.1 mm-long screws
    • Two 2.0 mm-long screws
    • One 1.0 mm-long screw
    FixBot'a Sor
    Yorum Ekle
  28. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the display brackets: adım 28, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the display brackets: adım 28, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the display brackets: adım 28, 3 resimden 3.
    • Use tweezers, or your fingers, to remove the top and bottom display brackets.
    FixBot'a Sor
    Yorum Ekle
  29. iPad Pro 12.9" 5th Gen Front Camera Replacement, Disconnect the bottom display cables: adım 29, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Disconnect the bottom display cables: adım 29, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Disconnect the bottom display cables: adım 29, 3 resimden 3.
    • Use a spudger to pry up and disconnect the two bottom display cable press connectors.
    FixBot'a Sor
    Yorum Ekle
  30. iPad Pro 12.9" 5th Gen Front Camera Replacement, Disconnect the top display cables: adım 30, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Disconnect the top display cables: adım 30, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Disconnect the top display cables: adım 30, 3 resimden 3.
    • Use a spudger to pry up and disconnect the two top display cable press connectors.
    FixBot'a Sor
    Yorum Ekle
  31. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the screen: adım 31, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the screen: adım 31, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the screen: adım 31, 3 resimden 3.
    • Remove the screen.
    FixBot'a Sor
    Yorum Ekle
  32. iPad Pro 12.9" 5th Gen Front Camera Replacement, Unfasten the front camera bracket: adım 32, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three screws securing the front camera bracket to the logic board:
    • Two 1.1 mm-long screws
    FixBot'a Sor
    Yorum Ekle
  33. iPad Pro 12.9" 5th Gen Front Camera Replacement, Heat the front camera bracket: adım 33, 1 resimden 1.
    • The front camera bracket is adhered to the logic board.
    • Heat an iOpener and apply it to the front camera bracket for two minutes.
    FixBot'a Sor
    Yorum Ekle
  34. iPad Pro 12.9" 5th Gen Front Camera Replacement, Separate the bracket adhesive: adım 34, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Separate the bracket adhesive: adım 34, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Separate the bracket adhesive: adım 34, 3 resimden 3.
    • Insert an opening pick between the front camera bracket and the logic board.
    • Slide the pick toward the top of the iPad to separate the adhesive.
    FixBot'a Sor
    Yorum Ekle
  35. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the front camera bracket: adım 35, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the front camera bracket: adım 35, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the front camera bracket: adım 35, 3 resimden 3.
    • Slide the front camera bracket toward the right edge of the iPad to release its metal clip.
    • Remove the front camera bracket.
    • During reassembly, make sure the metal clip is secured under the logic board before continuing.
    FixBot'a Sor
    Yorum Ekle
  36. iPad Pro 12.9" 5th Gen Front Camera Replacement, Disconnect the front camera: adım 36, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Disconnect the front camera: adım 36, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Disconnect the front camera: adım 36, 3 resimden 3.
    • Use a spudger to pry up and disconnect the three front camera cable press connectors.
    FixBot'a Sor
    Yorum Ekle
  37. iPad Pro 12.9" 5th Gen Front Camera Replacement: adım 37, 2 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement: adım 37, 2 resimden 2.
    • The left-most front camera cable is lightly adhered to the frame.
    • Use tweezers, or your fingers, to peel the left-most cable off of the logic board.
    FixBot'a Sor
    Yorum Ekle
  38. iPad Pro 12.9" 5th Gen Front Camera Replacement, Unfasten the front camera: adım 38, 1 resimden 1.
    • Use a T3 Torx screwdriver to remove the two 2.2 mm-long screws securing the front camera.
    FixBot'a Sor
    Yorum Ekle
  39. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the front camera: adım 39, 3 resimden 1. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the front camera: adım 39, 3 resimden 2. iPad Pro 12.9" 5th Gen Front Camera Replacement, Remove the front camera: adım 39, 3 resimden 3.
    • The front camera is strongly adhered to the frame with heat-resistant epoxy. Work slowly to avoid damaging surrounding components.
    • Insert a spudger underneath the front camera, between the middle and right cables.
    • Twist the spudger to separate the epoxy securing the front camera.
    • This may require significant force.
    • Remove the front camera.
    • During reassembly, use a spudger to scrape off any remaining epoxy before reinstalling the front camera.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 12.9" 5th Generation Answers community for help.
Alex Diaz-Kokaisl
241.258 İtibar
1.180 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.665 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 73
Her zaman: 2,030
