Giriş
Use this guide to replace the USB-C charging port in your iPad Pro 12.9" 5th Gen.
This guide is written with an A2379 (Wi-Fi and LTE with mmWave) model iPad Pro. If you have the Wi‑Fi only model, use this guide as a general reference, but you may need to perform extra disassembly not covered in this guide.
Some photos show the battery connector blocked with two card strips. While this is an optional method, it's more reliable to fully discharge the battery. Ignore this visual discrepancy as you work through the guide.
Neye ihtiyacın var
Apply a heated iOpener to the right edge of the screen for two minutes.
Bu adımda kullanılan alet:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next step.
Apply a suction handle to the screen as close to the center of the right edge as possible.
Pull up on the suction handle with a strong, steady force to create a small gap between the frame and screen.
Insert an opening pick into the gap.
The first magnet begins about 3 cm from the top of the iPad.
The second magnet begins about 3 cm from the bottom of the iPad.
Slide your opening pick along the right edge of the screen to separate the adhesive.
Leave the pick inserted in the bottom right corner before continuing.
Slide your opening pick around the bottom right corner of the screen to separate the adhesive.
Leave your pick in the bottom right corner to prevent the adhesive from resealing.
Apply a heated iOpener to the bottom edge of the screen for two minutes.
Insert a second opening pick under the bottom right corner of the screen.
Slide your pick to the bottom left corner to separate the bottom adhesive.
Rotate your opening pick around the bottom left corner of the screen.
Leave your pick in the bottom left corner to prevent the adhesive from resealing.
Apply a heated iOpener to the left edge of the screen for two minutes.
The upper cutouts begin at 4 cm and 6 cm from the top of the frame.
The bottom cutouts begin at 4 cm and 6 cm from the bottom of the frame.
Insert a third opening pick under the bottom left corner of the screen.
Slide your pick to the top left corner to slice the left adhesive, making sure to avoid the cutouts shown in the previous step.
Leave the pick inserted in the top left corner before continuing.
Slide your opening pick around the top left corner of the screen.
Leave your pick in the top left corner to prevent the adhesive from resealing.
Apply a heated iOpener to the top edge of the screen for two minutes.
While the top edge adhesive softens, note the following:
There are two ambient light sensors near the corners. Don't insert your pick more than 1 mm here.
The front-facing camera and additional sensors are in the center of the top edge. Don't insert your pick here—there is less than 1 mm of adhesive and you may damage the components.
Slide your opening pick toward the top right edge, stopping just before the camera assembly.
Leave your pick inserted before continuing.
Grab two opposing corners of the screen and lift up to separate it from the frame.
Shift the screen towards the bottom right corner of the frame until the ribbon cable near the top edge is uncovered.
Bu adımda kullanılan alet:FixMat$36.95
Use a Phillips screwdriver to remove the two screws securing the upper cable shield:
One 1.8 mm-long screw
One 1.4 mm-long screw
Use tweezers or your fingers to grab and remove the upper cable shield.
Use the tip of a spudger to pry up and disconnect the upper sensors press connector.
Grip the right edge of the screen and open it like a book.
Lay the screen down over the left edge of the iPad.
Use a Phillips screwdriver to remove the seven screws securing the top and bottom display brackets:
Four 1.1 mm-long screws
Two 2.0 mm-long screws
One 1.0 mm-long screw
Use tweezers, or your fingers, to remove the top and bottom display brackets.
Use a spudger to pry up and disconnect the two bottom display cable press connectors.
Use a spudger to pry up and disconnect the two top display cable press connectors.
Use a spudger to pry up and disconnect the charging port cable press connector.
Insert an opening pick between the charging port cable and the logic board.
Slide the pick toward the charging port to separate the adhesive.
Use a Phillips screwdriver to remove the two 1.8 mm-long screws securing the charging port.
Use tweezers to remove the two small grounding clips next to the charging port.
Use your fingers to pull the charging port out of its slot in the frame.
Remove the charging port.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 12.9" 5th Generation Answers community for help.
Bir başkası bu kılavuzu tamamladı.
