Ana içeriğe geç
iPad mini 5 Wi-Fi Screen Replacement
Neye ihtiyacın var
  1. iPad mini 5 Wi-Fi Screen Replacement, Apply tape to a cracked screen: adım 1, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement, Apply tape to a cracked screen: adım 1, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement, Apply tape to a cracked screen: adım 1, 3 resimden 3.
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    FixBot'a Sor
    Yorum Ekle
  2. iPad mini 5 Wi-Fi Screen Replacement, Opening Procedure: adım 2, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  3. iPad mini 5 Wi-Fi Screen Replacement: adım 3, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 3, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement: adım 3, 3 resimden 3.
    • Apply a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
    FixBot'a Sor
    Yorum Ekle
  4. iPad mini 5 Wi-Fi Screen Replacement: adım 4, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 4, 2 resimden 2.
    • While holding the glass up with the suction cup, insert the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
    FixBot'a Sor
    Yorum Ekle
  5. iPad mini 5 Wi-Fi Screen Replacement: adım 5, 1 resimden 1.
    • Reheat and reapply the iOpener to the left edge for a few minutes.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
    FixBot'a Sor
    Yorum Ekle
  6. iPad mini 5 Wi-Fi Screen Replacement: adım 6, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 6, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement: adım 6, 3 resimden 3.
    • Insert a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
    FixBot'a Sor
    Yorum Ekle
  7. iPad mini 5 Wi-Fi Screen Replacement: adım 7, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 7, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement: adım 7, 3 resimden 3.
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
    FixBot'a Sor
    Yorum Ekle
  8. iPad mini 5 Wi-Fi Screen Replacement: adım 8, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 8, 2 resimden 2.
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
    FixBot'a Sor
    Yorum Ekle
  9. iPad mini 5 Wi-Fi Screen Replacement: adım 9, 1 resimden 1.
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
    FixBot'a Sor
    Yorum Ekle
  10. iPad mini 5 Wi-Fi Screen Replacement: adım 10, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 10, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement: adım 10, 3 resimden 3.
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
    FixBot'a Sor
    Yorum Ekle
  11. iPad mini 5 Wi-Fi Screen Replacement: adım 11, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 11, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement: adım 11, 3 resimden 3.
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • As you reach the front-facing camera, pull the pick out slightly and continue sliding it across the top edge.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
    FixBot'a Sor
    Yorum Ekle
  12. iPad mini 5 Wi-Fi Screen Replacement: adım 12, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 12, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement: adım 12, 3 resimden 3.
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a third pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the third pick in place to prevent the corner adhesive from re-sealing as it cools.
    FixBot'a Sor
    Yorum Ekle
  13. iPad mini 5 Wi-Fi Screen Replacement: adım 13, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 13, 2 resimden 2.
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
    FixBot'a Sor
    Yorum Ekle
  14. iPad mini 5 Wi-Fi Screen Replacement: adım 14, 1 resimden 1.
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
    FixBot'a Sor
    Yorum Ekle
  15. iPad mini 5 Wi-Fi Screen Replacement: adım 15, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 15, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement: adım 15, 3 resimden 3.
    • Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go.
    FixBot'a Sor
    Yorum Ekle
  16. iPad mini 5 Wi-Fi Screen Replacement: adım 16, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 16, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement: adım 16, 3 resimden 3.
    • Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary.
    • Be careful not to slice too deep near the bottom right corner, or you risk damaging the display cable.
    FixBot'a Sor
    Yorum Ekle
  17. iPad mini 5 Wi-Fi Screen Replacement: adım 17, 1 resimden 1.
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
    FixBot'a Sor
    Yorum Ekle
  18. iPad mini 5 Wi-Fi Screen Replacement: adım 18, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 18, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement: adım 18, 3 resimden 3.
    • Insert a new opening pick at the bottom right corner of the display, below the last opening pick you used to slice down the right edge.
    • Rotate the new pick around the lower right corner of the device.
    FixBot'a Sor
    Yorum Ekle
  19. iPad mini 5 Wi-Fi Screen Replacement: adım 19, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 19, 2 resimden 2.
    • Slide the pick from the bottom right corner along the lower edge of the device. Stop about half an inch shy of the home button.
    FixBot'a Sor
    Yorum Ekle
  20. iPad mini 5 Wi-Fi Screen Replacement: adım 20, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 20, 2 resimden 2.
    • Insert a final opening pick at the lower left corner of the iPad, directly below the existing one.
    FixBot'a Sor
    Yorum Ekle
  21. iPad mini 5 Wi-Fi Screen Replacement: adım 21, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 21, 2 resimden 2.
    • Slide the pick around the lower left edge of the iPad.
    FixBot'a Sor
    Yorum Ekle
  22. iPad mini 5 Wi-Fi Screen Replacement: adım 22, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 22, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement: adım 22, 3 resimden 3.
    • Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button.
    FixBot'a Sor
    Yorum Ekle
  23. iPad mini 5 Wi-Fi Screen Replacement: adım 23, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 23, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement: adım 23, 3 resimden 3.
    • Twist the two picks at the top edge of the iPad to break up the last of the adhesive holding the display assembly in place.
    • Lift the display from the top edge to open the device.
    FixBot'a Sor
    Yorum Ekle
  24. iPad mini 5 Wi-Fi Screen Replacement, Hold the screen perpendicular: adım 24, 1 resimden 1.
    • To avoid stressing any cables, hold the screen perpendicular to the frame.
    FixBot'a Sor
    Yorum Ekle
  25. iPad mini 5 Wi-Fi Screen Replacement, Remove the display cable bracket: adım 25, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Continue to hold the screen perpendicular during this step.
    • Use a Phillips screwdriver to remove the two 1.3 mm screws securing the display cable bracket.
    FixBot'a Sor
    Yorum Ekle
  26. iPad mini 5 Wi-Fi Screen Replacement, Reposition the screen: adım 26, 1 resimden 1.
    • You'll need to reposition the screen to access the bottom side of the display cable bracket.
    • Lower the screen to about 30 degrees above the frame.
    FixBot'a Sor
    Yorum Ekle
  27. iPad mini 5 Wi-Fi Screen Replacement, Disconnect the battery: adım 27, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement, Disconnect the battery: adım 27, 2 resimden 2.
    • The battery press connector is attached to the underside of the display cable bracket on the screw hole side.
    • Insert the flat end of a spudger under the display cable bracket and lift up to disconnect the battery press connector from the logic board.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • Don't try to remove the display cable bracket as it's attached to the battery by the battery cable.
    FixBot'a Sor
    Yorum Ekle
  28. iPad mini 5 Wi-Fi Screen Replacement, Rotate the display cable bracket: adım 28, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement, Rotate the display cable bracket: adım 28, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement, Rotate the display cable bracket: adım 28, 3 resimden 3.
    • The display cable bracket is secured by a clip under the edge of the frame.
    • Use a pair of tweezers to pull the display cable bracket's clip out from under the frame's edge.
    • Rotate the display cable bracket toward the battery.
    • Don't bend the battery cable too much past vertical to avoid damaging it. You only need enough space to disconnect the display press connectors and prevent the battery connector from making contact with its socket during the repair.
    FixBot'a Sor
    Yorum Ekle
  29. iPad mini 5 Wi-Fi Screen Replacement, Disconnect the display press connectors: adım 29, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement, Disconnect the display press connectors: adım 29, 2 resimden 2.
    • Use the pointed end of a spudger to disconnect the digitizer press connector from the logic board.
    FixBot'a Sor
    Yorum Ekle
  30. iPad mini 5 Wi-Fi Screen Replacement: adım 30, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 30, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement: adım 30, 3 resimden 3.
    • Use the pointed end of a spudger to disconnect the second and third display press connectors.
    FixBot'a Sor
    Yorum Ekle
  31. iPad mini 5 Wi-Fi Screen Replacement, Remove the screen: adım 31, 1 resimden 1.
    • Lift and remove the screen.
    FixBot'a Sor
    Yorum Ekle
  32. iPad mini 5 Wi-Fi Screen Replacement, Screen reassembly information: adım 32, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement, Screen reassembly information: adım 32, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement, Screen reassembly information: adım 32, 3 resimden 3.
    • During reassembly, remove any remaining adhesive and residue from the perimeters of the frame and the screen. Then, apply new adhesive to secure the screen to the frame.
    • Don't remove the black tape on the left, right, and upper edges of the display. These hold the display to the front glass.
    • Follow this guide if you are using a pre-cut adhesive card. Follow this guide if you are using custom-cut adhesives.
    FixBot'a Sor
    Yorum Ekle
  33. iPad mini 5 Wi-Fi Screen Replacement, Remove the ZIF connector sticker: adım 33, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement, Remove the ZIF connector sticker: adım 33, 2 resimden 2.
    • Use a pair of tweezers to remove the sticker covering the home button assembly ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  34. iPad mini 5 Wi-Fi Screen Replacement, Unlock the ZIF connector: adım 34, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement, Unlock the ZIF connector: adım 34, 2 resimden 2.
    • Use the pointed end of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button assembly ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  35. iPad mini 5 Wi-Fi Screen Replacement, Unplug the home button assembly ZIF connector: adım 35, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement, Unplug the home button assembly ZIF connector: adım 35, 2 resimden 2.
    • Use a pair of tweezers to pull the home button assembly cable out of the ZIF connector.
    FixBot'a Sor
    Yorum Ekle
  36. iPad mini 5 Wi-Fi Screen Replacement, Separate the home button assembly cable: adım 36, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement, Separate the home button assembly cable: adım 36, 2 resimden 2.
    • The home button assembly cable is secured to the screen with light adhesive.
    • Use an opening pick to separate the home button assembly cable from the screen.
    FixBot'a Sor
    Yorum Ekle
  37. iPad mini 5 Wi-Fi Screen Replacement: adım 37, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 37, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement: adım 37, 3 resimden 3.
    • Use an opening pick to continue separating the home button assembly cable from the screen.
    FixBot'a Sor
    Yorum Ekle
  38. iPad mini 5 Wi-Fi Screen Replacement, Pry off the home button bracket: adım 38, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement, Pry off the home button bracket: adım 38, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement, Pry off the home button bracket: adım 38, 3 resimden 3.
    E6000 Adhesive Glue
    $2.99
    • Use a plastic opening tool to pry the home button bracket off of the screen.
    • Use a pair of tweezers to lift and remove the home button bracket.
    • When reinstalling this bracket, use high bond glue such as E6000 to secure it to the screen.
    • Use a small clamp to hold the bracket to the screen during the curing duration.
    • Make sure to support the other edges of the screen while clamping the bracket to avoid breaking the screen.
    FixBot'a Sor
    Yorum Ekle
  39. iPad mini 5 Wi-Fi Screen Replacement, Heat the bottom of the screen: adım 39, 1 resimden 1.
    • Heat an iOpener and apply it to the bottom of the screen for two minutes to weaken the adhesive holding the home button in place.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the display—it is susceptible to heat damage.
    FixBot'a Sor
    Yorum Ekle
  40. iPad mini 5 Wi-Fi Screen Replacement, Remove the home button assembly: adım 40, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement, Remove the home button assembly: adım 40, 2 resimden 2.
    • The home button is held in place by a thin, delicate rubber gasket that is lightly adhered to the screen.
    • Slowly push the home button up and out through the back of the screen.
    • The home button will be hot. Wait until it's cool enough to touch before pushing it up.
    • Be careful to not push the gasket past its tearing point. If the adhesive is adequately heated, it will separate with gentle pressure.
    FixBot'a Sor
    Yorum Ekle
  41. iPad mini 5 Wi-Fi Screen Replacement: adım 41, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement: adım 41, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement: adım 41, 3 resimden 3.
    • Lift and remove the home button assembly.
    • You can reuse the home button gasket if it's sufficiently tacky. Otherwise, replace the black rubber gasket:
    • Peel the gasket off of the home button. Then, thread it past the cable to remove it.
    • Apply a replacement gasket to the home button.
    • The iPad mini 4's replacement gasket fits on the iPad mini 5, but it is slightly larger. Make sure it doesn't overlap the screen's adhesive so that the screen can be properly adhered to the frame.
    • To install the home button:
    • Rotate the home button so that the home button cable sits where it was before disassembly. Make sure the home button cable can be inserted into its ZIF connector.
    • Center the home button so that it fits into its slot in the screen. Then, press down firmly on the gasket to adhere it to the screen.
    FixBot'a Sor
    Yorum Ekle
  42. iPad mini 5 Wi-Fi Screen Replacement, Remove the magnetic sensor sticker: adım 42, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement, Remove the magnetic sensor sticker: adım 42, 2 resimden 2.
    • Use a pair of tweezers to remove the sticker covering the magnetic sensor solder pads.
    FixBot'a Sor
    Yorum Ekle
  43. iPad mini 5 Wi-Fi Screen Replacement, Desolder information: adım 43, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement, Desolder information: adım 43, 2 resimden 2.
    • In the next steps, you'll desolder the six solder pads securing the magnetic sensor to the screen.
    FixBot'a Sor
    Yorum Ekle
  44. iPad mini 5 Wi-Fi Screen Replacement, Apply polyimide tape: adım 44, 3 resimden 1. iPad mini 5 Wi-Fi Screen Replacement, Apply polyimide tape: adım 44, 3 resimden 2. iPad mini 5 Wi-Fi Screen Replacement, Apply polyimide tape: adım 44, 3 resimden 3.
    • Apply polyimide tape to the area around the magnetic sensor solder pads to protect the components from heat.
    FixBot'a Sor
    Yorum Ekle
  45. iPad mini 5 Wi-Fi Screen Replacement, Apply heat: adım 45, 1 resimden 1.
    • Use a soldering iron or hot air gun to apply heat evenly to the six magnetic sensor solder pads.
    FixBot'a Sor
    Yorum Ekle
  46. iPad mini 5 Wi-Fi Screen Replacement, Remove the magnetic sensor cable: adım 46, 2 resimden 1. iPad mini 5 Wi-Fi Screen Replacement, Remove the magnetic sensor cable: adım 46, 2 resimden 2.
    • When the solder on the solder pads is melted, use a pair of tweezers to separate the magnetic sensor from the screen.
    • If the solder isn't melted, apply more heat and try again.
    • When the area is cool enough to touch, remove the polyimide tape.
    • Use a pair of tweezers to remove the magnetic sensor cable.
    • The magnetic sensor cable is secured to the screen with light adhesive. Remove the magenetic sensor cable slowly to avoid damaging the cable under it.
    • During reassembly, apply a piece of polyimide tape under the solder pads while soldering the magnetic sensor to avoid damaging the screen.
    FixBot'a Sor
    Yorum Ekle
  47. iPad mini 5 Wi-Fi Screen Replacement, Only the screen remains: adım 47, 1 resimden 1.
    • After removing the home button and magnetic sensor, only the screen remains.
    • Note that this image shows the magnetic sensor still installed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 5 Answers community for help.
15 farklı kişi bu kılavuzu tamamladı.
Kyle Smith
52.475 İtibar
124 adet Kılavuz yazıldı
5Kılavuz Yorumları
is it possible to buy the screen with the magnetic sensor already on it?
Mushfik ali - Yanıt Paylaş
Yes, if it is in stock.
Ethan Queen - Yanıt Paylaş
hello sir
I want to replace my ipad with another apple products
its possible or no ?
Yama Yamini - Yanıt Paylaş
Thanks so much for this. I had a variable response touch screen issue following a Tech repair (2 blown capacitors) and I suspected that the screen connectors had not been firmly reseated during reassembly.
Using this excellent tutorial I was easily able to remove the screen and carefully reseat the connectors.
I’ve been using it for a while now with no further issues.
Thanks again, great service!
Mike Floutier - Yanıt Paylaş
I am having great difficulty placing the home button bracket to line up perfectly with the raised/unraised area of the charging port. Any tips? This is the 2nd screen and it stays lifted up at the bottom. There is no glass in the way. I've never had this issue. So frustrating
Myra Augustine - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 100
Son 30 gün: 794
Her zaman: 37,741
