Giriş
Follow this guide to replace the screen on an iPad mini 5 Wi-Fi. You may need to do this if the screen is cracked or has stopped working.
This guide also shows how to transfer the original home button and magnetic sensor to the replacement part.
Note that only the iPad’s original home button assembly will be capable of Touch ID functionality. If you would like to maintain Touch ID functionality, you’ll need to transfer your original home button assembly to the new screen.
Some replacement screens don't come with a magnetic sensor installed. Without a magnetic sensor, the iPad won’t be able to sleep and wake when using a Smart Cover. It may also cause the power button to not be able to sleep and wake the iPad. AssistiveTouch may also lose its sleep and wake functionality. Without a magnetic sensor, holding down the power button to prompt the power off slider will still wake the screen. The home button will also still wake the screen.
Transferring the magnetic sensor requires advanced soldering skills. The magnetic sensor cable is soldered to the screen. Make sure to follow soldering safety procedures such as wearing eye protection, working in a well-ventilated area, and washing your hands with soap and water after soldering.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.
Neye ihtiyacın var
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Leave the opening pick in the iPad slightly past the front-facing camera.
Take a third pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
Leave the third pick in place to prevent the corner adhesive from re-sealing as it cools.
To avoid stressing any cables, hold the screen perpendicular to the frame.
Bu adımda kullanılan alet:Magnetic Project Mat$16.96
Use a Phillips screwdriver to remove the two 1.3 mm screws securing the display cable bracket.
Insert the flat end of a spudger under the display cable bracket and lift up to disconnect the battery press connector from the logic board.
Bu adımda kullanılan alet:Tweezers$4.99
Use a pair of tweezers to pull the display cable bracket's clip out from under the frame's edge.
Rotate the display cable bracket toward the battery.
Use the pointed end of a spudger to disconnect the digitizer press connector from the logic board.
Don't remove the black tape on the left, right, and upper edges of the display. These hold the display to the front glass.
Use a pair of tweezers to remove the sticker covering the home button assembly ZIF connector.
Use the pointed end of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button assembly ZIF connector.
Use a pair of tweezers to pull the home button assembly cable out of the ZIF connector.
Use an opening pick to separate the home button assembly cable from the screen.
Bu adımda kullanılan alet:E6000 Adhesive Glue$2.99
Use a plastic opening tool to pry the home button bracket off of the screen.
Use a pair of tweezers to lift and remove the home button bracket.
Use a small clamp to hold the bracket to the screen during the curing duration.
Heat an iOpener and apply it to the bottom of the screen for two minutes to weaken the adhesive holding the home button in place.
Slowly push the home button up and out through the back of the screen.
Lift and remove the home button assembly.
Peel the gasket off of the home button. Then, thread it past the cable to remove it.
Apply a replacement gasket to the home button.
Rotate the home button so that the home button cable sits where it was before disassembly. Make sure the home button cable can be inserted into its ZIF connector.
Center the home button so that it fits into its slot in the screen. Then, press down firmly on the gasket to adhere it to the screen.
Use a pair of tweezers to remove the sticker covering the magnetic sensor solder pads.
In the next steps, you'll desolder the six solder pads securing the magnetic sensor to the screen.
Apply polyimide tape to the area around the magnetic sensor solder pads to protect the components from heat.
Use a soldering iron or hot air gun to apply heat evenly to the six magnetic sensor solder pads.
When the solder on the solder pads is melted, use a pair of tweezers to separate the magnetic sensor from the screen.
When the area is cool enough to touch, remove the polyimide tape.
Use a pair of tweezers to remove the magnetic sensor cable.
After removing the home button and magnetic sensor, only the screen remains.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 5 Answers community for help.
13 farklı kişi bu kılavuzu tamamladı.
5Kılavuz Yorumları
is it possible to buy the screen with the magnetic sensor already on it?
Yes, if it is in stock.
hello sir
I want to replace my ipad with another apple products
its possible or no ?
Thanks so much for this. I had a variable response touch screen issue following a Tech repair (2 blown capacitors) and I suspected that the screen connectors had not been firmly reseated during reassembly.
Using this excellent tutorial I was easily able to remove the screen and carefully reseat the connectors.
I’ve been using it for a while now with no further issues.
Thanks again, great service!
I am having great difficulty placing the home button bracket to line up perfectly with the raised/unraised area of the charging port. Any tips? This is the 2nd screen and it stays lifted up at the bottom. There is no glass in the way. I've never had this issue. So frustrating
