Ana içeriğe geç
iPhone 11 Charging Port Replacement
Neye ihtiyacın var
  1. iPhone 11 Charging Port Replacement, Remove the pentalobe screws: adım 1, 2 resimden 1. iPhone 11 Charging Port Replacement, Remove the pentalobe screws: adım 1, 2 resimden 2.
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    the right screws wouldn’t come off
    Yusef San Inocencio - Yanıt
    ok one came of but my right wont come of either!!!!
    Aisa Jawara -
    Hello guys, I still haven't found away to power off the iphone without using the screen. Cheers!
    danielaguirre93 - Yanıt
    You can try this.
    Quickly Press and release the volume up button.
    then Quickly Press and release the volume down button.
    then press and hold the power button and wait until it turns off.
    worked for me :D
    Benóný Egilson - Yanıt
    Where does one get replacement seals? Is this the same as the display assembly adhesive?
    Brian Baker - Yanıt
    not of the screwdrivers i have seem to be able to turn the screws
    Aisa Jawara - Yanıt
    how do you change battery of an iPhone 11 and still the battery health shows, do you use a software for that?
    Great Me - Yanıt
    Battery health won’t show on a non Apple battery.
    DON’T forget to discharge old battery before removing it. Very impressive fire (and smoke!) if you puncture it. Ask me how I know
    Doug Harrowing - Yanıt
  2. iPhone 11 Charging Port Replacement, Tape over any cracks: adım 2, 3 resimden 1. iPhone 11 Charging Port Replacement, Tape over any cracks: adım 2, 3 resimden 2. iPhone 11 Charging Port Replacement, Tape over any cracks: adım 2, 3 resimden 3.
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  3. iPhone 11 Charging Port Replacement, Anti-Clamp instructions: adım 3, 3 resimden 1. iPhone 11 Charging Port Replacement, Anti-Clamp instructions: adım 3, 3 resimden 2. iPhone 11 Charging Port Replacement, Anti-Clamp instructions: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the top, and one on the bottom.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 11 Charging Port Replacement: adım 4, 3 resimden 1. iPhone 11 Charging Port Replacement: adım 4, 3 resimden 2. iPhone 11 Charging Port Replacement: adım 4, 3 resimden 3.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone 11 Charging Port Replacement: adım 5, 3 resimden 1. iPhone 11 Charging Port Replacement: adım 5, 3 resimden 2. iPhone 11 Charging Port Replacement: adım 5, 3 resimden 3.
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Any suggestions if the screen is broken and the anti-clamp just separates the screen from the bezel?
    Nathan Friedly - Yanıt
  6. iPhone 11 Charging Port Replacement, Heat the lower edge of the phone: adım 6, 1 resimden 1.
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
    어짜피 못쓰고 버릴 거라면, 이것보다 인두기를 직접 대는 방식을 추천 합니다. 어짜피 유리라 연기나 반응도 없고 무엇보다 금방 열기가 올라와요.
    코딩의달인 - Yanıt
    Gut gehen auch Kirschkernsäckchen. Damit hatte ich Erfolg!
    Hoetgen - Yanıt
  7. iPhone 11 Charging Port Replacement: adım 7, 2 resimden 1. iPhone 11 Charging Port Replacement: adım 7, 2 resimden 2.
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  8. iPhone 11 Charging Port Replacement, Lift the display slightly: adım 8, 3 resimden 1. iPhone 11 Charging Port Replacement, Lift the display slightly: adım 8, 3 resimden 2. iPhone 11 Charging Port Replacement, Lift the display slightly: adım 8, 3 resimden 3.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap under the screen and the plastic bezelnot the screen itself.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    This turned out to be the most difficult part for me. My old ifixit suction cup didn't suck hard enough to generate enough force to pry the display from the case. I ended up applying heat at least a dozen times, and I had to pull up on the suction cup forcefully over and over and over while repositioning it several times. I finally had success inserting my pick into the tiny gap after 30 or so rapid tugs on the suction cup.
    matthew r - Yanıt
    I pulled the screen by accident instead of the bottom layer, now what?
    Alvaro - Yanıt
    I have the same question
    Konstantinos Solakoglou -
    After heating (I used a hair dryer for 4-5 mins, moving around whole frame, to make sure was pretty hot, then let sit for 1 minute), insert a razor blade between the bezel and the frame, at the bottom edge. Lever upwards, the screen will easily pull away. You won’t even need the suction cup.
    Damian - Yanıt
  9. iPhone 11 Charging Port Replacement, Separate the screen adhesive: adım 9, 3 resimden 1. iPhone 11 Charging Port Replacement, Separate the screen adhesive: adım 9, 3 resimden 2. iPhone 11 Charging Port Replacement, Separate the screen adhesive: adım 9, 3 resimden 3.
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  10. iPhone 11 Charging Port Replacement, Screen information: adım 10, 1 resimden 1.
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  11. iPhone 11 Charging Port Replacement: adım 11, 3 resimden 1. iPhone 11 Charging Port Replacement: adım 11, 3 resimden 2. iPhone 11 Charging Port Replacement: adım 11, 3 resimden 3.
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Instructions are confusing as the last step says not to insert at certain points, while this says to slide all the way up the right side - is it that sliding is ok but inserting isn't (whatever that might mean) or just not more than 3mm?
    Peter Hill - Yanıt
    Just slide slightly and the display will rise without problems on all iPhone models, sometimes if I have long nails I even insert a fingernail and lift the display.
    Tonynox -
  12. iPhone 11 Charging Port Replacement: adım 12, 3 resimden 1. iPhone 11 Charging Port Replacement: adım 12, 3 resimden 2. iPhone 11 Charging Port Replacement: adım 12, 3 resimden 3.
    • The top edge of the display is secured with both glue and clips.
    • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
    • Insert your pick into the top-right corner of the phone.
  13. iPhone 11 Charging Port Replacement: adım 13, 2 resimden 1. iPhone 11 Charging Port Replacement: adım 13, 2 resimden 2.
    • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
    • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
    • Don't insert your pick more than 3 mm, as you may damage the Face ID sensor array.
  14. iPhone 11 Charging Port Replacement, Remove the suction cup: adım 14, 1 resimden 1.
    • Pull the small nub on the suction cup to detach it from the front panel.
  15. iPhone 11 Charging Port Replacement, Open the iPhone: adım 15, 3 resimden 1. iPhone 11 Charging Port Replacement, Open the iPhone: adım 15, 3 resimden 2. iPhone 11 Charging Port Replacement, Open the iPhone: adım 15, 3 resimden 3.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Prop the display up against something sturdy.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  16. iPhone 11 Charging Port Replacement, Display Assembly: adım 16, 2 resimden 1. iPhone 11 Charging Port Replacement, Display Assembly: adım 16, 2 resimden 2.
    • To access the screws in the following step, tilt the display by slightly lifting its lower edge.
    • Be careful not to strain or tear the display cables.
  17. iPhone 11 Charging Port Replacement, Unscrew the battery connector cover: adım 17, 2 resimden 1. iPhone 11 Charging Port Replacement, Unscrew the battery connector cover: adım 17, 2 resimden 2.
    Magnetic Project Mat
    $19.95
    • Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    During reassembly, I had to connect my phone to the charger before it would power up.
    Austin Culberson - Yanıt
    Die Schrauben sind wahnsinnig kurz, tatsächlich winzig klein. Nach dem Herausdrehen könnte es im ersten Moment so aussehen, als habe man die Schrauben ausgebohrt anstatt herauszudrehen, sie sind jedoch sehr schnell gelöst und liegen dann entweder im Gehäuse oder sind neben dem Gehäuse herausgefallen. In jedem Fall sollten sie nie auf den Boden fallen, da sie dann kaum mehr auffindbar wären.
    Bernd Sonneck - Yanıt
    I got to this point thinking/hoping I could eek by with a Y1 orY0 or even a PH000 driver but no such luck. The Y000 is in fact necessary. Finishing this repair will have to wait for now.
    ALSO thanks Apple, there is ABSOLUTELY no reason AT. ALL. to use so many random, oddball screw heads, BUT to make self repairs more difficult and expensive. A real F-U to the consumer!
    John M - Yanıt
  18. iPhone 11 Charging Port Replacement, Remove the battery connector cover: adım 18, 1 resimden 1.
    • Remove the bracket.
  19. iPhone 11 Charging Port Replacement, Disconnect the battery: adım 19, 2 resimden 1. iPhone 11 Charging Port Replacement, Disconnect the battery: adım 19, 2 resimden 2.
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
  20. iPhone 11 Charging Port Replacement, Unscrew the logic board cover screws: adım 20, 2 resimden 1. iPhone 11 Charging Port Replacement, Unscrew the logic board cover screws: adım 20, 2 resimden 2.
    • Use a Y000 driver to remove the five 1.1 mm screws securing the logic board cover bracket.
  21. iPhone 11 Charging Port Replacement, Remove the logic board cover bracket: adım 21, 1 resimden 1.
  22. iPhone 11 Charging Port Replacement, Disconnect the display: adım 22, 3 resimden 1. iPhone 11 Charging Port Replacement, Disconnect the display: adım 22, 3 resimden 2. iPhone 11 Charging Port Replacement, Disconnect the display: adım 22, 3 resimden 3.
    • Use a spudger or a fingernail to disconnect the LCD panel cable connector.
    • Disconnect the digitizer connector next to it.
    Be mindful when reconnecting LCD panel connector and digitizer connector. It’s looks very similar. These 2 ribbon connectors a slightly different.
    Pay attention.
    Josmaknolavic - Yanıt
    내 아이폰이 디스플레이 분리 단계를 거친 후, 전원이 들어오지 않습니다. 층전기를 꽂아도 배터리에 미세한 전기 반응이 느껴지지 않고, 탭틱 엔진도 작동하지 않게 되었습니다. cpu 온도는 여전히 뜨껍습니다. 내 마더보드가 디스플레이 분리 후 갑자기 고장난건가요?
    Protoncal - Yanıt
    Hast Du das Problem gelöst?
    Bernd Sonneck -
    커넥터 핀을 빼거나 다시 넣기 위해 구부러졌을 수 있습니다. 핀이 구부러진 경우 돋보기 등으로 살펴보고, 그렇다면 적절한 매장에 가져가세요.
    Hampter -
    Hier war mein Problem schon gelöst. Durch einen Sturz hat sich der Touchscreen Stecker gelöst. Wieder eingesteckt funktionierte die Touch-Eingabe wieder.
    Hoetgen - Yanıt
  23. iPhone 11 Charging Port Replacement, Disconnect the front sensors: adım 23, 2 resimden 1. iPhone 11 Charging Port Replacement, Disconnect the front sensors: adım 23, 2 resimden 2.
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
    There needs to be an extra step between 24 and 25 for reassembly, telling folks to apply adhesive here. I got the thing almost all the way put back together before realizing that the adhesive was a single piece that needs the cables to be disconnected in order to apply it.
  24. iPhone 11 Charging Port Replacement, Remove the display assembly: adım 24, 1 resimden 1.
    After this step its probably a good idea to test the new screen (you dont have to plug in the front camera assembly)
    Richard Kraus - Yanıt
    Not a technician, so correct me if I'm wrong: I think that it's at this step of reassembly (before you reattach the screen) that you apply waterproof glue, if you have it.
    Athanasius Pernath - Yanıt
    You are both correct. Testing the screen before putting on adhesive means the screen can be returned if faulty. Many places will not accept a screen return that has adhesive on it.
    So if it works apply adhesive at this point. When testing don’t just rely on Apple logo test touch functionality also .
    Daniel - Yanıt
  25. iPhone 11 Charging Port Replacement, Remove the lower bracket screws: adım 25, 2 resimden 1. iPhone 11 Charging Port Replacement, Remove the lower bracket screws: adım 25, 2 resimden 2.
    • Using a Phillips driver, remove the five screws securing the bracket below the Taptic engine and speaker:
    • Four 1.6 mm screws
    • One 1.3 mm screw
    The top right screw (1.6 mm marked red) is actually different from the other three 1.6mm screws as it's thread is slightly thicker.
    Florian - Yanıt
    yep same experience here
    Kai Mcpherson -
    Yes, same here. The guide should be updated.
    Maximilien Tirard - Yanıt
    me too same Experience
    Milchgl_s - Yanıt
  26. iPhone 11 Charging Port Replacement, Remove the lower bracket: adım 26, 1 resimden 1.
    • Remove the lower bracket.
  27. iPhone 11 Charging Port Replacement, Remove the Taptic Engine connector tape: adım 27, 3 resimden 1. iPhone 11 Charging Port Replacement, Remove the Taptic Engine connector tape: adım 27, 3 resimden 2. iPhone 11 Charging Port Replacement, Remove the Taptic Engine connector tape: adım 27, 3 resimden 3.
    • Use tweezers to lift and remove the black tape and rubber pad covering the Taptic Engine connector.
    • Use a little heat from a hair dryer or iOpener to make the tape easier to peel up and re-adhere later.
  28. iPhone 11 Charging Port Replacement, Unscrew the lower speaker: adım 28, 2 resimden 1. iPhone 11 Charging Port Replacement, Unscrew the lower speaker: adım 28, 2 resimden 2.
    • Remove the five screws securing the speaker and brackets:
    • One 1.9 mm Phillips screw
    • One 2.3 mm Phillips screw
    • One 3.1 mm standoff screw
    • Two 1.6 mm Phillips screws
    In my experience, the two green screws are not interchangeable
    PJ McConnell - Yanıt
    the two green srews are not equally thic
    Theo - Yanıt
    Wtf? I buy a repair kit and it doesn’t have all the screwdrivers I need?
    JMD - Yanıt
    The repair kit does not have bits for all the screws
    marios - Yanıt
    The battery kit includes the bit for the standoff screw marked in yellow.
    marc - Yanıt
    I can't get it to remove with any of the three provided bits. Doesn't even engage.
    Carey Dissmore -
    The green screw for the ground clip is longer than the second green screw. Keep the ground clip with that screw
    marc - Yanıt
  29. iPhone 11 Charging Port Replacement, Remove the grounding clip: adım 29, 2 resimden 1. iPhone 11 Charging Port Replacement, Remove the grounding clip: adım 29, 2 resimden 2.
    • Remove the small grounding clip on the top right corner of the speaker.
    Salut comment je peux trouver cette pièce ?
    kenyfaya973 - Yanıt
  30. iPhone 11 Charging Port Replacement, Remove the Taptic Engine connector cover: adım 30, 1 resimden 1.
    • Remove the Taptic Engine connector cover.
  31. iPhone 11 Charging Port Replacement, Remove the speaker standoff screw: adım 31, 3 resimden 1. iPhone 11 Charging Port Replacement, Remove the speaker standoff screw: adım 31, 3 resimden 2. iPhone 11 Charging Port Replacement, Remove the speaker standoff screw: adım 31, 3 resimden 3.
    • Lift and push aside the small board covering the remaining speaker screw in the bottom right corner of the iPhone.
    • Remove the 2.4 mm standoff screw underneath.
    Use the standoff bit that should be in the box with the battery and adhesive.
    marc - Yanıt
  32. iPhone 11 Charging Port Replacement, Loosen the speaker: adım 32, 2 resimden 1. iPhone 11 Charging Port Replacement, Loosen the speaker: adım 32, 2 resimden 2.
    • Insert a spudger under the top edge of the speaker, near the edge of the iPhone's case.
    • Gently pry up and lift the top edge of the speaker.
  33. iPhone 11 Charging Port Replacement: adım 33, 2 resimden 1. iPhone 11 Charging Port Replacement: adım 33, 2 resimden 2.
    • Hold the speaker by its side edges and rock it side-to-side, separating the adhesive securing it to the bottom edge of the iPhone.
    • Pull the speaker away from the bottom edge of the iPhone until the adhesive gasket separates.
    You want to pull the speaker out exactly as they have shown. If you rock it the other way, it will pull off the board that's not mentioned, but still pictured against the edge of the phone. Also, the kit frustratingly doesn't include the speaker gasket. So get that before you start, or you'll be remolding the used gasket.
    Tim Taylor - Yanıt
  34. iPhone 11 Charging Port Replacement, Remove the speaker: adım 34, 2 resimden 1. iPhone 11 Charging Port Replacement, Remove the speaker: adım 34, 2 resimden 2.
    • Remove the speaker.
    • Optionally, to help protect against water and dust intrusion, replace the speaker's adhesive gasket during reassembly:
    • Peel away any remaining adhesive with tweezers.
    • Prep the area underneath by cleaning it with a bit of isopropyl alcohol and a lint-free cloth or coffee filter so that the gasket adheres properly.
    • Install a new gasket onto the speaker, and then install the speaker.
    It seems that a bracket which held a screw to the charging port is holding the part to the phone even though adhesive and all screws are removed, not sure why but I can't remove the speaker. I had this same problem with another bracket of the speaker which held a screw but ripped it off the lower speaker part as i couldn't get it unattached from the screw port. All screws and adhesive were removed, I don't understand what is wrong
    Daniel Frey - Yanıt
    do you sell the speaker's adhesive gasket replacement?
    thuan nguyen - Yanıt
    Do you sell the speaker adhesive? It's unfortunate to have gotten this far and feel ill prepared to replace something that seems very important. You guys should have included it or indicated it as a highly recommended option.
    stevenalias - Yanıt
    Im Reparatur-Kit ist keine Ersatzdichtung für den Lautsprecher enthalten! 😢
  35. iPhone 11 Charging Port Replacement, Unscrew the Taptic Engine: adım 35, 2 resimden 1. iPhone 11 Charging Port Replacement, Unscrew the Taptic Engine: adım 35, 2 resimden 2.
    • Use a Phillips driver to remove the two 1.8 mm screws securing the Taptic Engine.
  36. iPhone 11 Charging Port Replacement, Disconnect the Taptic Engine: adım 36, 2 resimden 1. iPhone 11 Charging Port Replacement, Disconnect the Taptic Engine: adım 36, 2 resimden 2.
    • Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
  37. iPhone 11 Charging Port Replacement, Remove the Taptic Engine: adım 37, 1 resimden 1.
    • Remove the Taptic Engine.
  38. iPhone 11 Charging Port Replacement, Removing the port: adım 38, 1 resimden 1.
    • Unscrew the two Phillips screws.
    • Remove the charging port with tweezers.
    This guide is missing a few steps. Here’s a video with a complete guide:
    https://youtu.be/RGGxuIS4SV8?si=3BsLha9i...
    Thank me later
    Chris Cruz - Yanıt
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Bruno Garcia
314 İtibar
1 Kılavuz yazıldı
Ekip
4Kılavuz Yorumları
Ummm, is it just me, or is he skipping a lot of steps after removing the screen? Lmao
Riley Steed - Yanıt
Yes. Use this video for a complete guide:
Chris Cruz -
There are tons of steps missing, my god. Like removing the sim card holder, the speaker and mics, the jig below the taptic engine, yikes. This is no help.
plex - Yanıt
There are a lot of steps missing.
The video posted by Chris Cruz is great. This tutorial is not great.
Francisco José Borrazás - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 71
Son 7 gün: 540
Son 30 gün: 2,128
Her zaman: 24,415
