Ana içeriğe geç
iPhone 15 Front Camera Assembly Replacement
Clay Eickemeyer
Clay Eickemeyer ve 3 diğer katkıda bulunanlar
En son February 2, 2025 tarihinde güncellendi
1 - 2 saat
Orta
Use this guide to replace the front camera assembly in your iPhone 15.
This assembly includes the front-facing camera and Face ID hardware. These parts come as one unit, and the sensors are uniquely paired to your logic board. Note: If you replace this part, Face ID will no longer work. This repair will restore a broken selfie cam to working order, but on iOS 17.6 and earlier, only Apple or an Apple “authorized” technician can restore Face ID. On iOS 18 and newer, you can recalibrate genuine front-facing cameras using Apple's Repair Assistant.
You'll need replacement back glass adhesive to complete this repair.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. iPhone 15 Front Camera Assembly Replacement, Prepare your phone for disassembly: adım 1, 2 resimden 1. iPhone 15 Front Camera Assembly Replacement, Prepare your phone for disassembly: adım 1, 2 resimden 2.
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Front Camera Assembly Replacement, Tape over any cracks: adım 2, 2 resimden 1. iPhone 15 Front Camera Assembly Replacement, Tape over any cracks: adım 2, 2 resimden 2.
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Front Camera Assembly Replacement, Mark your opening picks: adım 3, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Mark your opening picks: adım 3, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Mark your opening picks: adım 3, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 15 Front Camera Assembly Replacement, Remove the pentalobe screws: adım 4, 2 resimden 1. iPhone 15 Front Camera Assembly Replacement, Remove the pentalobe screws: adım 4, 2 resimden 2.
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  5. iPhone 15 Front Camera Assembly Replacement, Secure the screen: adım 5, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Secure the screen: adım 5, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Secure the screen: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next four steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down four steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • The Anti-Clamp applies suction to both the screen and the back glass. To open only the back glass, you need to secure the screen with tape. You can also check out the full instructions on how to use this tape.
    • Cut two strips of tape, apply them along the long edges of the phone, and fold them over the screen to secure it.
  6. iPhone 15 Front Camera Assembly Replacement, Secure an Anti-Clamp: adım 6, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Secure an Anti-Clamp: adım 6, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Secure an Anti-Clamp: adım 6, 3 resimden 3.
    • Pull the Anti-Clamp's blue handle backward to unlock the arms.
    • With the back glass facing up, slide the arms over the right edge of your phone, with one suction cup on the back glass and the other on the screen. Center the suction cups near the bottom edge.
    • Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
    • Squeeze the cups together to create suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  7. iPhone 15 Front Camera Assembly Replacement, Create a gap under the back glass: adım 7, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Create a gap under the back glass: adım 7, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Create a gap under the back glass: adım 7, 3 resimden 3.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle one full turn (360 degrees) or until the cups start to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
    • If you don't have tape, you may warm up the suction cups to help them stick.
  8. iPhone 15 Front Camera Assembly Replacement, Insert an opening pick: adım 8, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Insert an opening pick: adım 8, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Insert an opening pick: adım 8, 3 resimden 3.
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    • Wait up to a minute for the adhesive to separate and a gap to form between the back glass and the frame.
    • If a gap doesn't appear after one minute, apply more heat and rotate the handle a quarter turn. Let the Anti-Clamp and time do the work for you.
    • Insert an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  9. iPhone 15 Front Camera Assembly Replacement, Heat the bottom edge: adım 9, 1 resimden 1.
  10. iPhone 15 Front Camera Assembly Replacement, Insert an opening pick: adım 10, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Insert an opening pick: adım 10, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Insert an opening pick: adım 10, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  11. iPhone 15 Front Camera Assembly Replacement, Back glass information: adım 11, 1 resimden 1.
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
  12. iPhone 15 Front Camera Assembly Replacement, Separate the bottom edge adhesive: adım 12, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Separate the bottom edge adhesive: adım 12, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Separate the bottom edge adhesive: adım 12, 3 resimden 3.
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  13. iPhone 15 Front Camera Assembly Replacement, Heat the right edge: adım 13, 1 resimden 1.
    • Heat the right edge of the back glass until it's hot to the touch.
  14. iPhone 15 Front Camera Assembly Replacement, Separate the bottom right corner adhesive: adım 14, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Separate the bottom right corner adhesive: adım 14, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Separate the bottom right corner adhesive: adım 14, 3 resimden 3.
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it to the volume down button or until you feel a hard stop at a large clip securing the back glass.
    • Don't slice past the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  15. iPhone 15 Front Camera Assembly Replacement, Heat the left edge: adım 15, 1 resimden 1.
    • Heat the left edge of the back glass until it's hot to the touch.
  16. iPhone 15 Front Camera Assembly Replacement, Separate the left edge adhesive: adım 16, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Separate the left edge adhesive: adım 16, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Separate the left edge adhesive: adım 16, 3 resimden 3.
    • Along the left edge, don't insert your pick deeper than 5 mm.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
  17. iPhone 15 Front Camera Assembly Replacement, Heat the top edge: adım 17, 1 resimden 1.
    • Heat the top edge of the back glass until it's hot to the touch.
  18. iPhone 15 Front Camera Assembly Replacement, Separate the top edge adhesive: adım 18, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Separate the top edge adhesive: adım 18, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Separate the top edge adhesive: adım 18, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
  19. iPhone 15 Front Camera Assembly Replacement, Heat the top right corner: adım 19, 1 resimden 1.
    • Heat the top right corner of the back glass until it's hot to the touch.
  20. iPhone 15 Front Camera Assembly Replacement, Separate the top right corner adhesive: adım 20, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Separate the top right corner adhesive: adım 20, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Separate the top right corner adhesive: adım 20, 3 resimden 3.
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
  21. iPhone 15 Front Camera Assembly Replacement, Swing open the back glass: adım 21, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Swing open the back glass: adım 21, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Swing open the back glass: adım 21, 3 resimden 3.
    • Gently swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
  22. iPhone 15 Front Camera Assembly Replacement, Unfasten the lower connector cover: adım 22, 1 resimden 1.
    FixMat
    $36.95
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
  23. iPhone 15 Front Camera Assembly Replacement, Remove the lower connector cover: adım 23, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Remove the lower connector cover: adım 23, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Remove the lower connector cover: adım 23, 3 resimden 3.
    • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
    • Remove the cover.
    • During reassembly, latch the top edge of the cover onto its slot on the logic board before securing it with its screw.
  24. iPhone 15 Front Camera Assembly Replacement, Disconnect the battery: adım 24, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Disconnect the battery: adım 24, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Disconnect the battery: adım 24, 3 resimden 3.
    • Hold the back glass upright with one hand and rotate it just enough to reveal the battery press connector just below the volume buttons.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
    • A plus and minus sign is printed on the head of this connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
  25. iPhone 15 Front Camera Assembly Replacement, Unfasten the middle connector cover: adım 25, 2 resimden 1. iPhone 15 Front Camera Assembly Replacement, Unfasten the middle connector cover: adım 25, 2 resimden 2.
    • Use your tri-point Y000 driver to remove the 0.9 mm-long screw securing the middle connector cover.
  26. iPhone 15 Front Camera Assembly Replacement, Remove the cover: adım 26, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Remove the cover: adım 26, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Remove the cover: adım 26, 3 resimden 3.
    • Use the flat end of a spudger or your finger to push the cover toward the bottom of the phone and unclip its top edge.
    • Remove the cover.
    • During reassembly, place the cover so its tab is just behind the clip on the logic board. Press down with one finger and slide the cover forward to engage the clip.
  27. iPhone 15 Front Camera Assembly Replacement, Disconnect the wireless charging coil: adım 27, 2 resimden 1. iPhone 15 Front Camera Assembly Replacement, Disconnect the wireless charging coil: adım 27, 2 resimden 2.
    • Use an opening pick to pry up and disconnect the wireless charging coil and NFC connector.
  28. iPhone 15 Front Camera Assembly Replacement, Remove the back glass: adım 28, 1 resimden 1.
    • Remove the back glass.
    • During reassembly:
    • This is a good point to test your repair before sealing up your phone. Temporarily reconnect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down and continue reassembly.
    • Use this guide to reapply adhesive and install your back glass.
  29. iPhone 15 Front Camera Assembly Replacement, Remove the upper connector cover: adım 29, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Remove the upper connector cover: adım 29, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Remove the upper connector cover: adım 29, 3 resimden 3.
    • Use your tri-point Y000 driver to remove the two 1.3 mm screws securing the upper connector cover.
    • Remove the cover.
  30. iPhone 15 Front Camera Assembly Replacement, Disconnect the front camera and sensors: adım 30, 3 resimden 1. iPhone 15 Front Camera Assembly Replacement, Disconnect the front camera and sensors: adım 30, 3 resimden 2. iPhone 15 Front Camera Assembly Replacement, Disconnect the front camera and sensors: adım 30, 3 resimden 3.
    • Use the tip of an opening pick to pry up and disconnect the antenna, front sensors, and front camera press connectors (three connectors in total).
  31. iPhone 15 Front Camera Assembly Replacement, Remove the front camera and sensors: adım 31, 2 resimden 1. iPhone 15 Front Camera Assembly Replacement, Remove the front camera and sensors: adım 31, 2 resimden 2.
    • Use tweezers or your fingers to pull the front camera and sensors out of their recess in the frame and remove them.
Sonuç
To reassemble your phone, follow these instructions in reverse order.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Clay Eickemeyer
82.893 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.664 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 51
Son 30 gün: 201
Her zaman: 2,890
