Ana içeriğe geç
iPhone 16 5G mmWave Antenna Replacement
Neye ihtiyacın var
  1. iPhone 16 5G mmWave Antenna Replacement, Before you begin: adım 1, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Before you begin: adım 1, 2 resimden 2.
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 16 5G mmWave Antenna Replacement, Tape over any cracks: adım 2, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Tape over any cracks: adım 2, 2 resimden 2.
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 5G mmWave Antenna Replacement, Remove the pentalobe screws: adım 3, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Remove the pentalobe screws: adım 3, 2 resimden 2.
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  4. iPhone 16 5G mmWave Antenna Replacement, Mark your opening picks: adım 4, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Mark your opening picks: adım 4, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Mark your opening picks: adım 4, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  5. iPhone 16 5G mmWave Antenna Replacement, Secure the screen: adım 5, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Secure the screen: adım 5, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Secure the screen: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next four steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down four steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • The Anti-Clamp applies suction to both the screen and the back glass. To open only the back glass, you need to secure the screen with tape. You can also check out the full instructions on how to use this tape.
    • Cut two strips of tape, apply them along the long edges of the phone, and fold them over the screen to secure it.
    • Make sure the tape is only securing the screen and not the back glass.
  6. iPhone 16 5G mmWave Antenna Replacement, Secure an Anti-Clamp: adım 6, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Secure an Anti-Clamp: adım 6, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Secure an Anti-Clamp: adım 6, 3 resimden 3.
    • Pull the Anti-Clamp's blue handle backward to unlock the arms.
    • With the back glass facing up, slide the arms over the right edge of your phone, with one suction cup on the back glass and the other on the screen. Center the suction cups near the bottom edge.
    • Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
    • Squeeze the cups together to create suction.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  7. iPhone 16 5G mmWave Antenna Replacement, Create a gap under the back glass: adım 7, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Create a gap under the back glass: adım 7, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Create a gap under the back glass: adım 7, 3 resimden 3.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle one full turn (360 degrees) or until the cups start to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
    • If you don't have tape, you may warm up the suction cups to help them stick.
  8. iPhone 16 5G mmWave Antenna Replacement, Insert an opening pick: adım 8, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Insert an opening pick: adım 8, 2 resimden 2.
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    • Wait up to a minute for the adhesive to separate and a gap to form between the back glass and the frame.
    • If a gap doesn't appear after one minute, apply more heat and rotate the handle a quarter turn. Let the Anti‑Clamp and time do the work for you.
    • Insert an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  9. iPhone 16 5G mmWave Antenna Replacement, Heat the bottom edge: adım 9, 1 resimden 1.
    iOpener
    $12.99
    • You can also use an iOpener to heat the back glass. Follow these instructions to heat and apply the iOpener properly.
  10. iPhone 16 5G mmWave Antenna Replacement, Insert an opening pick: adım 10, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Insert an opening pick: adım 10, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Insert an opening pick: adım 10, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the back glass.
    • While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  11. iPhone 16 5G mmWave Antenna Replacement, Back glass information: adım 11, 1 resimden 1.
    • As you slice the adhesive securing the back glass in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • A delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • Multiple spring contacts around the perimeter of the phone.
  12. iPhone 16 5G mmWave Antenna Replacement, Heat the right edge: adım 12, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
  13. iPhone 16 5G mmWave Antenna Replacement, Separate the bottom right adhesive: adım 13, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Separate the bottom right adhesive: adım 13, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Separate the bottom right adhesive: adım 13, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
    • Slide your pick around the bottom right corner and to the volume down button to separate the adhesive and release the metal clip.
    • Don't slide past the volume buttons to avoid damaging the wireless charging cable.
    • You'll hear and feel the metal clip release as you pass it.
    • Leave this pick inserted to prevent the adhesive from resealing.
  14. iPhone 16 5G mmWave Antenna Replacement, Heat the left edge: adım 14, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
  15. iPhone 16 5G mmWave Antenna Replacement, Separate the left adhesive: adım 15, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Separate the left adhesive: adım 15, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Separate the left adhesive: adım 15, 3 resimden 3.
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
  16. iPhone 16 5G mmWave Antenna Replacement, Heat the top edge: adım 16, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the top edge of the back glass until it's hot to the touch.
  17. iPhone 16 5G mmWave Antenna Replacement, Separate the top right adhesive: adım 17, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Separate the top right adhesive: adım 17, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Separate the top right adhesive: adım 17, 3 resimden 3.
    • Slide your second opening pick around the top left corner and along the top edge to separate the adhesive and release the metal clips.
    • Continue sliding your pick around the top right corner until you reach the Action button.
  18. iPhone 16 5G mmWave Antenna Replacement, Reposition the back glass: adım 18, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Reposition the back glass: adım 18, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Reposition the back glass: adım 18, 3 resimden 3.
    • At this point, the back glass should be free from the frame. If the back glass feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • Swing open the back glass to the right of the phone to separate the remaining adhesive.
    • Support the back glass with a clean, sturdy object.
    • Remove the opening picks before continuing.
  19. iPhone 16 5G mmWave Antenna Replacement, Remove the middle connector cover screws: adım 19, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Remove the middle connector cover screws: adım 19, 2 resimden 2.
    • Use a tri-point Y000 driver to remove the two 1 mm‑long screws securing the middle connector cover.
  20. iPhone 16 5G mmWave Antenna Replacement, Remove the middle connector cover: adım 20, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Remove the middle connector cover: adım 20, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Remove the middle connector cover: adım 20, 3 resimden 3.
    • Insert the point of a spudger in either cutout on the middle connector cover.
    • Slide the cover towards the left edge of the phone and release its hook from its slot on the logic board.
    • Remove the cover.
  21. iPhone 16 5G mmWave Antenna Replacement, Disconnect the battery: adım 21, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Disconnect the battery: adım 21, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  22. iPhone 16 5G mmWave Antenna Replacement, Disconnect the wireless charging coil: adım 22, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Disconnect the wireless charging coil: adım 22, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
  23. iPhone 16 5G mmWave Antenna Replacement, Remove the back glass: adım 23, 1 resimden 1.
    • Lift the back glass off the frame and remove it.
  24. iPhone 16 5G mmWave Antenna Replacement, Remove the top bracket screws: adım 24, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Remove the top bracket screws: adım 24, 2 resimden 2.
    • Use a screwdriver to remove the four screws securing the top bracket:
    • One 3.5 mm-long Phillips screw
    • Two 1.4 mm-long Phillips screw
    • One 1.0 mm-long tri-point Y000 screw
  25. iPhone 16 5G mmWave Antenna Replacement, Remove the top bracket: adım 25, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Remove the top bracket: adım 25, 2 resimden 2.
    • Use tweezers, or your fingers, to remove the top bracket.
  26. iPhone 16 5G mmWave Antenna Replacement, Disconnect the front camera: adım 26, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Disconnect the front camera: adım 26, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Disconnect the front camera: adım 26, 3 resimden 3.
    • Use the point of a spudger to pry up and disconnect the two front camera press connectors.
    • The second press connector is underneath the first.
  27. iPhone 16 5G mmWave Antenna Replacement, Remove the front camera: adım 27, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Remove the front camera: adım 27, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Remove the front camera: adım 27, 3 resimden 3.
    • Insert the point of a spudger between the top edge of the front camera and the frame.
    • Lift the front camera out of the frame and remove it.
  28. iPhone 16 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: adım 28, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: adım 28, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the 5G mmWave antenna press connector.
  29. iPhone 16 5G mmWave Antenna Replacement, Remove the stretch release adhesive: adım 29, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Remove the stretch release adhesive: adım 29, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Remove the stretch release adhesive: adım 29, 3 resimden 3.
    • Use angled tweezers to grip the black pull tab at the bottom right corner of the 5G mmWave antenna.
    • Press the antenna down with your free hand and use your tweezers to pull the stretch‑release adhesive strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the antenna.
    • To better grip the adhesive strip, you can twist it around the tip of the tweezers while you pull.
    • If the adhesive strip breaks off, try to retrieve it with your tweezers and continue pulling.
    • If you can't retrieve the strip, follow the next two steps for an alternate method. Otherwise, skip the next two steps.
  30. iPhone 16 5G mmWave Antenna Replacement, Apply isopropyl alcohol: adım 30, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Apply isopropyl alcohol: adım 30, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Apply isopropyl alcohol: adım 30, 3 resimden 3.
    • Apply a few drops of isopropyl alcohol (>90%) to the bottom edge of the 5G mmWave antenna.
    • Lift the bottom edge of the phone to let the isopropyl alcohol flow under the antenna.
    • Wait one minute for the adhesive to loosen.
  31. iPhone 16 5G mmWave Antenna Replacement, Pry up the antenna: adım 31, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Pry up the antenna: adım 31, 2 resimden 2.
    • Insert the flat end of a spudger under the top left edge of the 5G mmWave antenna, near the front camera cutout.
    • Pry up the antenna to separate the adhesive.
  32. iPhone 16 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna: adım 32, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna: adım 32, 2 resimden 2.
    • Lift the 5G mmWave antenna off the earpiece speaker and remove it.
  33. iPhone 16 5G mmWave Antenna Replacement, End of disassembly: adım 33, 1 resimden 1.
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  34. iPhone 16 5G mmWave Antenna Replacement, Remove the old adhesive: adım 34, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Remove the old adhesive: adım 34, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Remove the old adhesive: adım 34, 3 resimden 3.
    • Use tweezers or your fingers to remove the old adhesive from the top of the earpiece speaker.
  35. iPhone 16 5G mmWave Antenna Replacement, Apply new adhesive: adım 35, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Apply new adhesive: adım 35, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Apply new adhesive: adım 35, 3 resimden 3.
    • Apply thin double-sided tape, such as Tesa tape, to the back of the 5G mmWave antenna.
    • Only apply tape to the black fiberglass part of the antenna, not to the metal part.
    • Peel off the backing to expose the adhesive.
  36. iPhone 16 5G mmWave Antenna Replacement, Connect the antenna: adım 36, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Connect the antenna: adım 36, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Connect the antenna: adım 36, 3 resimden 3.
    • Use tweezers or your fingers to hold the 5G mmWave antenna above its cutout in the earpiece speaker.
    • To ensure the antenna is correctly aligned, do not let the adhesive touch the earpiece speaker yet.
    • Use the flat end of a spudger or your finger to connect the antenna press connector.
    • Press the 5G mmWave antenna into its cutout to ensure it adheres fully to the earpiece speaker.
  37. iPhone 16 5G mmWave Antenna Replacement, Place the front camera assembly: adım 37, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Place the front camera assembly: adım 37, 2 resimden 2.
    • Place the front camera assembly into its recess in the frame.
  38. iPhone 16 5G mmWave Antenna Replacement, Connect the front camera assembly: adım 38, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Connect the front camera assembly: adım 38, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Connect the front camera assembly: adım 38, 3 resimden 3.
    • Use the flat end of a spudger or your finger to connect the front camera's bottom press connector, then the top press connector.
  39. iPhone 16 5G mmWave Antenna Replacement, Reinstall the top bracket: adım 39, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Reinstall the top bracket: adım 39, 2 resimden 2.
    • Use tweezers, or your fingers, to reinstall the top bracket.
  40. iPhone 16 5G mmWave Antenna Replacement, Install the top bracket screws: adım 40, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Install the top bracket screws: adım 40, 2 resimden 2.
    • Use a screwdriver to install the four screws securing the top bracket:
  41. iPhone 16 5G mmWave Antenna Replacement, Remove the back glass adhesive: adım 41, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Remove the back glass adhesive: adım 41, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Remove the back glass adhesive: adım 41, 3 resimden 3.
    • Be careful not to damage any of the spring contacts as you clean the frame.
    • This is a good point to test your repair before sealing up your phone. Connect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down, disconnect the battery and back glass, and continue reassembly.
    • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use the pointed end of a spudger to press and roll the adhesive until you can grip it with a pair of tweezers.
  42. iPhone 16 5G mmWave Antenna Replacement: adım 42, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement: adım 42, 2 resimden 2.
    • Use the tweezers to pull the adhesive off of the phone.
    • Repeat the previous step and this step until all of the adhesive is removed.
  43. iPhone 16 5G mmWave Antenna Replacement, Clean the frame: adım 43, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Clean the frame: adım 43, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Clean the frame: adım 43, 3 resimden 3.
    Microfiber Cleaning Cloths
    $3.99
    • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
    • Wrap a microfiber or lint-free cloth over the point of a spudger and apply a few drops of high-concentration isopropyl alcohol (over 90%) to the cloth.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
  44. iPhone 16 5G mmWave Antenna Replacement, Clean the black glass: adım 44, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Clean the black glass: adım 44, 2 resimden 2.
    • If you're not reusing your back glass, skip this step.
    • Apply a few drops of high-concentration isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter of the back glass to prepare the surface for new adhesive.
    • If any clips on the back glass are bent, gently straighten them with your fingers.
  45. iPhone 16 5G mmWave Antenna Replacement, Orient the adhesive: adım 45, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Orient the adhesive: adım 45, 2 resimden 2.
    • Orient your replacement adhesive over the frame with the larger blue liner on the underside and its pull tab in the bottom-right corner.
    • The color of your liner and the pull tab locations may be different on your adhesive.
    • Use features such as the camera cutout and notches along the edges to visualize how the adhesive will lay in the frame.
  46. iPhone 16 5G mmWave Antenna Replacement, Expose the bottom edge of the adhesive: adım 46, 1 resimden 1.
    • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
  47. iPhone 16 5G mmWave Antenna Replacement, Apply the adhesive: adım 47, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Apply the adhesive: adım 47, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Apply the adhesive: adım 47, 3 resimden 3.
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Hold the blue liner out of the way and align the adhesive with the bottom edge of the iPhone.
    • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
  48. iPhone 16 5G mmWave Antenna Replacement: adım 48, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement: adım 48, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement: adım 48, 3 resimden 3.
    • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
  49. iPhone 16 5G mmWave Antenna Replacement, Press the adhesive into place: adım 49, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Press the adhesive into place: adım 49, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Press the adhesive into place: adım 49, 3 resimden 3.
    • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
    • Be careful not to touch the spring contacts sticking through the pink liner.
  50. iPhone 16 5G mmWave Antenna Replacement, Remove the pink liner: adım 50, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Remove the pink liner: adım 50, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Remove the pink liner: adım 50, 3 resimden 3.
    • Use the small pull tab in the top-right corner to remove the pink adhesive liner.
  51. iPhone 16 5G mmWave Antenna Replacement: adım 51, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement: adım 51, 2 resimden 2.
    • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
    • Your pull tabs may be in different positions.
    • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. If the adhesive is clean and properly aligned, you may proceed, just be careful not to touch anything to the exposed adhesive until you are ready to install the back glass.
  52. iPhone 16 5G mmWave Antenna Replacement, Connect the charging coil: adım 52, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Connect the charging coil: adım 52, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Connect the charging coil: adım 52, 3 resimden 3.
    • Prop up the back glass along the right edge of your iPhone, using a box or similar sturdy object to support the screen.
    • Use the flat end of a spudger or your finger to connect the charging coil press connector.
  53. iPhone 16 5G mmWave Antenna Replacement, Connect the battery: adım 53, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Connect the battery: adım 53, 2 resimden 2.
    • Use the flat end of a spudger or your finger to connect the battery.
  54. iPhone 16 5G mmWave Antenna Replacement, Install the cover: adım 54, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Install the cover: adım 54, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Install the cover: adım 54, 3 resimden 3.
    • The connector cover has two hooks that slide into slots on the logic board.
    • Lay the connector cover on the phone so the hooks are slightly to the left of their slots in the logic board.
    • Use your finger to press the connector cover down and to the right until both hooks slide into their slots.
  55. iPhone 16 5G mmWave Antenna Replacement, Install the cover screws: adım 55, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Install the cover screws: adım 55, 2 resimden 2.
    • Use a tri-point Y000 driver to install the two 1 mm‑long screws securing the middle connector cover.
  56. iPhone 16 5G mmWave Antenna Replacement, Remove the final adhesive liners: adım 56, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Remove the final adhesive liners: adım 56, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Remove the final adhesive liners: adım 56, 3 resimden 3.
    • As you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing touches the exposed adhesive.
    • Use the blue tabs to remove the liners from the bottom, left, and top edges of your iPhone. Wait to remove the liner along the right edge.
  57. iPhone 16 5G mmWave Antenna Replacement: adım 57, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement: adım 57, 2 resimden 2.
    • Without letting the back glass touch the adhesive, hold the back glass over the phone so you can access the final liner along the right edge of the phone.
    • Use a pair of tweezers or your fingers to remove the final liner along the right edge of the phone.
  58. iPhone 16 5G mmWave Antenna Replacement, Place the back glass: adım 58, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Place the back glass: adım 58, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Place the back glass: adım 58, 3 resimden 3.
    • Hold the back glass above the phone and align it with the frame.
    • Lay the glass straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the back glass to engage all clips.
  59. iPhone 16 5G mmWave Antenna Replacement, Heat the back glass: adım 59, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Heat the back glass: adım 59, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Heat the back glass: adım 59, 3 resimden 3.
    • To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • Firmly press around the perimeter of the back glass.
    • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the back glass.
  60. iPhone 16 5G mmWave Antenna Replacement, Press the back glass: adım 60, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Press the back glass: adım 60, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement, Press the back glass: adım 60, 3 resimden 3.
    • To evenly compress your iPhone and strengthen the bond of the back glass to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
  61. iPhone 16 5G mmWave Antenna Replacement: adım 61, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement: adım 61, 2 resimden 2.
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the back glass.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
  62. iPhone 16 5G mmWave Antenna Replacement: adım 62, 3 resimden 1. iPhone 16 5G mmWave Antenna Replacement: adım 62, 3 resimden 2. iPhone 16 5G mmWave Antenna Replacement: adım 62, 3 resimden 3.
    • Place two layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
  63. iPhone 16 5G mmWave Antenna Replacement: adım 63, 1 resimden 1.
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
  64. iPhone 16 5G mmWave Antenna Replacement, Install the pentalobe screws: adım 64, 2 resimden 1. iPhone 16 5G mmWave Antenna Replacement, Install the pentalobe screws: adım 64, 2 resimden 2.
    • Use a P2 pentalobe driver to install the two 7.7 mm-long screws on either side of the charging port.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Answers Community for help.
Alex Diaz-Kokaisl
162.014 İtibar
769 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.418 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 91
Son 30 gün: 375
Her zaman: 2,236
