Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
iPhone 7 Home/Touch ID Sensor Replacement
Neye ihtiyacın var
  1. iPhone 7 Home/Touch ID Sensor Replacement, Pentalobe Screws: adım 1, 1 resimden 1.
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Home/Touch ID Sensor Replacement, iPhone 7 Opening Procedure: adım 2, 1 resimden 1.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. iPhone 7 Home/Touch ID Sensor Replacement: adım 3, 2 resimden 1. iPhone 7 Home/Touch ID Sensor Replacement: adım 3, 2 resimden 2.
    • Attach a suction cup to the lower half of the display assembly, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 7 Home/Touch ID Sensor Replacement: adım 4, 3 resimden 1. iPhone 7 Home/Touch ID Sensor Replacement: adım 4, 3 resimden 2. iPhone 7 Home/Touch ID Sensor Replacement: adım 4, 3 resimden 3.
    • Pull up on the suction cup to create a small gap between the display assembly and the rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong, and creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
  5. iPhone 7 Home/Touch ID Sensor Replacement: adım 5, 3 resimden 1. iPhone 7 Home/Touch ID Sensor Replacement: adım 5, 3 resimden 2. iPhone 7 Home/Touch ID Sensor Replacement: adım 5, 3 resimden 3.
    • Slide the spudger to the left along the lower edge of the iPhone.
    • Twist the spudger to widen the gap between the display and rear case.
  6. iPhone 7 Home/Touch ID Sensor Replacement: adım 6, 3 resimden 1. iPhone 7 Home/Touch ID Sensor Replacement: adım 6, 3 resimden 2. iPhone 7 Home/Touch ID Sensor Replacement: adım 6, 3 resimden 3.
    • Slide the spudger up the left side of the iPhone, starting at the lower edge and moving towards the volume control buttons and silent switch.
    • Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display.
  7. iPhone 7 Home/Touch ID Sensor Replacement: adım 7, 3 resimden 1. iPhone 7 Home/Touch ID Sensor Replacement: adım 7, 3 resimden 2. iPhone 7 Home/Touch ID Sensor Replacement: adım 7, 3 resimden 3.
    • Insert the flat edge of a spudger into the bottom right corner of the device.
    • Twist the spudger to widen the gap between the display assembly and the rear case.
    • Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
    • Do not insert the spudger further than the adhesive to avoid damaging delicate ribbon cables along the right edge.
  8. iPhone 7 Home/Touch ID Sensor Replacement: adım 8, 2 resimden 1. iPhone 7 Home/Touch ID Sensor Replacement: adım 8, 2 resimden 2.
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10º as there are ribbon cables along the right edge of the device connecting the display to the logic board.
  9. iPhone 7 Home/Touch ID Sensor Replacement: adım 9, 1 resimden 1.
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  10. iPhone 7 Home/Touch ID Sensor Replacement: adım 10, 2 resimden 1. iPhone 7 Home/Touch ID Sensor Replacement: adım 10, 2 resimden 2.
    • Slide an opening pick along the top edge of the iPhone, between the rear case and front panel, to break up the remaining adhesive holding the screen in place.
    • Be careful not to damage the plastic clips on the top edge of the phone.
  11. iPhone 7 Home/Touch ID Sensor Replacement: adım 11, 3 resimden 1. iPhone 7 Home/Touch ID Sensor Replacement: adım 11, 3 resimden 2. iPhone 7 Home/Touch ID Sensor Replacement: adım 11, 3 resimden 3.
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  12. iPhone 7 Home/Touch ID Sensor Replacement, Battery Disconnection: adım 12, 1 resimden 1.
    Bu adımda kullanılan alet:
    Tri-point Y000 Screwdriver
    $5.99
    Satın Al
  13. iPhone 7 Home/Touch ID Sensor Replacement: adım 13, 1 resimden 1.
    • Remove the lower connector bracket.
  14. iPhone 7 Home/Touch ID Sensor Replacement: adım 14, 3 resimden 1. iPhone 7 Home/Touch ID Sensor Replacement: adım 14, 3 resimden 2. iPhone 7 Home/Touch ID Sensor Replacement: adım 14, 3 resimden 3.
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  15. iPhone 7 Home/Touch ID Sensor Replacement, Display Assembly: adım 15, 3 resimden 1. iPhone 7 Home/Touch ID Sensor Replacement, Display Assembly: adım 15, 3 resimden 2. iPhone 7 Home/Touch ID Sensor Replacement, Display Assembly: adım 15, 3 resimden 3.
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  16. iPhone 7 Home/Touch ID Sensor Replacement: adım 16, 3 resimden 1. iPhone 7 Home/Touch ID Sensor Replacement: adım 16, 3 resimden 2. iPhone 7 Home/Touch ID Sensor Replacement: adım 16, 3 resimden 3.
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
  17. iPhone 7 Home/Touch ID Sensor Replacement: adım 17, 2 resimden 1. iPhone 7 Home/Touch ID Sensor Replacement: adım 17, 2 resimden 2.
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  18. iPhone 7 Home/Touch ID Sensor Replacement: adım 18, 1 resimden 1.
  19. iPhone 7 Home/Touch ID Sensor Replacement, Home/Touch ID Sensor: adım 19, 1 resimden 1.
    • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
    • One 1.1 mm screw
    • Three 1.3 mm screws
    • During reassembly, be careful not to overtighten these screws, or your home button may not work.
  20. iPhone 7 Home/Touch ID Sensor Replacement: adım 20, 1 resimden 1.
    • Remove the bracket that secures the home/Touch ID sensor.
  21. iPhone 7 Home/Touch ID Sensor Replacement: adım 21, 3 resimden 1. iPhone 7 Home/Touch ID Sensor Replacement: adım 21, 3 resimden 2. iPhone 7 Home/Touch ID Sensor Replacement: adım 21, 3 resimden 3.
  22. iPhone 7 Home/Touch ID Sensor Replacement: adım 22, 2 resimden 1. iPhone 7 Home/Touch ID Sensor Replacement: adım 22, 2 resimden 2.
    • Carefully pry up the underlying connector and move it out of the way of the home/Touch ID cable.
    • It's very easy to damage your iPhone during this step. Work slowly and take care where you pry with your tool. If you damage the Touch ID hardware, it can only be replaced by Apple.
    • If the connector doesn't pry up easily, use a hair dryer or iOpener to heat and soften the adhesive securing the connector, and then try again.
    • Don't try to detach the connector completely—simply flip it up slightly so that the underlying home/Touch ID sensor cable can be removed.
  23. iPhone 7 Home/Touch ID Sensor Replacement: adım 23, 1 resimden 1.
    • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
    • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
  24. iPhone 7 Home/Touch ID Sensor Replacement: adım 24, 3 resimden 1. iPhone 7 Home/Touch ID Sensor Replacement: adım 24, 3 resimden 2. iPhone 7 Home/Touch ID Sensor Replacement: adım 24, 3 resimden 3.
    • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
  25. iPhone 7 Home/Touch ID Sensor Replacement: adım 25, 1 resimden 1.
    • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
    • To reinstall, first feed the cable through the hole in the front of the display.
    • Your replacement part may come with an extra Y000 screw already installed right of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
    • Follow this guide to install replacement display adhesive on your screen.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
110 farklı kişi bu kılavuzu tamamladı.
Paige Reisman
23.586 İtibar
15 adet Kılavuz yazıldı
8 Yorum
I read through this guide for fun and I must say it's %#*@ good,It's by far the most informative and it's full of great never mentioned tips too ensure you don't cause damage,I rarely see any precautions outside of the basics,like remove the battery connection first and we all know what can happen when you don't so GREAT WRITE UP
Vegeta Barrett - Yanıt
Just to be clear. I understand that the Touch ID won’t work if the logic board is not paired (the same as before). But are you also saying that an original home button won’t even click on another logic board? As in, if I take my whole screen and put into another phone, the click won’t work either?
garfolino - Yanıt
Yes. On the iPhone 5s - 6s you lost touch ID functionality but on The 7 and 8 series, you lose all home button functionality as well.
Fionán Kelly -
I found another article on the ifixit website saying it’s absolutely NOT possible to replace the iPhone 7 home button:
https://www.ifixit.com/News/9020/no-fix-...
What’s the story?
Thomas - Yanıt
I have iphone 7..my home button is working but touch id isn’t responding…why????
roshan Kumar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 66
Son 7 gün: 444
Son 30 gün: 1,937
Her zaman: 204,954
