Giriş
Replacing the WiFi antenna can help solve problems with bad or no WiFi reception, slow internet access when connected via WiFi, and WiFi connection issues.
Neye ihtiyacın var
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located near the side button on the edge of the iPhone.
Press firmly to eject the tray.
Power off your iPhone before beginning disassembly.
Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Bu adımda kullanılan alet:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen and the plastic bezel, not the screen itself.
Skip the next three steps.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Remove five Y000 screws securing the logic board connector bracket, of the following lengths:
Three 1.1 mm screws
One 3.1 mm screw
One 3.7 mm screw
Use the point of a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Remove the seven screws securing the bracket below the Taptic Engine and speaker:
Two Y000 1.9 mm screws
One Y000 1.2 mm screw
One Y000 1.6 mm screw
One Phillips 2.4 mm screw
One Phillips 1.7 mm screw
One Phillips 1.5 mm screw
Each piece of adhesive has a black pull-tab at the end, which is lightly adhered to the side edge of the battery.
To increase your odds of success:
Don't press down on the battery. Hold the iPhone firmly by its sides.
Keep the strips flat and unwrinkled as you pull.
Pull very slowly, giving the strip time to stretch and separate. It takes around 15-30 seconds of stretching to remove each strip.
Pull at a low angle so the strip doesn't snag along the bottom edge of the battery.
If a strip does break off underneath the battery and cannot be retrieved, move on to the other strips and then continue with the additional steps below.
If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
Flip the iPhone back over and thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
Wrap the ends of the string around a cloth (or wear gloves) to protect your fingers.
Pull the string from side to side in a sawing motion all along the length of the battery to separate the adhesive. This can take some time since the adhesive is slow to deform, but with patience it will come free. Do not deform or damage the battery.
Using the flat end of a spudger, disconnect the three front camera assembly cables:
The dot projector.
The front camera.
The infrared camera.
Disconnect the following cable connectors.
The WiFi Antenna connector.
The Wide-Angle Camera connector.
The Power Button / Flash / Microphone connector.
The Telephoto Camera connector.
The Dock Flex connector.
The Button / Wireless Charging connector.
The Cellular Antenna connector.
Disconnect the Power Button / Flash / Microphone cable connector.
Disconnect the Dock Flex cable connector.
Bend the cable 90 degrees straight up to allow clearance to remove the logic board.
Disconnect the Button / Wireless Charging cable connector.
Disconnect the Cellular Antenna cable connector.
Bend the cable out of the way.
When the SIM card is ejected, a pin slides out from the frame and pushes on the eject lever in the SIM card carrier. The pin needs to be pushed back into the frame so it will not block the removal of the logic board.
Remove the 1.4 mm Phillips screw holding the first grounding tab.
Remove the grounding tab.
8 farklı kişi bu kılavuzu tamamladı.
2 Yorum
The connector is shown plugging into the motherboard on step 55.
